Key in Frunk
I was closing the frunk to head in for lunch with the group and as it clicked I thought....Oh crap!!! My key,wallet, and cell phone is in my coat pocket. I knew I wasn't the only one to do this and remember reading something on this forum. One of the guys had a smart phone with a good signal and 5 minutes later the left panel with the quick clips was removed, the latch cable identified, and a slight tug released the frunk. This forum is awesome, as are all the helpful people. Keep posting those boo-boos and the solutions. Your not alone and the life you save might just be mine, or at least keep me from calling the wife to bail me out.
Stay Safe!
PaulB
2011 Orange/Black Spyder RS-S
Here's an idea for the future. Drill a small hole in the oil dip stick handle, and use a small black cable tie, to connect your spare key to it. It only takes 30 seconds to remove the tupperware and then your back in business.
If you don't want your spare on the bike you can also have a key cut to open the frunk, and use a hide-a-key box on the side of the oil sump.
Catching a Yellow Jacket in your helmet at 65 mph can double your vocabulary
Spyderlovers.com is awesome!
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Motorbike Professor
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Key in Frunk
I keep my spare key on a lanyard around my neck under my shirt whenever I ride. Part of my pre-ride ritual is to hang that key around my neck. It doesn't get in the way, and it doesn't get lost/locked away. But, that's just me. The lanyard came from Sports Authority and cost less than $5.
2009 GS SE5 Silver
You could just bring your wife along with you when you ride and have her carry the spare key on her! That's what Erags does!
2008 GS Phantom, 2012 RT Limited
Cheryl Reinhart Ragsdale
I really like the ERAGS approach.....
220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
IPS - In Plain Sight ...solves the problem.
Happy Owner * 2013 RT Limited, 2009 RS SE-5
Some months ago I took Scotty's wire in a plastic tube a step further. I've never locked my keys in the frunk, but wanted quick, easy access without having to get the key back out. I ran some picture hanging wire in a tube from the frunk release through the rubber collar around the steering shaft and put a 3/4" ring on the end. If I'm around I leave the ring above the collar. If not it tucks down below = outta sight. This way I don't have to take a panel off. Less work.
2022 Plasma Red, F3 Limited, Special Series
