Results 1 to 3 of 3
    Registered Users taggtr's Avatar
    May 2010
    Tucson, AZ
    Default "Check Transmission" light
    Did my first ride in the rain the other day after installing my Fan Can, which requires removing a splash guard underneath. After riding on some wet roads and water puddles I got the "check transmission" light on the screen. Didn't go into limp mode or anything and was just a block away from home. I haven't ridden it since then, but I do start it up in the garage and there are days it comes on and days it doesn't. Dealership said to let it run and get up to operating temps to see if it is just moisture on the sensor. It hasn't come back on since and I took it around the cul de sac a few times, but wanted to see if anyone else may have had this same situation before hitting the road again.
    Mar 2008
    Allegan, MI
    Check your oil level. Could be just a coincidence.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    May 2010
    Tucson, AZ
    Checked oil, level was fine. She may have just had attitude with riding in the rain and that was her way in telling me or something. But she seems fine now, so far. Do some little trips with her when the weather clears up.
