Page 1 of 2 12 LastLast
Results 1 to 25 of 28
    Aug 2007
    Springfield, MO
    Default Warning about the new Fox shocks
    This is the official statement from BRP. You could say the same for any aftermarket shock that is changed out on your RS/GS or RT. As you know I've not had an issue but I thought this is something you should know anyway.
    Invalid Emails
    Sep 2007
    Wayne, NJ
    Quote Originally Posted by Lamonster View Post
    Can the 2008-2010 be properly re-calibrated through a software update???
    Aug 2007
    Springfield, MO
    Quote Originally Posted by lightman02 View Post
    I think it's a lot more involved than that. It has to go though testing on those year models and have approval. I think this more of a legal thing than anything but as you know it hasn't stopped me from changing my shocks.
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    Any idea of price???
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    Invalid Emails
    Sep 2007
    Wayne, NJ
    Gotcha, I was just wondering.
    Very Active Member daveinva's Avatar
    Mar 2011
    Washington, D.C.
    Does this mean BRP dealers won't even install a pair on anything earlier than 2011s?
    Silver 2010 RS SE5: Triple Play, Taillight, Brightsides, Fender Tips, Easy Risers; Evo Sway Bar; Airhawk R & Beadrider; latch springs; Grab-On grips; Crampbuster; 24" Madstad smoke windshield & deflectors; N-R round bag & soft saddlebags; BRP handlebar bag; Throttlemeister; Spyderpops Missing Air Dam & Air Mgmt System; Rivco driver & passenger boards & pegs; ISCI parking brake extension; Ultimate Midrider Seat w/both backrests, Fox Racing Shocks, Yoshi R-77 exhaust and a whole lotta love!
    Very Active Member IWN2RYD's Avatar
    Apr 2010
    Puget Sound, WA.
    Wink
    This is just a CYA for BRP... I mean really... Who here has gone to their Dealer and had the Computer re-programmed after replacing their shocks to Elka's or heck even putting RT shocks on an RS?
    Very pleased to see the warning, but in all reality there should not be any alarm...
    BlUe SpYder RT-S SE5 #303I don't suffer from insanity; I enjoy every minute of it ... Proud Member of A.S.S. (Average Senile Spyderryder)
    Our 2010 RT-S Mods... *Warning* If you can read this, it is already too late and there is no known cure. You have Spydervirus.
    Feb 2009
    Ceresco, Michigan
    Part of replacing the front shocks for many of us was to shut the nanny up anyway--- don't need no stinkin' new calibraion!
    Invalid Emails
    Sep 2007
    Wayne, NJ
    Quote Originally Posted by Firefly View Post
    I just hope she doesn't start getting louder. That would be bad if it makes it more sensitive, however less sensitive would be nice.
    Aug 2007
    Springfield, MO
    Quote Originally Posted by IWN2RYD View Post
    There is no "re-programming" that can be done when you change shocks or for that matter tires that are not OEM. The VSS is calibrated to those tires and shocks and changing them changes the calibration. Like I said it hasn't stopped me from making changes but I'm doing it at my own risk.
    Quote Originally Posted by daveinva View Post
    I guess that depends on your dealer. Most dealers like Cowtown don't have a problem with it.
    Nope but you have a part number now for the kit so make a phone call and let us know.
    Very Active Member Raptor's Avatar
    Jun 2010
    S.F. Bay Area
    Well, they look pretty good. At least they are offering an alternative, even though they say only for 2011-2012 models. Since the physical platform is the same and I am guessing they are using the same ECU type there is no reason why my ECU couldn't be flashed to match the 2011/2012 ECU. To my knowlege the new RS machines have no new sensors added above and beyond what the rest of us have.
    But I agree with Dan that no recalibration would be needed anyway. As long as it keeps body roll in check and provides good ride feel and damping (which equates to keeping Ms. Nanny less active) I'd have no problem putting them on 14. After all, the RT shocks are not gong to last forever and the 2010 RT shocks won't be available any more when mine do wear out. Just gotta see what these babies cost...
    "Life must be understood backward. But it must be lived forward."
    '09 Phantom GS (#14) (Gone but not forgotten) and 2010 RS-S
    Apr 2010
    Puget Sound, WA.
    Smile
    Sorry Lamonster... I should have mentioned that. I did not mean to imply there was one... I was just highlighting that no one has and we cannot if we wanted to... I just took a different route...
    Invalid Emails
    Sep 2007
    Wayne, NJ
    Quote Originally Posted by Raptor View Post
    Actually the VSS is controled by the antilock brake system which is part of the Bosch system and not the ECM. The Bosch module is not able to be directly updated by BUDS such as the other modules are. I believe this is why it's only 2011/2012 as they must be using newer software in the antilock brake controller for 2011/2012.
    Jun 2010
    S.F. Bay Area
    D'OH! Yer right about that. It says VSS right on the post! My bad...
    Aug 2007
    Greeneville, TN
    Anything that changes suspension or traction will, in effect, lie to the Nanny.
    Like the performance sway bar. The Nanny has lean angle as one of her parameters. The sway bar makes the Spyder corner with much less lean for the same centrifugal force. So the Nanny will hold off longer thinking that less lean means less danger of losing control.
    Add performance shocks and higher traction tires and you compound this effect.
