Results 1 to 21 of 21
    Nov 2009
    Dallas, TX
    Default Rattle when letting off throttle
    2008 SE
    24k miles
    My Spyder has developed a rattling noise when I let off of the gas. I searched the forums and do not see anything similar. The mechanic at the dealer I use has no idea what could be causing it, and cannot discern where it originates. He put the machine up on a stand to allow the rear wheel to spin and simulate on the road travel. Roll on the throttle, everything is find. Let go and rattle, rattle, rattle. The cycle performs well. Good acceleration. Good shifting. Just this noise whenever I let off the gas. And no, I do not have a Hindle exhaust.
    Any ideas? I don't want him to tear everything apart without an idea of where to go with the exploratory surgery.
    Aug 2007
    Springfield, MO
    Your Harley buddies dropped a bolt in your pipe
    Just kidding but sure sounds like an exhaust issue like a loose baffle or something.
    Very Handy Member dltang's Avatar
    Sep 2007
    Grand Blanc, MI
    Sorry I don't have any answers for you but Lamont's sounds like the first place to look.
    With Christ all things are possible, so live life with no fears and no worries.
    Happy Ex Owner, Hopefully future Spyder owner again.
    Pastor Deb Tangen, Missions Director and short term missionary.
    Blazing Member fastfraser's Avatar
    Feb 2009
    Orangeville, Canada
    Man it sound to me like you need an RTS !
    Happy Owner
    Motorbike Professor
    Mar 2008
    Allegan, MI
    First place I'd look is at the muffler. Loose baffle or loose heat shield would be a common cause.
    Dec 2010
    Fountain Inn,SC
    Quote Originally Posted by NancysToy View Post
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by kenalmond View Post
    2008 SE
    24k miles
    Like previously said sounds like the muffler.
    Another [slight] possibly Sometimes when you take a lode off a bad wheel bearing [off throttle] you can get a rattling like sound.
    Nov 2009
    Dallas, TX
    Default I don't think it's the muffler
    I should add that the situation has been getting worse.
    Check transmission message, limp home mode, towed once to dealer #2
    Dealer #2 blamed shop at Dealer #1
    Can AM had Dealer #1 reperform a bearing job
    Problem still exists, plus louder, more trans,mission and limp home faults
    Can Am won't tow, so I drive to dealer #3
    Check Transmission light comes on at low speed and gear, clears at high gear and speed - comes on 7 times on trip to Dealer #3
    Limp Home mode twice - Stop, cycle power, clear, continue
    Now, it has been 8 weeks, 3 dealers, and still no joy.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Your dealer should be able to find some fault codes in BUDS, with this history. If I were the dealer, I would suspect the GPS. As to the rattle, I agree with Lamont, the muffler is the first place to look.
    Jun 2010
    S.F. Bay Area
    I agree, it seems there are two issues at play here. Perhaps dealer #3 would have a stock can that he could borrow to put on your machine to either confirm or rule that out?
    The codes make me want to suspect the GPS as well, given some historical posts of similar symptoms. I hope that the third dealer is the charm for you.
    Invalid Emails
    Sep 2008
    Reidsville N.C.
    Default yes
    Have your tect check front drive pulley.
    Nov 2009
    Dallas, TX
    Quote Originally Posted by Raptor View Post
    I still don't think it's the muffler. Regardless, Update: No word from Service at BRP dot COM. No word from Carlo. 3rd dealer now says he is too busy and wants Can Am to send a tech to fix it. Crimeny! Jumping Jehosaphat! Whiskey Tango Foxtrot!
    Sep 2008
    Ajax, Ontario, Canada
    I had the exact same thing happen with it sounding like rattling metal. Turns out the original factory spec for belt tension was a little high causing excessive wear on the main drive shaft bearing. This obviously required a partial engine rebuild to replace it, all luckily done under warranty.
    2008 SE5 24000 km
    Very Active Member hawkiii's Avatar
    Apr 2008
    Northern California
    Default noticed this yesterday
    I just noticed this same rattle yesterday. The wife and I took a nice ride yesterday, before we left I ran to gas up and get some cash and heard a rattle that sounded like it was coming from right underneath me. I have dealt with the baffle rattle already and was able to have that fixed. This is coming from right underneath me and only when off the throttle.
    Now I am wondering if we should take the ride we have planned for today. We aren't going that far but we will be on a 2 lane Hwy known as "Blood Alley", not an ideal road to break down on. Little to no shoulder for most of the road. Only going about 30 miles. Would you go?
    Very Happy Spyder Guy
    The 2015 F3 has over 46,000 miles
    Have Spyder...Will Travel
    Dec 2008
    Syracuse, NY
    Quote Originally Posted by hawkiii View Post
    If that is going to be on your mind, I'd say don't go. When riding you don't want to think about breaking down; you need to concentrate on what you are doing.
    Apr 2008
    Northern California
    Once I decide I am going to ride, all else is out the window. We are going to go ahead with today's ride but off to the dealer we go to get this taken care of this week. Now that the weather is nice I have the itch to ride. Don't want her in the shop for an extended visit just when the perfect weather has arrived.
    Aug 2008
    St. Louis, Missouri
    Default Plus one.
    Quote Originally Posted by rleathen View Post
    2008 SE5 24000 km
    Also had Hindle exhaust heat shield rattling but that was easy enough to diagnose. Best of luck.
    Nov 2009
    Dallas, TX
    Default Problem Fixed
    Well, Can-Am found the problem. A spindle shaft in the engine. At higher rpm or under load it either centered (high rpm) or under load would engage fully. Solution - they are replacing the entire engine/drive package.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Glad they found the cause. Very glad they are replacing the engine. That's absolutely the best cure.
    Invalid Emails
    Aug 2010
    Waunakee
    Default Muffler Rattle
    My 2010 RTS with 15k on the clock developed a rattle this spring. My wife first noticed it when I pulled in the driveway. Something is rattling. From that point on I was more attentive to the rattle that seemed to be coming from the muffler. It was not there at all upon startup. The engine had to get to a normal operating temp for it to develop. It got to be embarrassing at stop lights. I could not hear it going down the road. I took my Spyder to my dealer for them to listen. My service guys had no doubt it was a loose baffle in the muffler. They ordered a new muffler with some reluctance, I feel, from BRP. They claim they have not heard of this before. But send a new muffler they did; if you can believe $1700 for a muffler! I now have a new muffler that looks like the old one, but much cleaner. More important, no rattle.
    western Colorado
    Possable cause- the spyder dropping out of warp speed CLANK. Happens to me often! Jk
