Results 1 to 6 of 6
Thread: toyo t1r
    Invalid Emails
    Jun 2009
    birmingham,al
    Default toyo t1r
    where can i order this tire
    Quote Originally Posted by bun-1 View Post
    I believe this beloved tire is history.... Fortunatly, there are good alternatives.
    But I'd say there may be some left somewhere. Finding it? That may be a challange.
    MOgang Member xpeschon's Avatar
    Mar 2009
    Waynesville MO
    spydee owner
    Guest
    Cool tires
    look here
    http://www.falkentire.com/Tires/Ziex-ZE-912-2
    falken has two tires that should fit the requirements for the rear of the spyder-both rs and rt 225 50 15. This tire lists for about $90.00 in canada.... so us should be not a bad deal either. This tire is also a high performance tire.
    Quote Originally Posted by xpeschon View Post
    That is a pretty good find if they actually have them. I may check that out. I'm going to need a new tire for the G&G ride.
    Recently, I've found several Internet sites that leave Out of Stock / Discontinued products up and showing as 'In Stock'. And actually they've been out of the product for a long time.
    They use the listing to get you to purchase. Then they email you with a special deal on what they actually have in stock.
    I'm finding this a lot with Arai helmets and some other products as well.
    Registered Users venom's Avatar
    Aug 2009
    quebec
    did you try tirerack.com
