Originally Posted by canam9
Who here has changed there stock exhaust to some other slip on,
Hinde Exhaust ect? And what are your feeling about your change?
I have a Micron and I really like the deep throated sound. Many have said my Spyder sounds awesome
Video
In order to find his equal, an Irishman is forced to talk to God. God looked down upon Ireland and said "Damn, I'm good!"
2009 POW*MIA SE5
I had a 2 brothers single can on mine for about 20,000 miles - got sick of the loud sound even on slow acceleration and at highway speeds - I put a Hindle on and like the sound....just right, good sound w/o the loud drone on the freeways....
Sorry I should have pointed out I was asking about changing pipes on the RT only.
Originally Posted by Roy's Bassets
I changed to a Hindle, ran like crap, spit and back fired at low speed, rear cylinder ran to rich, fouled the plug. Talked to three different dealers all said you have to but a fuel control on or run the above 4000 rpm all the time. I take this as true because if you read about after market exhaust all recommend a fuel controller. I but the stock back on and all is fine, runs great. I just can't justify $600 for an exhaust and another $300 for a fuel controller just for a louder nosie. 1SG
I'm not buying it. All late model ricer are EFI as is the can am Spyder. With my ricers the computer just took care of the fuel mix as it does for changes in altitude and with a slip on. True with a full header then a power comander is in order. Just my $.02
depends on how wide band the 02 sensors are.
if you change air filter and full exhaust you will need more fuel as there is more air gong thru engine or it will run lean.
typically just a can exchange only doesn't free enough air flow to make a difference.
full exhaust and air filter with fuel mgmt will give your more HP
waiting for a full exhaust upgrade to be made and then go with the new fuel mgmt system coming out soon from dynojet with o2 sensor adjustment
Motorbike Professor
Also depends on the mapping in the ECM. Some are more forgiving and have a wider range than others.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
RT-S PE#0032
Hindle is working with BRP to develope an exhaust for the RT
Spyder Bytes: Kury ISO Grips, GL1500 Windshield Vent w/ accent, Heel-Toe Shifter(inspectorgadget), HMT Brake Light, 12v outlet in frunk, GPS-Phone mount w/ case( techmounts.com), seat seal, Right Side Grill Covers( customdynamics.com), Fan Can10(I SCIrides.com), CAT Shields( SpyderPops.com), Elka Shocks, PressurePro TPMS, Cobra CB....and of course Cup Holders( mycupholders.com)
I have the two brothers racing on my RT-S I love the deep sound it gives
They offer a cone to make it quieter P1 I believe
I rode Harleys for years, even with the two brothers on mine I think its quiet
others may not
others may not
I bet, coming from shot gun pipes and what nots I'm sure its quiet.
changed stock exhaust!
I changed my stock exhaust, I went with a two brothers M5. I had an S pipe fabricated at a muffler shop so now I have dual exhaust a two brothers M5 on each side. and I love the change, sound and response is great.
Exhaust
I too have the two brothers single pipe. I have the P1 tip and it made the Spyder run better. A little quieter too. Also have the K&N air filter. If anyone wants a clip, just let me know via PM.
2012 RS SE5
Mods:
Oxford Hot Grips
Bad Boy Air Horn
Two Brothers Exhaust
K&N air filter
LED mud flap lights
Tips Kit
Brake Light Modulator
IPS Key Cover
Up/out mirror Extensions
RSS stitched seat cover
Cal Sci touring windshield
5 spoke wheel upgrade
Ram mount Iphone cradle
LED turn signal indicators
Frunk Liner
BRP 12 Volt Outlet
Third brake light
Double Play tail light
I have a 2 Brothers on my RT-S and it has a good sound. No Juice box needed.
Bill
Pride Runs Deep Semper Tacitus
An armed man is a Citizen; an unarmed man is a subject....
2017 F3 T SE6
2015 Vulcan Vaquero ABS
ALR Chapter 401 (Hilliard FL)
GA & FL Patriot Guard
Just had one of BRP's Akropovic sport touring exhaust installed on my 2012 RT. Local dealer gave me a substantial discount, so I said "go for it".
Just a few miles on it so far, but a 3000 mile trip coming up late next week. The Akropovic sounds "great". Doesn't sound any louder than the original, but has a much healthier sporty sound. Original exhaust always reminded me of someone blowing hard into a split paper sack! Lol! Still pricey, but installed easily, and looks great, plus I shaved almost 15 lbs off of the total bike weight. Also, no re-tuning required, and it's covered under BRP's warrenty as an original accessory. I like it!
GUZZI :
2020 RTL blue
I have a Yosh on my RT, and like it. I also eliminated the CAT. It still pops a bit when cold, but runs like a scalded cat when warmed up. The Yosh sounds great around town or on the road.
2014 RT SE6 Rider
X - Honda Rider
X - RT S driver
X - RS driver
Lifetime VFW Member
2011 RTL exhaust
The coming from a GW with modified exhaust and 6 cylinders to a twin I miss my "fine tuned Porsche sound." there are a few Hindle's around but they don't sound good to my old ears.
The stock muffler sounds good IMHO!
Straight pipe
I wanted to see how my Spyder would sound and run with an open exhaust. I had a local muffler shop make a pipe up for me with a stainless tip. The sound wasn't too loud, I ran it for a couple of days, it wasn't obnoxious, but I guess my age caught up with me and I put the stock muffler back on. It's more comfortable when it's quiet. I am going to powder coat the pipe to make it look better an prevent rust. I may put it on when I run with my Harley friends.
