Mod Monster
Phil's Mods
Reason: Mode list of all mods here - Updated
____________________________
Phil - Tyler Texas
2010 RT-Premiere Edition (Named DARTH) | Timeless Black | All My Mods--- ARE HERE | Phil. 4:4
Sounds like a great winter project list. I wish you the best in getting it all done, and being able to show it off.
Mod Monster
Upper Wind Deflector LEDs
I'm almost finished with all of the mods. The list grew a bit. Again, I'm not a paint or mechanical guy and I do work for a living, so... the mods are mainly electrical and done on weekends. I'm proud to say that in 5 weeks of work, I only blew 2 fuses!! Yea me!! And when I blew them, I knew exactly what I did and knew exactly which fuse to replace.
Descriptions below pics....
This is garage bay #3 where the fun takes place. I've set up the workbench (all from Sam's Club) so I have plenty of outlets and power supply for my netbook. You'll see my Brother label printer. I find putting tags on the wiring helps me remember what I did after the fact. One of the early things I did was to get a battery tender and so I don't kill the bike battery while I'm working on it, I keep the tender plugged into the 12v accessory outlet in the trunk. Works VERY well.
After I get things cleaned up, I'll be adding slat board plastic hanging system. I have it in the rest of the garage for our gardening tools and its great stuff.
Part of the LED mods I did included adding Purple LEDS behind the upper wind deflectors. An accent I've done over the years is to light glass or plastic from an edge. Depending on the material, it then looks like it is glowing on its edges. I've used purple 95% of the places. All of the accent lights are tied into a Street Magic remote (love it)
After I get it out on the street, I may add a purple lighting gel in front of the LEDs to mute them a bit. I need to see them in comparison to all the other lights. I'll have to go back a figure out where I found these particular thin LEDs.
More to come......
Phil - Tyler Texas
Certainly looks beautiful. I've often wondered how one could improve on the looks of a Timeless Black RT-S....but you sure hit the nail on the head, my friend. I'm jealous!!
RT Looking good. Love the garage too!
Mods
Nice looking mods, and great looking garage.
Nice man nice! Good to see a tricked out RT.
Mod Monster
Phil - Tyler Texas
RT-S PE#0412
Mod Monster
Bluetooth for the masses (ok... just my Spyder)
I spent HOURS researching this. I now know more about Bluetooth than I ever wanted to know. And I realize that I now know less than I thought I knew. This solution is about the only way I could figure out how to make this work. I AM interested in any other ways to make this happen!! I want to also give a HUGE thanks and deep appreciation here to all of those that have gone before. The pioneers like Lamonster, Scotty, Mark, others. You guys figured out lots on the RT and gave me the confidence that me, a software geek, might be able to do the mod thing. THANKS!!
My requirements were to be able to SIMULTANEOUSLY listen to the bike audio (I'll call it the FM), audio from my TomTom, listen for iPhone things like incoming TXTs and email, AND have intercom to my wife's helmet. I know... I'm in a 12 step program for being picky. I first tried to use the Bluetooth in each helmet as the connection point. Nope. It has to do with there being a Bluetooth priority order that is fixed and cannot be adjusted. My iPhone would always link to the helmets first when I really wanted the bike FM first. That meant seeking a different solution.
The helmet system I purchased several months ago was the SENA SMH10-
Some don't like it due to the size. I LIKE is because of its size. REALLY intuitive and easy to use 'jog wheel'. Anyway... back to the story.
I laid out this solution-
So I ordered all of the pieces, hoping it would work. I finally got the courage one day to open all the boxes and dig in. After several hours, I had this:
Big mess, but it was the experiment that worked. To make this work, I needed Bluetooth units that could be powered from the bike's 12v so I wouldn't have to keep charging, replacing batteries, etc. I also needed a mixer that would power the same way. The ONE item that I could not find (believe me I tried) was a Bluetooth TRANSMITTER working from 12v to take the mixer output and send it to the helmets. PLENTY of receivers, but only 2 transmitters. I already had the Sony guy, so Sony it is... for now. Here's the Transmitter:
I decided to mount the Bluetooth receivers under the seat:
I really thought a lot about this location for the receivers. The units are pretty well sealed so there's no issue being close to the tank. I wanted them somewhat accessible in case of needing to re-pair with another GPS, etc. They are held in place by Velcro, AND... my best friend- black Gaffer tape! Kinda like duct tape, but MUCH prettier and nicer to handle. REALLY strong stuff. It's used by audio guys to keep mic wires in place on floors, etc. I used it a lot for quick, easy ways to tack wires in place on the bike.
After lots of trial, here's the mounting I selected for the audio mixer:
The inputs are on the left, the volume controls (faders) in the middle, output on the top right and power mid-right. I drilled a 3/4" hole in the top of the side trunk to get all of the cables to and from the mixer. The hole leads to the relatively empty space near the battery. THAT's where the real cable mess is. I really tried to make it neat, but....
Costs-
Mixer- about $79
Bluetooth receivers- about $89 each
Bluetooth Sony transmitter- about $50
Fun designing it then seeing it work- priceless.
I still have SOME things that I'm not sure about but willing to live with. Like, if I get a call, I can't answer from the headset. No issues for me. I don't really take l-o-n-g trips on the bike and so this is not an issue. IF I need it, I can quickly pair the iPhone directly to the SENA unit. 95%+ of the time, I'm interested in music or my Sirius/XM app on my iPhone.
LOTS more details, but we'll stop here.
More pics of more mods to come!
Phil - Tyler Texas
SpyderLovers Founder
Mod Monster
Run Brake Turn Mod
To quote Sally Field when she won her Oscar-- "You love me... you really love me!" Thanks guys. Like I said, its humbling.
