Thanks Thanks:  0
Likes Likes:  0
Results 1 to 16 of 16
    Senior Member pierrelogic's Avatar
    Apr 2010
    Central OHIO
    Default replacing spark plugs
    I'm well over 10 G's on the OEM spark plugs because well, the Spyder is running just fine. That and I'm a huge fan of if I don't think it's broke don't fix it. That thinking has served me well with the Spyder so far.
    I've seen other swap them out as early as a couple thousand miles...but no one has suggested a high end number before replacing the OEM's. I've got the Iridiums just waiting to be slapped in but everything is running so smooth. Can I do any damage if I don't change OEM plugs until either the Spyder starts choking or around 12,000 miles is that going to be an issue?
    Very Active Member Dudley's Avatar
    Dec 2008
    Jacumba, CA
    I changed my first plugs at over 26K and put in the iridiums. The OEM were barely worn. Could have probably gone another 20K.
    I am also a believer in if it ain't broke, don't "fix" it.
    2008 GS SE5 in 2008
    Traded at 43,000 miles for a left over
    2010 RT SM5 in 2011
    Traded at 57,000 for a left over
    2014 RTS SE6 in 2015, which has 35,000 miles
    Oct 19th, 2017, totaled 2014 RT while killing a Javaline
    Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
    Never had any breakdown stranded issues.
    Senior Member
    Katy, Texas
    OK I'll play. How labor intensive is replacing the spark plugs?
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by Rider Steve View Post
    The first time you change them, you'll wish you waited till you really needed to do it. Air box has to come out,
    6 hard to get at screws to remove the bottom of the air box, [and put back] And be careful puling the boots off the plugs, they damage easy. Oh year a couple of panels have to come off first. That said if you have a few hours and a lot of patience you can do it.
    SpyderLovers Sponsor groundeffect's Avatar
    Dec 2009
    Newfoundland, Canada
    Any tips or methods or told to use to safely getting the spark plug boots off?
    Very Active Member pjp623's Avatar
    May 2010
    Montgomery Center, Vermont
    Also, don't forget the heat sink paste!
    ".........regrets are only memories written across my brow, and there's nothing I can do about it now......" Wille Nelson
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by pjp623 View Post
    Dec 2009
    Radioshack / The Source part # 276-1372A
    cheers.
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by groundeffect View Post
    Carefully, there on tight [Suction?]
    Dec 2009
    Quote Originally Posted by boborgera View Post
    By hand though... right? Grab with fingers... ( when engine is cold of course )
    Very Active Member hawkiii's Avatar
    Apr 2008
    Northern California
    I have never pulled the airbox just to change plugs. Just need an extension and an elbow for your ratchet. IMHO.
    Very Happy Spyder Guy
    The GS had over 44,500 miles by March of 2015.
    The F3 is going strong
    Have Spyder...Will Travel
    Senior Member Campverdefela's Avatar
    Aug 2009
    Camp Verde, Az.
    I take a large flat head screwdriver under the lip of the boot while lifting around the boot with my fingers, do both slowly and gently, then when replacing put a little silicone grease on the plug insulator. I've never damaged a plug wire this way.
    Hindle exhaust, Kewlmetal K&N intake + prefilter, Kuryakyn widow pegs, Kuryakyn grips, Madstad 20in. windshield, Juice Box, 02Modifier, Kewlmetal backrest and carrier, missing air dam, missing belt shield, 1" riser, Kewlmetal handlebar risers,Evoluzione sway bar, Street Magic/Day Runner Pucks, Glo Riders Amsoil, 10w40, Rons performance wires
    Dec 2009
    Quote Originally Posted by hawkiii View Post
    The shop manual outlines exactly this method, indeed, no airbox removal required just a universal ratchet extension / elbow.
    Quote Originally Posted by Campverdefela View Post
    Thank you!
    Active Member Just Doo Me's Avatar
    Aug 2008
    Ontario
    Unfortunately the way the plugs are recessed into the cyl. you wont be able to get a screwdriver or fingers in to help lift around the plug cap and without removing the airbox you will spend more time trying to get the plug out then just removing the box.Just take your time and be careful when pulling the plug cap, is about all you can do.The back cyl. is a breeze the front is a lot more time consuming but not a big deal.
    Mar 2008
    Battle Creek, MI
    Quote Originally Posted by Just Doo Me View Post
    .......The back cyl. is a breeze the front is a lot more time consuming but not a big deal.
    That's easy for you RS owners to say...LOL!
    -Scotty
    2011 Spyder RTS-SM5 (mine) & 2008 Spyder GS-SM5-PE (Nancy's)
    2000 BMW R1100RTP, motorized tricycle & 22 vintage bikes
    Mutant Trikes Forever!
    Aug 2009
    Camp Verde, Az.
    Quote Originally Posted by NancysToy View Post
    Yes, I'm sure it is much easier in the RS and yes the air box has to come off to do what I suggested but I have no problems getting a long screwdriver and my fingers on the boots and gently prying the boots off and I'm not a small man. Of course it helps to have no air box as I have the Kewlmetal intake. Life is so much easier without that darn coffin on top.
