Definitely need a pic of the finished product after all you had to go through to get it installed.
I failed to mention... I do not have the tail pieces mounted yet because I plan to find the final mounting position of the luggage first. I do not want to "Assume" how far forward or backward I need to have the back pad for passenger...
All this means is the final product does look very nice and clean with the back cover on it...
That is an interesting rack. I hadn't looked at it before now. Please post pics after you have the luggage on it, and it is all buttoned up.
Versatility is why I opted for this over the sport rack. This may be one of the best mods Kewlmetal produces.
A flat surface to set things like drinks on, holes in the side that are great for bungie cord hooks, a variety of top plates available that fit into pre-drilled holes. The backrest is simple to install (2 screws) and fully adjustable. The channel (what seems to require the hammer to install) actually becomes part of the frame. Their website shows a guy standing on the installed product. Try that on a sports rack. Also you can take off the luggage rack, leave the channel in place and put the OEM tail piece back on with ease.
The sports rack is very nice and color coordinated, just not as many features as this one.
Those are very good points, and I would probably go this route as well if I didn't already have the BRP one. You are also right, there is no way I would ever think of trying to stand on mine.
