Tic Tic Tic Gone!
Left front was driving me nuts between brake squeals and tic noise at low speed.I pulled wheels and calipers took my brake CRC brake quiet put it all over the backing plate on the pads reinstalled .Now my squeals and tic tic tic are gone.
This may be a fun weekend project. How hard is it to get the fender off the front? I haven't looked yet but I was debating doing that with the brake quiet stuff.
+1
Did the disc brake quiet about 3K ago and I forget what the squeal sounded like! (just jinxed myself)
Originally Posted by GA-SPYDER
+1
I've had good results using the CRC, But riding though the slush and wet snow last winter i would have to apply it quite often, So i finally gave in and got the 3 gen pads,
No More squeal and no more CRC.
SpyderLovers Sponsor
I had the old pads and the CRC, all was quiet. Installed the Gen 3 pads with no CRC and have a little squeal sometimes at slow speeds, reverse sounds ugly.
What's CRC ????
Ride safe and often!
I have a 2011 RT LTD and get the occasional brake squeal only when backing up. Seems to be just the back wheel. Can the brake quieting spray be applied without removing anything and how often does it need to be applied?
MODS: Elka Shocks, ESI RT HMT Brake Light, ESI RT Brightsides, ESI Fender TIPS, ESI RIPS, ESI RT Day Runners, Grip Puppies
AmerSeal Sealant, KewlMetal Kewlock, Scorpio I900 Security System, Stebel Nautilus air horn, KewlMetal Highway Brackets & ISO Wings
Corbin seat, trunkrest & driver backrest, Capt.Jim's Belt Tensioner, SpyderPops LaBlock, Cat Shields, Bumpskid & Belt Guard
Seal PUP Floorboards, BRP chrome, Ron's Anti-Sway Bar, Lamonster LED Head/Fog Lights & BRP Air Scoops
Brake squeel
The CRC I use was in a squeeze bottle and was a orange color and applied to metal on the back of pad and it does not wash off.let it dry or get tacky after 15 minutes and reassemble. I did not have to remove fender.
No Tic Tic Tic!!!
Che57vy, did this CRC really get rid of the ticking from the front left wheel?! I have the same problem and it drives me crazy!!! Could you please give me a little detail in what exactly you did? I NEED to do this!! Thanks in advance.
BRAKE PAD HOW TO WITH PICS
could someone please do a how to with pics on rs gs brake pads? it would be very helpful to those of us who haven't messed with spyder brakes before. especially applying the crc goo. ,,,,,,,,,,,,,,thanks,,,,,,,,,,,,coz
it was fun while it lasted.
