Results 1 to 6 of 6
Thread: chassis ground
    Active Member johnwinslow's Avatar
    Jul 2011
    Waterboro, Maine
    Default chassis ground
    today i installed a Battery tender pigtail on my 2011 rts, what i found is disturbing!!! the nut and bolt that holds the ground to the frame was a jury rig at best. there is a threaded boss on the frame but the thread size accommodates a bolt larger than the holes in the ground lugs, so they used a nut and bolt a couple of sizes smaller, a spacer, and placed it through the frame. so when i finally got the bolt out the nut fell out to never never land. the proper way to attach the ground would be to put the proper lugs on the ground straps and the right size bolt. i have seen other posts from riders that said they could not tighten the ground. may be this is not from the factory, but the size of the ground lugs would say it was.
    Mar 2008
    Allegan, MI
    All the Spyders are built this way. You should never use the negative jumper terminal connection to attach a ground wire...and you should never loosen it! It would be good if BRP put a warning tag there. You are not the first to discover this.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by Rattigan_Roger View Post
    or they could retool and make a refinement that actually matters
    Mar 2008
    Allegan, MI
    I suppose a warning tag might read something like "Warning this cheap and almost inaccessible nut should not be loosened or even checked for tightness."
    or they could retool and make a refinement that actually matters.
    I like it. It's a bit wordy for that small space, however.
    -Scotty
    Registered Users JCSMOKE's Avatar
    Sep 2011
    Johnson creek. Wi
    I also found never never land in my spyder, or at least my favorite #30 torx bit did.
    Corbin saddle
    spyderpops block off plate, bump skid, belt guard
    IPS
    Tricled LED lights all around(too many to name here)
    Smoothspyder belt tensioner
    Custom Dynamics britesides
    VTC floorboards, upper air vents, spoiler
    BK car stuff HID upgrade
    trailer hitch
    Repainted rear fender, trunk latch assembly, switch cluster, gauge cluster
    cell phone interface kit
    travel cover that no longer fits due to the spoiler
    New sway bar
    New shock relocator
    Jun 2011
    Near Lexington, NC
    I had the same problem but finally got the nut & bolt tightened back up. I found it easier to drill a small hole in the main frame and attach the pigtail ground there, than to try to get at the battery ground.
