Motorbike Professor
Looks similar, if not identical, to the ones on the 2010 RT-SE machines. I wonder if this dampened unit will help with the sprocket/spline damage issue? It may even isolate some belt harmonics. Let us know what you think.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Blazing Member
Is it me or does the belt look upside down ?
Those are not the drive ribs. They are the little cooling ribs on the outer surface.
States We Have Been To On Our Spyder
My mods: Green filter, Air box mod., Muzzy exhaust, Cat Bypass, Exhaust Heat Wraped, Powder coated all Bare Metal surfaces, Capt. Jim`s Belt Tensioner, Custom Built Highway Pegs, Elka front shocks, RS-S rear shock, 2011 smaller windshield, Dynojet PowercommanderV & Autotune, NGK iridiom DCPR9IEX spark plugs, Maxxis MA-Z4S Victra rear tire, General Altimax HP 185/60R14 front tires, Corbin seat & backrest, BRP hitch. I need to stop!
SpyderLovers Sponsor
Interesting, I was noticing that on Lamont's RT the other day. It has to be a vibration dampener. Could also work as a flywheel, though a bit late in the power train for that.
Should smooth things out some.
Will it fit the others years also.
I can confirm these "Look" the same on my 2011 RS-S and our old 2010 RT-S...
BlUe SpYder RT-S SE5 #303I don't suffer from insanity; I enjoy every minute of it ... Proud Member of A.S.S. ( Average Senile Spyderryder)
Our 2010 RT-S Mods... *Warning* If you can read this, it is already too late and there is no known cure. You have Spydervirus.
A better mousetrap Maybe???? Will it fit Older Units??
Sea Doo GTI-SE 90 Jet Ski!!
Senile Member
Originally Posted by jedd
Will the pulley retrofit??
Jim
My thought exactly.
Silver SM5 PE# 1274, Hindle Exhaust, Touring Windshield, Caliper Trim, B.E.S.T. 3 Year Ext, Nuvi 255 GPS, Fog Lights, Sport Rack, Back Rest, 12V Outlet, Talon 3300p Alarm, NMN Mud Flap and TipZ LEDs, SpyderLovers Emblems, Kuryakyn Widow Pegs and Axel Trim, Luimoto seat skin, Evo Air Filter and O2 Mod, Cranker Tank Bag, Blue Sea fuse block, MAD/AMS/MBG, Oddyssey battery, IPS.
Service Bulletin Applied: Gen II parking brake, 2nd SW patch, evap can/hose update, Gen II DPS
Happy Spyder Owner
Very interesting indeed. Wouldn't it be really cool if the new front sprocket that is being put on my Spyder is this one. I highly doubt that is the case, but it would be nice if it can be retrofitted to the older models.
Happy Spyder Owner
Shown as two parts:
#705501201-28 Teeth Sprocket $100.99
#705501250-Flywheel $76.99
09 SM5 Phantom
Originally Posted by Batmobile
Shown as two parts:
Sayeth Wiki:
"A flywheel is a mechanical device with a significant moment of inertia used as a storage device for rotational energy. Flywheels resist changes in their rotational speed, which helps steady the rotation of the shaft when a fluctuating torque is exerted on it by its power source such as a piston-based (reciprocating) engine" (or a heavy Throttle hand! )
If this could fit our older RS machines it would be very promising...
"Life must be understood backward. But it must be lived forward."
'09 Phantom GS (#14) (Gone but not forgotten) and 2010 RS-S
For sure would be cool if they put that one on, we still have yet to hear on a retrofit, I can only assume it will can't believe they would change output shaft, redesigned pulley should go on but I want confirmation before I order one. Please let us know if anyone gets a definite answer
Jim
My Spyder is still in the shop. I talked to them again today, and asked them if while talking to BRP they could find out if the new 2011 sprocket can be retrofitted. Not sure if they will ask or not, but I am hoping they will find something out for us. Best I can do is try.
Originally Posted by Raptor
Sayeth Wiki:
"A flywheel is a mechanical device with a significant moment of inertia used as a storage device for rotational energy. Flywheels resist changes in their rotational speed, which helps steady the rotation of the shaft when a fluctuating torque is exerted on it by its power source such as a piston-based ( reciprocating) engine" (or a heavy Throttle hand! )
What's a heavy throttle hand?
Looking at the RT and RS part #'s, there was a changeup but both models use the same shafts so should be good to go:
2010 RT sm5
420620612 Main Shaft. Serial number lower than 8458089
420620616 Main Shaft. Serial number 8458090 and up
2011 RT sm5
2010 RS sm5
2011 RS sm5
420620612 Main Shaft. Serial number lower than 8454845
420620616 Main Shaft. Serial number 8454846 and up
Registered User
2010 RT sm5
2011 RT sm5
2010 RS sm5
2011 RS sm5
This part of the equation looks good!
Shown as two parts:
Something interesting here; for the 2009-2010 sprockets we have a P/N of 7505500744 at a price of $61.41. The 2011 sprocket is 40 bucks more. Why? Is there more to this front sprocket other than a different casting to fit the flywheel or are there other factors such as material compostion? Is it a bit beefier than the 2009-2010 sprocket? Enquiring minds want to know!
2013 "Silver Dream" GG Taurus
2008 "Silver Dream" Spyder RS
Einstein's theory of drag racing: Time and Speed are Relative.
Shut up and Race!
2010 RT sm5
2011 RT sm5
2010 RS sm5
2011 RS sm5
I will have to look at mine. What if my RT does not have this upgraded sprocket ?? Will BRP give it to me or let me replace it later when something goes wrong?
I just checked my 2010 RT and I do not have the new updated Sprocket. Will BRP change it or give me and others a recall ??????
Motorbike Professor
Normally, a design change is not covered as a warranty item. If you want the new sprocket/damper, I suspect you will have to pay for it.
-Scotty