Ok... this really was a simple mod. It was billed as such, but trust me, once you've drilled a couple of holes, hoping you did them right, it's no big deal. What's the worst? Buy a new piece of tupperware! I really looked at a way to mount it higher on the trunk, but I really couldn't find a way to make it look right due to the curves. Here's the end result:
I love the look of the SOLID light, like a neon tube. It IS descrete LEDS, but they are packed tightly so it looks like one light. Some have written that they had issues with the curve of the light- it was 'peeling up' at the ends. When I opened the package I cound see that might be a problem. I didn't use a heat source, but I did set a toolbox on the very end and let most of the light hang off a work bench for several days then did the same on the opposite end. In the end, I did have one end that wanted to curve out. The answer for me was a very little bit of JB Weld. The kind that is like putty. It dried grey, so I broke out the Sharpie (aka black paint touch up tool) and here's that result. You have to know what to look for to notice it:
Coming up next- Cornering Lights
Phil - Tyler Texas
Mod Monster
Brighten the Corner Where You Are - Cornering Lights Mod
Old song I learned in Sunday School about 52 years ago
This is one that has been on my list the longest. The older I get, the more help I need to see at night. No real issues, just aging I guess. I wanted a way to light up where I was heading when I turned into a corner. I had this feature on a car I once had and I loved it. I looked into dozens of ways to do this. I walked around the bike 10 times one day, just studying how it might be done. Mounting on the front is the obvious place, so I looked at the not so obvious. I searched the web for the very brightest LED bulbs and fixtures I could find. I bought 1 and 3 watt Pond lights. Waterproof, but large-ish and hard to mount. On a whim, I ordered 'bling' DRL lights for cars. www.SuperBrightLEDs.com is one of my favorite sites. This is where I found the lights called DRL-CW5 Series. Here's where I mounted them:
I made sure the foot rests would fold up when tieing up the wiring. The BIG challenge was figuring out how to turn them on without having one more switch. I remembered a thing called TDR- Time Delay Relays. I found simple DIY circuits to build, but I wanted something more durable. Google found this guy:
I exchanged an email with Mr. Wolsten describing what I wanted to do and he pointed me to the 'P' model. Their website is full of creative, clear DIY type applications. http://www.wolstentech.com/. I mounted it in that 'cavern' behind the headlights. A SLIGHT adjustment in the delay timer, and it worked perfectly first crack. Press the right signal switch, normal turns begin to flash, that closes the TDR relay, lights the Cornering Light, TDR keeps it on between normal turn signal flashes. Cancel the turn signal and within 1 sec, the Cornering Light goes out. Taaaa Daaah! THESE puppies are bright too:
With a little ride time, I may want to aim them up or down a little. But one spin around the block (before the 5 degrees rolled in) tells me they're pretty close. Oh, there is one TDR for left, one for right. I mounted them back to back. You'll see from their web site that the electronics are 'potted' to make them robust. An 'interesting' sidelight... with the Double Play unit on the turn signals, plus the TDRs, it looks like a carnival ride when you press the 4-Way flashers! Once I can figure out about posting a video, I'll SHOW you!!
TDRs- about $30 each.
Lights- about $70 for the pair
More mods and more pics coming...
Phil - Tyler Texas
Mod Monster
Mod Monster
Phil's Mods
The pictures and comments are very informative. Alot of time and hard work went into this project. You need to train a tech and establish this as a business.
Regards,
Reese
Mod Monster
Regards,
Reese
HA! And give up the day job to do it?! Nope. That one is TOO much fun.
When it warms Reese, we'll meet at Heartland Ham and you can play with it! Thanks for the encouragement guys....
While I'm here, here's a pretty comprehnsive list of my mods:
Phils Spyder Mods
Additional front fuse panel
Mud Flap Lights
BrightSides front and rear
Kewlmetal Run-Turn-Brake light
Double Play Unit
12vdc dash convenience outlet
AEM Voltage Meter
TricLed TricFenderz - Amber / Red
Front DayRunners
RTGloRyder
Custom Various Stingerz LED sticks (Purple)
Black Magic Remote LED Control
DRL Cornering Lights with TDR control
Puddle Lights & switch
Master Accessory Power Switch & relay
LED Licenseplate light
LED Frunk Surround
LED Fendertip lights
LED Seatglow light
LED Trunk lights
LED Glove Box light
LED Under Dash light
Dimmers for Dash & TricFenderz lights
~~new 07/23/11~~
HID Headlights
LEDs under rear fender
Bluetooth Receivers
Bluetooth Transmitter
4 Channel Audio Mixer
Extra WAGO LeverNuts
Billet Axel Covers Front end Dressup Kit
Green Filter
Swaybar
Elka Shocks (7/2011)
Utopia Backrest (6/2011)
Fog HIDs
Gizmo Mount Bracket
Küryakyn Widow Pegs
BRP Chrome Mirror Accents
Reason: Added more mods
Phil - Tyler Texas
Phil's Mods
Saw Adam at Broadway today and he said they got a shipment of 2011 RT's in on Thursday. Sevice was assembling a unit this afternoon. Brought the Spyder home after having a steering sensor repaired.
Regards,
Reese
Mod Monster
Originally Posted by harddrive
Nice work Phil. . I may have to ride mine up there so we can put these mods on my RT...we have to keep you from getting board...
Come on up!! But I'm far from board . Now on to my big project... a 35,000 sqft green office building for our company, complete with all LED computer controlled lighting, motorized shades, uuber technology to save energy, geothermal wells, the works! But seriously, let Reese and I know if you're wanting to come and we'll host you.
Regards,
Reese
Saw a grey one driving by. I'll have to stop in.
Phil - Tyler Texas
Mod Monster
Man, I want to come to your house and play!!!
Mod Monster
Bring it on my brother!! We have plenty of room for guests.
Phil - Tyler Texas
