Results 1 to 15 of 15
    SouthEast Mo.
    Default Larger Brake Pedal *Solved*
    I would like a larger foot brake pedal. Has any one modded theirs, or know of a mod for it?
    Have trouble finding it sometimes, and I think a larger pedal would solve this.. Maybe a large pedal from a vtx??
    Aug 2009
    Granbury, TX
    My wife felt the same way. I had a stock rear passenger footpeg laying around, so I unbolted the brake pedal, got a longer bolt and bolted on the passenger peg. She loves it!
    SouthEast Mo.
    Quote Originally Posted by Texmac1011 View Post
    Mine must be different... has 2 small bolts that that screw in from under the pedal to the pad...
    I have bought a kuryakyn longhorn #8044 pedal cover and going to see if i can make it work.
    Will see.....i'll let ya'll know if successful.
    Registered User
    Dec 2007
    Schenectady NY
    We offer a billet Spyder brake pedal for the RS models in a standard and extended lenght.
    You can find them here http://www.esicycleproducts.com/spyd...dalcovers.html
    MM
    Is there anything available for the RTs?
    SouthEast Mo.
    Default Brake pedal solved
    I found a solution for a larger pedal pad. I bought a Kuryakyn Longhorn pedal pad# 8044. I had to modify the square end to fit flush ( grinded the end to fit the spyder's brake pedal ). The mounting bolt matched up with an existing hole, so no drilling was needed.
    Here's a pic of it mounted.
    I'll post a pic of the stock pad vs the longhorn tomorrow.
    SouthEast Mo.
    Default bump
    Bump it up
    Very Active Member cyclelover63's Avatar
    Mar 2011
    Big Sandy, TN
    Quote Originally Posted by Magic Man View Post
    MM
    Are these for the parking brake or the foot brake,and what is the length of the extended ones?..thanks!
    Jun 2013
    South Berwick, Maine
    yes is there P L E A S E?? It is just too short!!!
    Jun 2013
    You would think that the BRAKE pedal would be IMPORTANT and not all of us have tiny feet?!?!? I have to almost turn my foot inward to get to it.. I'm on an RTS It is supposed to be for touring.... not quite set up for it... ie needs larger gas tank and cup holder ROFL!!! I do need a longer brake pedal though ... any suggestions?
    Aug 2010
    Riverside, California
    May 2009
    Connecticut
    I don,t want a wider brake pedal for my GS BUT because of the Sport leg angle I would like one 2 inches farther forward so I could get an improved leg angle and Leverage in an emergency stop?
    Sea Doo GTI-SE 90 Jet Ski!!
    Mar 2011
    Big Sandy, TN
    I have a hinged brake lever from ISCI..part ##SPY-HB-FB-BL for sale.....the description says it locates the brake pedal 3 1/2" forward...the pedal part hinges upwards so you don't get your foot caught underneath it,in case you have floorboards..$160.00 shipped and I have Paypal....http://www.isciride.com/iscirsautoparts.htm#brakelevers...this the ISCI link..
    Mar 2010
    SD
    For you RT folks looking for a wider pedal, I just talked to the ISCI folks. They are out of stock right now, but should have more extended brake pedals in about 2 1/2 weeks - about 1 1/2" wider than the OEM.
    Quote Originally Posted by Charley711 View Post
    Does this pedal look as if it might fit the bill? It's from TricLEDS...
