Page 1 of 2 12 LastLast
Results 1 to 25 of 42
    Registered Users musicarcade's Avatar
    Jul 2009
    Beaufort SC
    Default Transmission problem - code po826
    Hopped on the to make short trip to the grocery store. Got on the main drag and I got a check transmission scroll and engine light.
    Same thing when I got back home. checked for codes and got P0826 on my display. ran ok and shifted gears ok except for one time where it seemed to miss third. I hit the paddle again and it shifted.
    I was going to go for a 100 mile trip later today. not sure now. any ideas? does this need to go back to the service dept, or is there something I can do w/ my limited wrenching skills?
    Only out of the shop for 2 weeks...
    Happier Spyder Owner
    Fairly happy 08 YELLOW SE5
    Registered Users DSQUARE's Avatar
    Jul 2010
    CLEBURNE TX.
    Quote Originally Posted by DSQUARE View Post
    Last Saturday, I stopped at a friends house after riding the about an hour. The outside temp was probably about 99 heat index maybe 102, but only had 4 bars during ride
    I am in central Texas for location purpose.
    Anyway when I went to start the after about a 45 minute vist with my friend, when through the start-up mode, started, but a message scrolled across "check transmission". Bike would not go into ANY gear, and throttle would not rev over 1800. tried several different things. No luck. Finally called Granbury Motor Sports where I bought the and talked to the Tech.
    He told me to turn the key off and on 3 times. Did it. Started the bike, message gone and bike went into gear.
    He told me sometimes, not often the heat after a ride will not allow the computer to reboot to normal. The key trick will re-boot the computer. He said he had only seen this happen a few times. This is an FYI if it happens to you. And oh by the way, that Tech has my business for being so aware and knowledgeable of this great machine and all the workings of it.
    I POSTED THIS ON THE SHOP TALK. THE MESSAGE WENT AWAY AND NEVER APPEARED AGAIN. TRY IT
    Jul 2009
    Beaufort SC
    I'll try it but don't think it's the same thing. I just went out to try it again and what it seems to be doing is showing the ck tranny display when I shift from 1st to 2nd under quick acceleration. Then, when I try to shift to 3rd, nothing happens. 2nd time I push the paddle it goes into third and the display and engine light goes off like there was no problem.
    Also, while it is hot here, my engine was cold the first time- only up to 2 bars when it happened.
    Jul 2010
    CLEBURNE TX.
    Heat or no heat (COLD) it may sometimes but very rarely fail to return to normal. The computer may just need to re-boot which the key action may do.
    Jul 2009
    Beaufort SC
    Default key 3x seemed to work!
    Well I ate lunch and went for a quick spin again after turning the key on and off 3 times, and I could not re-create the fault. So the re-boot seems to work/hold.
    thanks DSQUARE!
    Is the computer on this ryde windows based??
    Mod Maniac ataDude's Avatar
    May 2008
    North Texas
    Quote Originally Posted by musicarcade View Post
    Ahh... the old blue screen of death.
    ata = allergic to asphalt
    My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
    There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
    My Spyder:
    Very Active Member Raptor's Avatar
    Jun 2010
    S.F. Bay Area
    Quote Originally Posted by ataDude View Post
    It was inevitable I suppose! But DSQUARE, that is a great trick to remember. That one is going in my notes for sure!
    "Life must be understood backward. But it must be lived forward."
    '09 Phantom GS (#14) (Gone but not forgotten) and 2010 RS-S
    Mar 2008
    Allegan, MI
    P0826 is the code for a "Shift Up/Down Switches) fault...basically your paddle shifter. It means the switches are out of range or there is a switch defect. The action to be taken is to check for disconnected switches or damaged wires. There is an extensive testing procedure in the shop manual to troubleshoot the problem. In the short run look at your connectors, to see that they are all fully seated and properly attached.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Jul 2009
    Beaufort SC
    Thanks Scotty!
    Somehow I knew you would come through what the code is.
    For some reason it only occurred from 1st to 2nd; If I made past second I was good to go.
