It was 146 horse. And you need a new top end.... so yes, you need parts.
Actually, it depends on which Aprilia you're talking about, the Tuono has (had) around 130 hp, the RSV has (had) around 145 to 150. In either case, they'd be awful peaky for the Spyder, the torque comes in way up the rpm band, as does the hp.
If you want more useable power, it's going to be expensive, a jug and piston kit or a stroker kit, or both, could be made to work with the existing control module, and the torque could be made to come in at lower revs. All it comes down to is cubic money.
john
Looks like Evoluzione has changed a little, they had an engine kit to boost hp to 145. Some of their other spyder items have gone away, too. Maybe ebay or instock somewhere.
