brake failure
Brake failure indicater screen comes on and red warning light comes on and stays on. Brake pads and fluid levels are good. What can be causing this?
Not sure what you have but I had the brake failure issue on my 2010 RTS SE5. They ended up replacing the brake fluid container under the seat. That cleared it up. Good Luck.
Life should NOT be journey to grave with intention of arriving safely in attractive and well-preserved body, but rather you skid in sideways on 1 leg with body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!"
Check the brake fluid level again ,Very careful, Sometimes if its even a few drops low the warning will come on.
