Brake Squeak
Hi,
Any advice on how to quiet squeaking brakes ?
Only 550 miles on the bike...shouldn't be an issue with worn brake pads.
Thanks,
Ray
I've asked that question, and the common answer is "oh, Spyders do that."
Good luck!
Good luck!
jenmom, thanks for your feedback...I'll continue in search of the truth LOL
Ray
Check to see if you have the 3rd Generation pads. It solved the issue for me!
Old Spyder Mods:
No Magic Neon Triple Play II, Leo Vince SBK Exhaust, MMG Backrest, BRP Seat Skin, XOPRODOX Grips & Throttle Rocker, Paint By Tallant's Hot Rods, Kewl Metal Air Filter, Juice Box, Evoluzione O2 Mod, DEI Titanium Exhaust Wrap, Ride Wright Mojo Wheels and Pulley, Custom Handlebars, Relocated Ignition Switch, Madstad Robo Brackets, Evoluzione Swaybar, RT Shocks/Springs, Toyo R1R, Odyssey Battery, Lowered Shock Mount, SFB Floorboards, Fenderless w/ Custom License Bracket.
PhotoShop Master
Welcome to the world of the can am Spyder I'm on 3rd set of pads still squeaks 30000 miles ,,,, yes that is just what spyders do ... Been squeaking since 2008
THOSE WHO LIVE BY THE SWORD DIE BY THE SWORD... BUT...THOSE WHO MASTER THE SWORD SURVIVE BY THE SWORD....
Rev. J. Proctor
reverendproctor.com
HAPPY SPYDER OWNER
PhotoShop Master
I have 3rd gen pads ... There better but they still squeak
Rev. J. Proctor
reverendproctor.com
HAPPY SPYDER OWNER
Gen 3 pads and proper break in and no squeak.
DO NOT go with the EBC brand pads---horrible pads- wear fast
Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
3Rd gen pads, There your only fix, Without going with Rube Goldberg fixes.
The numbers are; front=219800164
Rear=219800165.
And mine were done warranty.
2014 Spyder RT Limited, Lees-sure Excell camper, Aluma MCTXL Trailer
If you think your pads squeak, you oughta try living on 2 miles of dirt road! Mine squeak, growl, etc., until I have put several miles on hard surface! Yep, I have a 2010 RT.
2008 GS SE5 in 2008
Traded at 43,000 miles for a left over
2010 RT SM5 in 2011
Traded at 57,000 for a left over
2014 RTS SE6 in 2015, which has 35,000 miles
Oct 19th, 2017, totaled 2014 RT while killing a Javaline
Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
Never had any breakdown stranded issues.
K
That makes me feel better!
My dealer had to replace the rear brake rotor and install Gen 3 pads and new mounting bolts to reduce the loud squeal. I had tried many other remedies but none kept the squeal away very long. The bolt problem that they found was that the bolts that hold the rear caliper in place had a groove worn in them so that pads were quite loose on the bolts and would vibrate. Now when the spyder sits for a few days while I am out of town for work the squeal is there when I back out of the garage. Once moving and after applying the brakes it does not squeal so I consider it almost solved. Before the replacement anytime I applied the brakes there was a loud screech from the rear.
I Hear ya! I do live 2 miles down a dirt road also. soon as that bike hits the gravel / dirt it starts squealin like a banshee. Ive finally just resorted to wipin my brake rotors down at 1st stop on rides. takes the squeal out for a short time.but it always comes back.
Thank you all !!
Now I have some leads to look into...I'll post the results once I get a chance to tinker with the pads/calipers.
Ray
K
I sense some sarcasm, LOL
I bought an '08 used recently with only 3000 miles. From the beginning, my brakes have been squeaking. But after reading the threads on this forum, it seems normal for spyder ryders to have squeaking brakes.
Tatt2r spring fix
Very Happy '08 Spyder RS Owner
Both our Spyders do it, especially if either machine sits for any length of time. I just clean the components off and it goes away. Just make it part of the pre-flight now before we take off as it's Pretty embarrassing not to mention annoying!
"Life must be understood backward. But it must be lived forward."
'09 Phantom GS (#14) (Gone but not forgotten) and 2010 RS-S
bake squeak
I just make a couple quick stops and it takes care of. Also forget to release parking brake sometime so do have squeak there
Originally Posted by jvicker
jvick,
Thanks for that link and thanks to all for your feedback.
Ray
I'm a member since 2009 and this is my first post. Constant reader and supporter.
Done 55000ks in NZ and this problem is surely one that BRP don't know how to fix economically. The truth is the rear pads do not release properly and continue to hold causing drag,heat and fuel costs. Check rear disk temp compared to fronts after a short ride. If someone can find a cure other than changing the caliper I'll be surpised and very very gratefull.
Cheers Yogi
I'm a member since 2008 and this is my first post. Constant reader and supporter.
Cheers Yogi
....and we're gonna ride, we're gonna ride.....
ride like the one-eyed Jack of Diamonds, with
the devil close behind,.....we're gonna ride....
2008 GS.....PE # 2888
spoke with a fellow rider the other day and he claims, if you attempt to do the rear/front pads yourself , the Spyder will throw a code and requires a trip to the dealer. Did not have the time to go in depth with this issue. Any body else have info or ideas on this ???? Thanks.
Thanks Guys Ive tried all the fixes on this page while they all work to some extent they do not overcome the real cause. The bloody caliper piston does not release properly. Embarising when travelling with Biker mates and you pull the "Old reverse out of the park" trick.
