SpyderLovers Sponsor
Originally Posted by spydernatic
I want to order one of these Bumpskids but have heard that it may increase the bikes temperature ...anyone have more info on this for me or experienced an increased temperature on the bike once they have installed the Spyderpops bumpskid?
NO!!!! The BumpSkid does not raise the operating temperature on the RT or RS. The extra lip around the leading edges increases the flow of air into the radiators.
There was a discussion about the ambient temp gauge showing a higher temp after installing the BumpSkid, but when I have investigated this with over 10 different RT 's I still haven't found one registering a higher room temp.
Hundreds of satisfied customers with no increases in operating temps.
Harvey
I've had mine installed for the past year. If anything, it may have helped reduce the temp with the increased & efficient air flow. I think it may have also increased my gas mileage. It also saved me some damage to the front air dam.
GOS member (Girls On Spyders)
Bump Skid
Since I have installed mine the ambient temp shown on the bikes screen is DEFINITELY & CONSISTENTLY at least 15 degrees higher! I rode last week and the temp out was 31 degrees and the bikes shown outside ambient temp NEVER went below 55 degrees. For some reason my bike may be different but the results are accurate, consistent & reproducible! I did remove the OEM shield and followed the install exactly. I cannot understand why mine is this way and some are not!
Just sayin!
2015 an Am Spyder RT Limited
2013 Yamaha WR250R - Sold
2011 Can Am Spyder RT-S SE5 Limited - Sold
2011 Aspen Sentry Trailer
2003 BMW K1200LT - Sold
2007 Unigo Trailer - Sold
2001 BMW K1200LT - Sold
2001 Honda 750 NightHawk - sold
2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
Motorbike Professor
The display ambient temperature does seem to run higher with the BumpSkid, but the engine water temperature does not.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
SpyderLovers Founder
Just sayin!
Easy way to find out is to remove the bump skid and then check it.
my input to this is i have everything spyderpops offer for the rt and that includes both block-off plates and i haven't had a problem at all with it running extremely hot i would say that it proably ran one bar higher than normal but that would be it and that was put to the test in this texas heat this year.
Tall flag mount, spyderpops skid plate & stainless steel screen mesh, airhawk adjustable cushion, raised white lettered tires.
For clarification!
Let me make it clear that the bike does not run hotter with the bumpskid! It is only the ambient (outside air temp) as it reads on the display. The bike engine temperature is fine. I want to make it clear that the bumpskid is an amazing product and does exactly as promised! It's terrific protection for the bottom as well as the leading edge! I would easily sacrifice the ambient temp reading for the protection this product provides!!
Bump Skid
I have checked my outside air temp on the display alot before in stalling the bump skid. It was always higher then the outside temp.
After the skid if the temp change I have not noticed.
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
I have often wondered where the temp sensor is on my RSS. My temp is always higher than outside temp. Anyone know where the sensor is??
On my RS it was on the right side of the frunk under the tupperware,had to disconnect to remove frunk when in put in power outlet.
2015 RT White,Tj's Dash mount,Rivco's Duel Flag Holder,SealsFloorBoards(Pups),Custom Dynamics fender lights(R/W)Bajaron's Swaybar & links,Lamonster's LED headlights,lidlox.Wiredux A-arm driving lights(upper&lower)FOBO TPMS system,Spyerpops lighted bumpskid,Foom handgrips. tobor9@me.com
Motorbike Professor
You should be able to see it by looking in the right side vent below the foglight.
-Scotty
So I wonder just how the airflow IS affected...
(Not that it's gonna knock these babies off of my Wish-List!)
Any time I read "easy", "drill", and "remove" all in one description I get paranoid. Can I buy one at SpyderFest and pay someone to install it for me?!?! Please?
Actually I'm happy to pay for it at anytime but would really, really like someone to install it
-Christina
2012 RT-S Blue
Photographer and horse rider.
I'm the same way you were, especially when the said "drill" but I did install it myself. It really was fairly easy, just took a couple of hours and looks great. My biggest obstacle was how to get the spyder lifted, finally borrowed a MC jack and it worked great.
Come on guys. Don't let it scare you! It is very straight forward after you get it off the ground. Remove the existing OEM part. Temporarily attach bumpskid to existing holes. Use bumpskid holes as pilots for new bumpskid bolts, remove bumpskid, slide on new clips and reattach bumpskid. Nothing bad about it at all.
It was a real pain in the butt for me when I installed mine, but then I put down some padding to lay on and it was fine. I agree, it is a real easy instal.
What I found to work best was to instal one of the rear bolts on each side first, then one front bolt in the middle to hold it in place. Then instal the other two rear bolts, and follow with the font half from rear to front. Once you have all the bolts in and started. Tighten them up from rear to front, and switch from side to side to keep pressure even.
Of course this was after doing as bmwlarry instructed on how to drill the pilot holes.
Is it Friday yet? ... Oh yeah, I forgot. I'm retired
Past bikes
2010 RS - Sold
2012 RT - Sold
2014 RT - Testing completed
2016 F3-T Audio package - Sold
I just ordered this. Would I be able to install this myself or would it be better if I had someone install it for me? I like to attempt things but I sure don't want to screw anything up on my RT.
If you have a good (safe) way to lift the Spyder high enough to get under it for the install I would say go for it!
2012 Spyder RT Limited
Guardian Bell (gift from son)
Spyderpops bumpskid
ISCI hand brake
BajaRon Anti-Sway Bar
BRP Adjustable Wind Deflectors
I've had mine on for 6 mos. Last week I pulled it off to install Baja Rons sway bar. Noticed that the 12 screws provided were rusting so I ordered and installed stainless ones from Fastenal.
So $159 and 12 screws that rust after 6 months? Maybe stainless or better coated screws should be provided.
bumpskid
Originally Posted by SPYDERPOPS
You can now go to WWW.SPYDERPOPS.COM AND ORDER.
BumpSkid TM
Ultimate protection for your Spyder RT Roadster!
Dual purpose, functions as a bumper and skid plate with the look of a stylish spoiler.
Your worries are over, no more expensive paint damage.
No more dangerous evasive moves to miss roadkill or tire treads and if a live small critter jumps out in front of you, well you know.
Made from 3/8” black UHMW (ultra high molecular weight) Polyethylene, tough and slick. Replaces that tiny skid plate the lets you tear up your body.
It attaches to the lower flexible area for impact absorption without damaging the body.
Ground clearance is not a problem due to the thin profile. It protects everything from the nose to the suspension.
The coverage eliminates air drag from the open cavity under the nose.
Added down force is created by the spoiler styling.
Very easy to install with all hardware and instructions included.
A bargain at $159.00 + Priority USPS shipping of $19.50 domestic, Canada & Mexico Priority USPS shipping $34.00, All other countries Priority USPS shipping $62.00.
Do you have any that fits a 2015 RSS?
