What Mirror extensions do you recommend
I'm getting the 4" riser for my 2011 RS and I need the mirror extensions also. Can anyone recommend which ones to get and who sells them. ESI has them for around $139 are these the best ones or direct line parts for $79 whats the difference. Thanks CJ
Hand grips
GPS holder
Buttler mug holder
Running lights front and rear
12V plug in
Graphics
The difference is the $139.00 one go up and out where as the $79.00 ones just go straight out.
Registered User
....and the "up" makes all the differance in the world!
[URL="http://www.esicycleproducts.com/"]
ESI for sure. I had the "other" brand, which are fine by the way unless you add risers. Once you add risers you are back to no view again. The up should solve that issue nicely.
