Results 1 to 12 of 12
    Jan 2009
    austria
    Default adjustable handlebars for the RT ?
    started to think about my winter-work for my spyder RT ..
    spoke with a friend (working in a metall-company) ..and he thinks its no problem to make a new adapter-plate for the handlebars/ key-holder .. where I can fix a standard "tube" .. or adjustable bars like this here .. will be a lot of work to protect all this cables .. but maybe someone here has any other ideas ( a sponsor?)
    Active Member fencepost's Avatar
    Apr 2010
    Thorn Hill, TN
    When Harry at Heli first saw the RT he thought that he might make an adjustable handlebar for the RT. I spoke with his shop about a month ago and was told that at this time adjustable bars for the RT are not in the plan.
    Apr 2010
    Thorn Hill, TN
    BTW I have a set of Horizon Handlebars on my 06 Streetglide. It is by far the best handlebar setup made.
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    I read an a product evalution in October Rider Magazine on the Horizon ST bars, for a Concours, interesting. I think the biggest problem would be extending the wiring for the extra height and pullback.
    john
    Jan 2009
    austria
    needed some time .. BUT if they do not fit on an ST - why should I change ??
    (and a pair of the new 15" wheels of the RS..)
    Aug 2007
    Springfield, MO
    Quote Originally Posted by chris56 View Post
    I'm sure they will "fit" but there may be some cosmetic reasons they are not offered for the ST now.
    Why should you change?, maybe you shouldn't but from the ground up the whole Spyder lineup as been changed and I hope soon I can share some of those changes with you, if not your dealer has that info available to him now if he knows where to look.
    Jan 2009
    austria
    the news need a while till the reach the alps in europe ..
    I'm liking the fact that the picture says, "2013 and prior..."
    Very Active Member stevedfive's Avatar
    Aug 2010
    Riverside, California
    That's for the adjustable lower wings.
    2014 Timeless Black RTS/SE - BRP CB/Comm System; BRP Zumo 660 GPS System; BRP Cellphone Interface; BRP ST-1 Helmets w/BRP Headsets; BRP XM Radio; BRP Tri-Axis Handlebars; BRP Adj Wind Deflectors; BRP Adj Vent Windshield; BRP Comfort Seat & Utopia Backrest; Corbin Armrests; HMT Brake Light; TricLED 3/4 Brake & Running Lights; TricLED Fender Lights & Rr Cargo Lights; CD Fender TIPS Kit; Bump Skid; Scorpio i900 Alarm; Touratech GPS Locking Mount; NBV Highway Mounts; BBP Brake Pedal, Stebel horn.
    Aug 2007
    Springfield, MO
    Quote Originally Posted by stevedfive View Post
    And handlebars
    Aug 2010
    Ok, my bad. I thought the pic he was referring to was of the adjustable wings ($149.99 Clear and $189.99 Chrome)
    Invalid Emails
    Dec 2008
    Mexico City, Mexico
    Default Extending wiring
    Be very crefull when making the multiconductor cables longer. I did that on my SE5 and all went well as the first 2 cables' wires were color coded. So when I went to do the third cable extension I just cut it in half knowing thinking there would be separate wire colors. But this wasn't so. I found two black colored wires and three blue colored wires. There was no way to tell which went where. I took it to the shop and they had 3 different drawings showing different colored wires. I ended having to buy a new control with its plug and then one by one I made the extensions. Your solution would be to NOT to cut the cable in half but rather attack one wire (conductor) at a time as the color coding might not exist. Arthur---Mexico City
    Quote Originally Posted by retread View Post
    john
