Page 2 of 2 FirstFirst 12
Results 26 to 45 of 45
Thread: fuel tank size
  1. #26
    Page 27 of operator's guide. It is not bright.
  2. #27
    Quote Originally Posted by Orange Spyder Man View Post
    does the 2014 RT have a LOW FUEL WARNING LIGHT ??????
    osm
    Yes. Mine usually kicks in around 210 miles on the tank--if I let it go that far.
    Registered Users paforonda587's Avatar
    Jun 2015
    US
    My 2015 RTS SE6 tank holds 6.9 gallons. my light comes on at 5.5 used leaving 1.4 in reserve. i tried it twice just to see.
    Sent from my SM-T530NU using Tapatalk
  4. #29
    5.5 gallons...
    I missed seeing it by .008 gallons!
    (5.492)
  5. #30
    Sep 2014
    erie, pa
    Quote Originally Posted by Hayfield View Post
    My Spyder is the first motorcycle I've ever had with a fuel gauge. Personally, I pay more attention to how many miles I've ridden. Recently, on my first long trip after the recall work, I rode quite a few miles after the low level light came on . . . I was with a large group and didn't want to make them all stop (lots of folks have the 1330 engine) . . . when we did stop, I'd averaged 31 MPG and only got 4.2 gallons in the tank.
    That fuel gauge is nothing more than a device that tells you your tank isn't full, anymore!
    Totally agree with you on that one. My '013 seldom shows full after a fill up and even when it does drops to 3/4 after a mile or so.
    Whereas my wifes '014 has a pretty accruate fuel guage.
  6. #31
    Active Member Buckeye Chuck 54's Avatar
    Jun 2015
    Zanesville Ohio
    Default My 2014 RT-S does
    I keep a log of all gas fill ups, miles and gallons used, price per gallon and total odometer miles. On June 7th this year the low fuel light came on at 212.6 miles. I filled when it had 257 and it held 6.319 gallons. It was a nervous last few miles. It's never held more than 5.8. I think from what I've read on this thread, I'll fill earlier. One interesting note, every time the low fuel light comes after 200 miles, it's always gotten 40+ mpg.
  7. #32
    Default NO RESERVE
    Quote Originally Posted by paforonda587 View Post
    There is no reserve on the Spyder gas tanks.......and because of the air pocket ( which is needed for expansion ) the tank will NEVER hold the listed amount. For some reason BRP lists the AIR POCKET as usable gas space but in reality you cannot get gas into that area .........Mike
  8. #33
    Quote Originally Posted by Buckeye Chuck 54 View Post
    I know what is happening.
    When you get down to where you're looking at the Low Fuel light; you are riding in a VERY careful and cautious manner...
  9. #34
    United States
    osm
    Yes, it does.
    I have put 5.6 gallons in mine before. Average about 32 miles per gallon. That was with the light on for about 15 miles.
  10. #35
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by Doc Humphreys View Post
    Yes, it does.
    That is not very good mileage. I average about 40 MPG with my 2014 RTL.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
  11. #36
    Hey, another OC guy like me! I track only to 2 decimal places though.
  12. #37
    Quote Originally Posted by jaherbst View Post
    Jack
    Jack, you have to be a lot lighter on the loud handle than I.
  13. #38
    It actually does, and I've found mine!
    It seems to light up once you reach the point where the tank will take a bit over 5.5 gallons...
    Since the 2015 post:
    I've stretched the tank to a 236.4 mile range, and it took 5.557 gallons: 42.5 mpg!
  14. #39
    Very Active Member HayRog's Avatar
    May 2013
    Sacrament0, CA
    Thanks :-) -- that's --- what I needed to know.
  15. #40
    Jun 2017
    Nashsua NH
    Cool
    Quote Originally Posted by bruiser View Post
    Most I've ever put in was 5.2 and that was with the light on. Usually when my RTS reads empty it'll take between 3.5 and 4 to fill it. My gauge starts bouncing after I use about a gallon. Still can't convince my dealer they need to replace it. Most mileage was 29. When I get close to empty I start looking for station.
    I have an RS and I get about the same. Just about when the fuel light is on and off, i fill up and it takes about 3.7 US Gal. I get about 120 miles on a tank right now putting that much in. i dont over top it off just because they can be known to drip into the evap canister and stink like fuel. I'll avoid that and fill up more often haha.
  16. #41
    May 2017
    TX
    Default fuel tank size
    I have a 2017 RTS SE6. The most fuel I have put in is 5.584 gallons. Had 183 miles on the tank at fill up.
    2017 RT-S , Pearl White
  17. #42
    Quote Originally Posted by HayRog View Post
    The low fuel warning light on mine also pops on when I reach the 5.5 gallon (nominally) amount of room in the tank.
    It repeats so accurately, that I now ride by the fuel gauge: not by the trip odometers!
  18. #43
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    Default Reserve capacity???
    Re my 2016 ST-S...
    The manual says "Fuel Capacity 6.6 gallons", but I was looking at the spec sheet on the BRP site yesterday and in addition, it lists "Reserve 1.0 gal".
    Is this an indication of approximately how much gas is left AFTER the low fuel warning light comes on?
    I have only had that happen once so far, after about 125 miles...and I was very nervous for the next 20-odd miles til the next depot.
    Thanks!
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
  19. #44
    osm
    Yes. The light usually goes on for me at about 200 miles or so. I always fill to the same level each time. Run it up to the inner ring, stop, let it settle for a couple of seconds, refill to the rim...DONE.
    The 1330's have somewhere around 6.8 US gallons. The most I have ever put in was 5.8.
    wisconsin
    osm
    YES! Mac