    Jul 2009
    Beaufort SC
    Default seem to be working
    Went out again after dinner for sunset ryde around town, over several bridges, mossy oaks lining the street near the shore of the intercoastal waterway, beautiful sunset and NO CODES
    Life is getting better...
    ...then my washing machine heard me and sprung a leak tonite
    At least I can ryde my to work tomorrow- and I got all my clothes clean
    Registered Users SpyderWolf's Avatar
    Oct 2009
    Martin, SC
    Did the error come back after you cycled the key 3 times? I am hoping not.
    Very Happy Spyder Ryder!
    Click here to see My Spyder Mods
    Mar 2008
    Allegan, MI
    What fault code did the washing machine show?
    -Scotty
    Jul 2009
    Beaufort SC
    Quote Originally Posted by SpyderWolf View Post
    No. error did not return
    Quote Originally Posted by NancysToy View Post
    PuDDL3
    Apr 2010
    Milehigh City
    Life is good!
    Jul 2009
    Beaufort SC
    Quote Originally Posted by Suppentrulli View Post
    This it what the Service Manual says
    http://img651.imageshack.us/f/826p.jpg/
    tHANKS-
    But when I opened that URL, symantics popped up and said I had aquired a virus.
    Just trying to warn others!!!
    Oct 2009
    Martin, SC
    tHANKS-
    Hmmm, glad I read all the way through the posting before clicking on the link now.
    Is everything still good in Spyderville?
    Jul 2009
    Beaufort SC
    Default Not Again
    well I got home from work and hopped on the . didn't even get out of the driveway or reverse when i got the transmission fault again.
    this time I got a new code to go along with.P0826
    now I also have P0500
    This is not good.
    Jul 2009
    Beaufort SC
    Ok............... I came in wrote my little post, left a message w/ Carlo, and went again out for a little ryde. check transmission lite came on, and I had to shift (push the paddle) twice to get it into second. soon as I did, the engine light went off and so did the message. I drove to a parking lot and stopped,checked for codes - only got the p0826 this time, did the key off/on 3 times, and the code went away. drove it like a stole it. couldn't get it to come back on. While I was ryding, i remembered yesterday that I had cleaned my wheels. when I was cleaning the back one, which is a PITA, I had moved the by hand several feet to get to places I couldn't reach before. maybe this caused to 500 code? as well as the P0826? dunno.
    I'm going to make a point to ryde thru a few storms before I head to Gatlinburg in September tho just to see if my wants to tell what else is ailing it!
    Oct 2009
    Martin, SC
    You may want to double check the connections on your wheel sensors. I can't remember where I read it, but someone else was having some strange issues that were caused by this. I also think ryding it in the rain a few times to make sure it is okay would be a good idea. If you were here tonight you could have ridden it in a monsoon. It may be heading your way, so tomorrow could be a good day for testing.
    Somehow, some way, something needs to be done to get your Spyder running well for you for a heck of a lot longer than 2 weeks at a time.
    Jul 2009
    Beaufort SC
    Default Update
    Got a call from Service Center. They are ordering a shift switch to fix the issue. They said they should get the part in by Tuesday.
    Hoping that is the last issue for my this year.
    Really hoping to make it to SitS and THE BBQ.
    Oct 2009
    Martin, SC
    I sure hope this is the actual culprit and things get much better for you and your Spyder once this new part is installed.
    Best of luck! SitS is not too far away now.
    Jul 2009
    Beaufort SC
    yeah- Carlo talked me into getting it fixed prior to SitS. Told me there was no reason - and that it was BRP's goal- that a should not be in a shop for over a week.
    As Elvis Costello sang...
    "well I used to be disgusted, now I try to be amused.."
    Here's hoping getting this fixed doesn't cascade to another BRP part failure-
    I really want to make it to SitS, and possibly a trip on the Blue Ridge Parkway afterwards.
    REMAINING POSITIVE- See You at SitS and THE BBQ
    Oct 2009
    Martin, SC
    Oct 2007
    Musicarcade...off subject but I like your tall tinted windshield. Brand and height (from top to bottom center), please?
    Jul 2009
    Beaufort SC
    Madstadt windshield w/ robobrackets - middle size- I think is 22".
    I'd measure it but it's in the shop at present...
    I really like it!
