Thanks Thanks:  0
Likes Likes:  0
Results 1 to 20 of 20
    Jan 2010
    usa
    Default Pakit Rak and the RTS
    Well, I have never been a big fan of trailers, but I do like the extra room so I have always used a pakit rak on my wings, vision, and now on my RTS. I bought the BRP hitch, removed the ball, and had a receiver welded to the hitch and ta da.. Now have my pakit rak working on the RTS. It was a good day....lol
    Willy
    When the going gets tough...Downshift..
    Very Active Member clueless's Avatar
    Jul 2010
    Pittsburgh, PA
    i am guess this is the thing he is talking about
    http://www.pakitrak.com/index.php?di...w&product_id=6
    RT-S PE#0391 SilverSurfer's Avatar
    Dec 2009
    Halethorpe, Maryland
    Default Okay ... But ...
    Indeed, this sure beats the price of a $4K trailer, but then what does it do to the rear-end stability of the Spyder? Does it conceal your tail lights/turn signals?
    I went to the site and it was the same picture... on the back of a Wing. Then I saw a link to "Honda Trike." I clicked it. It brought up a picture of a Harley Tri-Glide. So the company doesn't know the difference between a Honda and a Harley? That said, I'm concerned the height of this thing would block (at least mostly) visibility to the RT's tail lights and turn signals for followers at "bike height" and lower-riding cars.
    Ya gotta post some pictures of it ... not on a Wing ... but on a Spyder RT, bro.
    ~ Surfer
    Jan 2010
    usa
    Sorry, I forgot the pictures. I am not an engeneer....(LOL) but I have used this rack since 2004 on several bikes. No problems with handling and it does not block the tail lights or blinkers (or would not have used it). I am sure this is not for all but it works very well for me. The BRP hitch is rated at 35 lbs and the packit rack is rated for the same so weight is not an issue. The second picture was taken from the rear on my knees with a slight slope to the driveway.
    Attachment 11695
    Attachment 11694
    Willy
    Active Member REDSPY's Avatar
    Jan 2011
    Alexandria, VA & Southport, NC
    Can you post a picture of how you modified the hitch. I'm planning on doing the same thing with my pakit Rak whenever my Red RTS SE5 arrives.
    Jan 2010
    usa
    Sure, I will take a picture. But in the mean time, I had the adapter from the Pakit Rak folks for the Goldwing and the Bushtech vertical mount. I removed the ball from the BRP hitch and had my local trailer company weld the the adapter right on the top of the hitch where the ball would be.
    Willy
    Jan 2010
    usa
    I am sure this has been discussed many times, but.... What is the best way to remove the hitch when not in use as I am not fond of the way it looks with nothing on it. Does one take it completely off or just remove the 4 bolts holding the rear of the hitch to the section that mounts to the Spyder?
    Thanks
    Willy
    Senior Member Sunshyn's Avatar
    Mar 2011
    Navarre, FL
    Default A Question about the hitch
    Will the hitch that BillyTheKid is talking about fit on a 2008 SE 5? Seeing the photos of his modified Pack It configuration, I thought about racks that are commonly seen on the backs of automobiles with coolers and other things on them. If one knew a good welder, a rack could be made to any specification. I know a fella up in TN who makes all kinds of things for people, needing only a drawing with measurements. Not worth driving 400+ from FL to TN.
    Mar 2011
    Navarre, FL
    Default Photo
    Love that "...without pichers" photo!
    Senior Member Dragonrider's Avatar
    Feb 2009
    Canby, OR
    !!!! There are a number of terrific trailers on E-bay for under $2K, delivered to your home. I couldn't justify BRP's price, given the number of annual uses.. JMHO
    2014 RT SE6 Rider
    X - Honda Rider
    X - RT S driver
    X - RS driver
    Lifetime VFW Member
    Mar 2011
    Navarre, FL
    If I can use this PAKIT RAK on my 2008 SE 5, and when I am comfortable driving highway speeds, I definitely see an overnight or longer ride in the future. Does anyone know if my 2008 will accept the hitch mentioned in earlier posts?
    Jan 2010
    usa
    I don't know, but when I called the dealer to see if they had one to touch, they asked me if I had an RS or and RT.
    Here is something I found on the site... read down a bit to NancysToy response. Since you wouldn't actually be towing a trailer, and it is an 08 the warranty stuff might not be relevant.
    http://www.spyderlovers.com/forums/s...ad.php?t=25223
    Willy
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    not mine but this was pretty cool, from Inspector Gadget.
    Jan 2010
    usa
    Here are the pictures of the hitch that were requested.
    Willy
    Jan 2011
    Looks good, This is a great idea as I already have the PackitRak as well from my Goldwing.
    Very Active Member IWN2RYD's Avatar
    Apr 2010
    Puget Sound, WA.
    Wink
    Quote Originally Posted by billythekidd View Post
    Attachment 11695
    Attachment 11694
    Willy
    That is brilliant. Time to order a hitch...
    BlUe SpYder RT-S SE5 #303I don't suffer from insanity; I enjoy every minute of it ... Proud Member of A.S.S. (Average Senile Spyderryder)
    Our 2010 RT-S Mods... *Warning* If you can read this, it is already to late and there is no known cure. You have Spydervirus.
    RT-S PE#0032 2Gunns's Avatar
    Oct 2009
    North Carolina Sandhills
    With this mod....could you then use a receiver hitch w/ball when pulling a trailer?
    Spyder Bytes: Kury ISO Grips, GL1500 Windshield Vent w/ accent, Heel-Toe Shifter(inspectorgadget), HMT Brake Light, 12v outlet in frunk, GPS-Phone mount w/ case(techmounts.com), seat seal, Right Side Grill Covers(customdynamics.com), Fan Can10(ISCIrides.com), CAT Shields(SpyderPops.com), Elka Shocks, PressurePro TPMS, Cobra CB....and of course Cup Holders(mycupholders.com)
    Jan 2010
    usa
    Quote Originally Posted by 2Gunns View Post
    I guess you could providing you make sure the receiver attachment was rated to tow a trailer. The one in the pictures is NOT. It is made specifically for the Pakit Rak.
    willy
    Dec 2009
    Canada
    Default Rivco 11"Hitch Rack
    This is an alternative to the Pakit Rack. The receiver mounts beneath the trailer hitch ball and the rack slips in and out easily when needed. If we are just going on a short overnighter we attach the rack to the trailer hitch and strap an overnight bag to the rack. When we go on longer trips we bring the rack along in the trailer just in case we want to go somewhere and don't want to haul the trailer. I find the rack handy for carrying small stuff when we are out and about. Definitely not as awesome as a Pakit Rack, but it fits easily on our existing trailer hitch and does the job it was intended for.
    Mar 2016
    Cheyenne, Wyoming
    Default Sprung vs unsprung ?
    Willy
    Anything bolted to the Spyder trailer hitch would be unsprung weight. Sprung weight moves with the frame of the vehicle...nice and smooth. Unsprung rides with the suspension moving up and down when the rear axle moves up and down. It also would effect the handling and performance of your suspension. A very small amount of weight might not effect things much but it makes me wonder how safe it would be, especially hitting rough roads at hissy speed. Has anyone actually used anything like it?
    furthermore think about something projecting 2-3 feet behind you. At the original location of the hitch, the suspension moves up and down lets sat 2" on a bump. Projected movement 2-3 feet back could be 8-10" up and down. That 40 pounds just became 80 pounds of downward force. Not good.
    Two-lane blacktop isn't a highway it's an attitude. ~Author Unknown
