The front right fender supports broke on my 08 GS with about 25,000 miles on Needles highway near Sturgis. Cracked right at the transition from bracket to round tube. Had a welder fix it with a steel pin placed in the tube and welded. $25 fix.
I had the same thing happen to me also. I had the fender supports fixed two times. The problem is they are hollow on the inside and all of the vibration and bumpy roads just tears them apart. I found a shop to make me some duplicate fender supports that a fully aluminum, no problems since.
I now have 40,000 on the Spyder so the welded support has held together. The right wheel hub was warped so that was replaced and no vibrations now. I thought the disc was warped but when they checked it they found the hub was the problem.
and what were the results? any more vibration than before? and how about an image?
+The results are fine. I asked him to insert a rod into the hollow before welding it. Vibes are the same, and have never been a problem. Crummy roads are the problem. I didn't take any pics because it looks the same.
