Results 1 to 14 of 14
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    Default making oil change cleaner ... 1330 RT
    I am due for an oil change on my 2015 RT. Last time, even after watching Smoak's videos, there was a mess with oil tracking onto the plastic panels underneath. I used my J&S jack with spyder adapter as well as the oil diversion pan. Before I started the change, I trimmed the openings that the draining oil is SUPPOSED to drain thru. I marked some painters tape after determining there was no danger of damaging anything under the panels. A dremel with a small cutting wheel did the job. I "cleaned" the trim job up with a ting sanding disc and it is all done. Oil ended on the drain diversion and into the drain pan. I could catch both drains with one pan!! I did find one wrapped electrical cable underneath the trans side but luckily didn't hit it.
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Very Active Member JimVonBaden's Avatar
    NoVA
    Any reason not to use a fumoto valve in there?
    http://www.fumotousa.com/
    I have one in my Mercedes and had one in my Saturn Sky Redline.
    Jim
    2013 ST-S (wife's)
    2015 BMW R1200GS (mine)
    1981 Yamaha XS400 Scrambler Custom (mine)
    Default Welcome. ..
    Congrats...this is a quick and simple way to keep the oil draining straight out...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by JimVonBaden View Post
    Do you have one of these on your Spyder? What size did you get.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    NoVA
    No, but I am considering it.
    Jim
    2013 ST-S (wife's)
    Jun 2014
    Schenevus NY
    I've used Fumoto valves on my cars as well. General consensus here was that there isn't enough clearance under the bike for the valve. Although they do have a low clearance version that could work.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    NoVA
    Quote Originally Posted by Trbayth View Post
    Good info. I'll see when I do mine in the next couple of weeks. The bike only has 1600 miles on it, but is an 03 with an undocumented maintenance history, so I think I should just reset the clock on it.
    Jim
    2013 ST-S (wife's)
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    On my VTX I used this: https://www.stahlbus-us.com/oil-drai...qs8c8f1rqfheo1
    Now I'm waiting for sizes from stahlbus.
    2018 F3 Ltd. , Black/Dark
    Mar 2015
    forrest above Reno, Nv
    Thumbs up Done and done.
    Well I got the up on jack stands and a block. Easy to cut the plastic around the 2 plugs. I think it's a must do if you DIY oil changes.
    On the subject of the drains mentioned above----- if they arn't too long they would fit just OK. I've bottomed out at low speed (off road ). Glad there was a heavy duty bumpskid there. I'll stick with the hex replacements I put in last oil change
    Kaos
    2014 RTS , Circuit Yellow
    Sep 2016
    Lewiston , Maine USA
    Default J & S Jack with Spyder Adapter?
    If you don't mind, where would I find these & How do you find the "Balance Point?" Thanks
    Mar 2012
    Beaverton, Oregon
    Quote Originally Posted by Tomline View Post
    J & S Jacks.
    Call them for the adapter for your specific spyder!
    Sep 2016
    Default Cleaner oil change?
    Are you familier with 2012 RT with 998 engine? Any issue with these & the Spyder Pops bump steer? Thanks
    Active Member Richardv's Avatar
    Oct 2014
    Montreal north shore, QC
    Default What if.....
    ....we would use a 90 degree to install the valve horizontally....?
    Richard
    * 2012 RS SE5 (hers)
    * 2013 ST SM5 (mine)
    Daughter RSS SE5 2014
    Son in law RSS SM5 2013
    P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
    2 sets of Kumho 175/55R15 front tires
    1 set of Hankook V4
    1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
    Aug 2013
    Clovis Ca.
    Default Another way to drain oil
    I use a small plastic bottle that I cut on a miter and tape it to the bottom .
    This allows the oil to drain with out a mess...The bottle I used was a pool
    water sample bottle small enought no need to cut hole in the bottom...