    Since changing the shocks and sway bar, I have noticed the Nanny waits longer to jump on me when I'm riding hard. And when she does come in it is more abrupt and forceful. You can only fool her to a point. When she discovers what you are really doing she feels the need to be more agressive.
    It is a good idea to take it easy and explore the limits and get a feel for the new handling characterists of any suspension/traction mod before you ride it hard. You've changed things and you don't want to be surprised.
    You can go faster before you reach the point of losing control. But the break will come with less warning and be more abrupt than with the stock configuration. In other words, you have to pay more attention and you are more likely to exceed the limitations of the Nanny protecting you. Though I must say, she still does a very good job.
    When I was stock I could easily raise the inside tire. In a controlled turn the tire would come up gradually and predictably. It sometimes came up 5 or 6 inches but looked more dangerous that it actually was. I never felt like I was near any 'edge' of losing control.
    Now it is rare for me to raise a tire. I have to be cornering pretty hard. When it does come up it is only an inch or 2 at most and I feel much closer to 'the edge' of control. But more often, instead of raising the inside tire, I will actually drift all 3 tires (which never happened on good pavement with the stock setup).
    It's not much drift and it usually doesn't last long, (a second or two - like hitting a patch of sand). Then you have to be ready when the tires bite again because that can also get your attention. The rear usually breaks first and also hooks up first. That's the most intimidating part of this senario.
    Registered Users retiredsquid's Avatar
    Apr 2011
    Northwest Arkansas near Beaver Dam
    I don't know about other folks here, but installing Elka shocks has vastly improved my satisfaction level with the Spyder. The originally shocks were just too soft, even cranked up. I am sure my dealer's service tech with have something to say when he services it next time. If he wants to attempt to void my warranty over it, then we can take on the fight at that time, because I am not going to go back to stock. I live just off of Arkansas Highway 62 west of Eureka Springs and anyone familiar with the area knows the tight curves we have and Elka shocks made all the difference in the world for handling for me.
    So far I've never had the nanny scream at me.
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by retiredsquid View Post
    I can not imagine a senario where any warranty would be compromised by changing to Elka shocks. I do not think you'll have any issues there.
    Still, I had a dealer tell me my DPS unit was not working because I had installed an aftermarket cruise control uint. So you never know. That didn't fly, by the way, but it did take me by surprise.
    Very Active Member Dochands's Avatar
    Aug 2009
    Oklahoma
    Red face
    Quote: There is no "re-programming" that can be done when you change shocks or for that matter tires that are not OEM. The VSS is calibrated to those tires and shocks and changing them changes the calibration. Like I said it hasn't stopped me from making changes but I'm doing it at my own risk.
    We're Spyderlovers. That's cause we be livin on the edge.
    2022 RT Limited , Carbon black
    Jan 2009
    austria
    heard something that they use for the new RS - models now the "longer" rocker-arm of the RT ?? maybe thats the reason
    Active Member Just Doo Me's Avatar
    Aug 2008
    Millbrook,Ontario
    Default Fox shocks
    I did some research on these as a dealer came back to me telling of the same calibration issue if you didn't have a 11 or 12 model year,as stated in Lamonts post.BRP's online parts finder lists two part number's for 2010's on the stock shocks [early,late release].The spring numbers are the same.So some people with a later release 2010 may also be able to use them as it is the same number as the 2011.How you know if you have a early or late release is not known.
    Registered Users Campverdefela's Avatar
    Aug 2009
    Camp Verde, Az.
    Quote Originally Posted by Just Doo Me View Post
    How does this time travel thing work...an 08 in 04 signature.
    Hindle exhaust, Kewlmetal K&N intake + prefilter, Kuryakyn widow pegs, Kuryakyn grips, Madstad 20in. windshield, Juice Box, 02Modifier, Kewlmetal backrest and carrier, missing air dam, missing belt shield, 1" riser, Kewlmetal handlebar risers,Evoluzione sway bar, Street Magic/Day Runner Pucks, Glo Riders Amsoil, 10w40, Rons performance wires
    arntufun
    Guest
    Quote Originally Posted by Campverdefela View Post
    I didn't even notice that until you pointed it out !!!
    Feb 2009
    Ceresco, Michigan
    Spyders go much further than most knew......
    RT-S PE#783 VaughnCat's Avatar
    Mar 2010
    Illinois Valley in Southern Oregon
    Default Elkas -sway bar and picking up front wheels . . .
    Have both the Elkas and the performance sway bars on our RT and RS - I have managed to pick up a front wheel on the RT 3 times now at slower speeds with out the nanny kicking in. These were tight and off camber turns. Another Spyder pilot thought I was showing off (pulling out on to the highway from a driveway) . . . it has always been the left front that picks up, but I think that is because I tend to turn harder in that direction . . . any thoughts?
    Vaughn
    Spyder Cat's other half
    Passing thru Southern Oregon? Come ryde with us SOreSpyders@yahoo.com
    2010 RT-SE5 PE#783
    Mods: Corbin Custom Seat & passenger arm rests; Elka Shocks, RT622 trailer, and lots and lots of gas. . . . and did I mention, a new rear tire?
    2010 RS , custom home made billet Red/Black
    Oct 2007
    If you go here http://en-us.spyder.brp.com/home.aspx and go to build and price an RS they are shown as an option for 449.99 under custom accessories
