Foam Grips
I'm looking for foam grips for my 2010 RT-S. I am looking for grips that will fit over the existing grips to give me a little larger diameter. I presently have the Throttlemeiser on my grips which should not interfere. Maybe foam paint roller covers ? Yellow ones? :>) I am sure I have seen posts about these before. Ebay has hundreds of grips but I have no idea which ones will slip over. Any ideas will be appreciated.
Grip puppies. I love them on my RT
Duh! I found my answer using search. Lots of information there.
Foam Grips
Have to agree ref Grip Puppies
Fitted them a couple of months ago on my Spyder RT -S SES Model
1 - Fitted without any problems - Easy install
2 - Less fatigue on hands and they give a much more positive feel for the throttle control
3 - No problem when they get wet - In fact you can still feel the heat from the heated grips and can use the heated grips to dry them out
4 - Original grips will never need replacing as I will just replace the Grip Puppies
I rate them and highly recommend them
Hope this helps
Eddie Sheppard
Reading UK
Spyder – RT-S SES (AUTO 2010 Model)
List of Mods :-
Added Zuno 660 -Garmin kit as supplied on the Spyder RT Limited
Digital Voltmeter and Digital Clock to replace Fuel and Temp gauge – Fuel and Temp now
displayed in Cluster Display
LED Bulbs Reversing Lights,Front position lights
HMT - Brake Light
LED – Running lights
LED - Mud Flap lights
Rear extended Mud Flap
Sport Tall Wide Clear Windshield
Chrome 2011 Front Lower Wind deflecors
Utopia Backrest
S/S Seat Prop
S/S Handlebar Weights
S/S Grills both sides matching
Bottom Panel S/S Protection
S/S stronger Funk Lid brackets
S/S Bracket for RBNS Hood for Zumo 660 GPS + TourTech Lockable Mount
Rubber Tank protector on glove box
Grip Puppies
Power Socket in Switch Cluster and at Rear passenger Handrail
Rear Speaker Switch for passenger On/OFF
Upgraded Front Marine Speakers
Bluetooth On board Radio to Sena SMH10 Headsets
Here is where you get Grip Puppies in case anyone is looking
http://www.casporttouring.com/cst/mo...e/GPSMALL.html
Thanks for the link!
They really do work and as winter approaches I took them off till spring and put on the Oxford "Hot Hands" Wraps and they do almost the same thing with :"HEAT!"
Sea Doo GTI-SE 90 Jet Ski!!
Heat comes thur my grip puppies very well. Can get almost too hot on high setting.
