Registered User
RT IMPROVEMENTS FOR 2011 & 2012
THIS VIA BRP.SEPT 2011
2011 RT CHANGES
FRONT SUSPENSION CAM ADJUSTER ,ALL 2011'S
RT-REAR SUSPENSION AND SWING ARM STOPER, ALL
RT-BRAKE LIGHT SWITCH PROTECTION, ALL
RT-CARGO AND TRAILER BARREL, ALL
RT-CLUSTER SOFTWEAR ISSUES, RUNNING CHANGE
RT-REAR AIR SUSPENSION FACTORY SETTINGS, RUNNING CHANGE
RT-OIL PRESSURE SWITCH, RUNNING CHANGE
RT-ANTENNA, RUNNING CHANGE
RT-DRIVER RIGHT HEATED GRIP (BETTER BALANCE), RUNNING CHANGE
RT-LEFT COMMODO TIGHTER FIT WITH HANDLE BAR, RUNNING CHANGE
RT-THROTTLE BODY RELIABILITY, RUNNING CHANGE LATE 2011
RT-PARKING BRAKE CABLE AND SWITCH, RUNNING CHANGE LATE 2011
RT-REAR CENTER CARGO LATCHING, RUNNING CHANGE LATE 2011
RT-CRUISE CONTROL ACCURACY, RUNNING CHANGE LATE 2011
2012 RT CHANGES
RT-THROTTLE BODY RELIABILITY, ALL
RT-SCREWED GROMET ON SIDE PANELS, ALL
RT-FRONT CARGO LIGHT SWITCH PROTECTION, ALL
RT-IRRIDIUM SPARK PLUGS, ALL
RT-NEW FRONT FENDER PACKAGING,ALL
RT-WINDSHIELD TIGHTER ASSY, ALL
RT-COOLING TANK, ALL
RT-WINDSHIELD PROTECTION VS SUPPORT, ALL
RT-FUEL GAUGE WITH ELECTRONIC DAMPING, RUNNING CHANGE
RT-CLUSTER NEEDLE STICKING, RUNNING CHANGE
OTHER IMPROVEMENTS ARE CURRENTLY BEING EVALUATED
HOPE YA ALL FIND THIS OF HELP
What exactly is a commodo?
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
They changed the seat on the 2012 also to make it farther back and lower. I wonder how it feels?
I think that would be the multi-function switch on the left side.
SpydermanCT
2010 RT-S SE5 Timeless Black PE # 794 ~ RT-622 Trailer ~ Can-Am Garmin 665 GPS ~ Elka Front Shocks ~ ESI Brightsides with Rips Kit ~ ESI RT Fender Tips Kit ~ Rear Brightsides ~ HMT Brake Light ~ Tricplate rear running / Brake LED's ~ ESI Mud Flap Lights ~ LED Day Runners ~ Right Side Inlet Covers ~ Street Magic Scuff Guards ~ IPS Key Cover ~ KewlMetal Kewlocks ~ Spyderpops Radiator Block Off Plate and Catalytic Converter Shield Set ~ Carbon Fiber Kit ~ Corbin Seat
Did they mean "Commode"? Wow! This thing is better equipped than I thought!
Aspydering Ryder
subsisto inrideo amicitia
I may not be perfect but, I am Canadian, and that's close enough!
Has anyone heard when the 2012's will be available?
Motorbike Professor
Let's not forget the increased damping on the 2011 front shocks, the cut-down windshield, and the revised wind deflectors. BTW, I have been asking for increased cruise control sensitivity for some time, which I got with the throttle body update, new throttle body, and new gauge cluster. It is a very welcome improvement!
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Improvements
All these improvements it makes me feel like I own an old Spyder not just my 2010 model. I will put Iridiums plugs in at my 12,000 mile service. I would guess that my dealer should stock them if they are now standard on the 2012 models?
V4 Engine
BRP has all my money and won't get anymore until they replace the engine. Fine for most from what I read but NOT me. A multi cylinder with larger displacement is a must for a tourer with this bulk to push through the air. Just my thoughts.
Damn, I just had the windshield mechanism replaced under warranty because the control arm broke.
The new one is as shaky as the original.
The shake doesn't bother me, it's just that I think that was the root cause of the failure.
Reason: I can't type for beans
IBA #47122
2020 RT Limited Asphalt Grey
Does the replacement arm appear to be the same as the piece that broke??
Motorbike Professor
These types of continuous improvements and refinements (many driven by warranty bulletins or technical service bulletins meant to correct problems or errors) are common for all vehicles. In many cases, if you have had some updates done under warranty, you have the same improvements. They are just not normally listed and quantified like this.
-Scotty
2012's
I have spoken with numerous dealers and even BRP (who were very tight lipped about the whole thing) and the general idea I get is: the 2012's will be coming out in December or around the first of the year. Keep in mind, that is nothing official and little more than idle gossip from Can-Am dealers (TN-Carolinas), but that's what they told me at the beginning of this month. Who knows what the reality is.
Paul "Wingman" Metheney
2020 Can-Am Spyder RT Limited
BRP Save a Life
Hope BRP is listeniNg. I have so many comments about gas fumes on the RT, bRTS, Limited. Many Spyder owners park their Spyders in their garages and basements, when they open the the door, they are overwhelmed with gas fumes, this Is a recipe for a bomb, a light switch, hot water heater, compressor, electric door opener is just the catalyst for a spark and an explosion.Lamonte was able to help his, surely BRPwill follow suit with a fix on the 2012's and a recall on the others before someone gets hurt seriously or even worse killed. I am a dedicated Spyder Lover, but can not help but hope BRP puts priorities on the fixes.
To my untrained eye, the new arm appears to be the same as the old one.
I know for a fact that the replacement arm/mechanism carries a different part number than the original. I do not know if the new number is a true design change, or simply an inventory change.
Also, I was told that the old arm appeared to be a poor casting so it wasn't as strong as it could be. Only time will tell on the new one. I'm surely going to get the BEST warranty extension.
IBA #47122
I'm with you Tonga...
I will NOT be riding a RT, until the power-to-weight ratio is equivalent too or better than my GS...
I had hopes of purchasing a 2012 RT with a significant increase in the HP and torque department...
BRP really stepped up the power in the ATV's for 2012...You can now get an ATV with a 1000 motor...
The Ski-Doo's, Sea-Doo's and ATV's FOLLOW NO ONE...
Maybe 2013 will be the SPYDER'S turn to lead the pack???
