Check your front sprocket for spline wear and looseness. Was it retensioned and retorqued at 6K, as specified in the service bulletin? Also check rear wheel/sprocket bearings. Give the belt teeth a good inspection, too. Vibration in a certain rpm range is not uncommon, but sudden development of a vibration is an indicator of problems. If you can't figure it out, see your dealer.
