Results 1 to 12 of 12
    Feb 2009
    Chiang Mai, Thailand
    Default 09 SE5 stuck in 1st gear
    Yesterday I could not get bike out of 1st gear until I pulled the two main fuse up front and waited a while. Now I notice it take at least 2 to 3 time to go from 1st to into neutral, am I looking at a problem down the road and why did/is it dong this any idea what might be the cause.
    Jul 2008
    Los-Angeles
    Did U have the ground wire update?. Some had problems wit GPS or Gear Position Sensor. Have it checked by your dealer
    Feb 2009
    Quote Originally Posted by dvmdf View Post
    Yes did the ground wire and when I had my first services I convince them to change the GPS sensor now I wonder if they really did.
    Server Admin AnthonyG's Avatar
    Aug 2007
    mi
    Mine did the same thing and it was in the shop for 5 weeks.
    2018 F3 , Red
    Registered Users SpyderWolf's Avatar
    Oct 2009
    Martin, SC
    Do you have a different dealer you could take it to? They should be able to tell you if the GPS was really replaced or not. Either way, it sounds like you may need a new one.
    Best of luck with getting it fixed quickly.
    Very Happy Spyder Ryder!
    Click here to see My Spyder Mods
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    So is the Spyder stranded on your trailer then?
    Sorry bro.... couldn't resist. Hope you get her back on the road soon.
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    Feb 2009
    Quote Originally Posted by Firefly View Post
    Thanks Firefly, after I pulled the two main fuse it then went into neutral again and is running now but as I said sometime going from 1st to neutral it takes 2 to 3 time hitting the shift button and this never happen before.
    Active Member QuadManiac's Avatar
    Apr 2009
    San Diego, CA
    I've noticed, occasionally, if I leave my SE5 sitting for a while (several weeks) unused, that shifting from 1st to neutral can take a few tries... then as I ride it for a short time the problem goes away. I also have found that, when this has happened, shifting from 1st to reverse does work and this then allows me to go into neutral immediately from reverse.
    '08 SE5 #123 - Red - F1 Slider - BRP Comfort Seat - Spyder City 3" Riser
    Mar 2008
    Allegan, MI
    Bad TCM?
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Very Active Member Dudley's Avatar
    Dec 2008
    Jacumba, CA
    Don't know why this came to mind...have you checked your oil level???
    2008 GS SE5 in 2008
    Traded at 43,000 miles for a left over
    2010 RT SM5 in 2011
    Traded at 57,000 for a left over
    2014 RTS SE6 in 2015, which has 35,000 miles
    Oct 19th, 2017, totaled 2014 RT while killing a Javaline
    Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
    Never had any breakdown stranded issues.
    Registered Users Campverdefela's Avatar
    Aug 2009
    Camp Verde, Az.
    I'm betting on the GPS being suspect. It can be very sensitive at times such as if you should happen to rock the spyder while its trying to go into or out of rev., neut., or first. That manuever has caused mine to go into error, not start and or run bad and stall, then error again.
    Hindle exhaust, Kewlmetal K&N intake + prefilter, Kuryakyn widow pegs, Kuryakyn grips, Madstad 20in. windshield, Juice Box, 02Modifier, Kewlmetal backrest and carrier, missing air dam, missing belt shield, 1" riser, Kewlmetal handlebar risers,Evoluzione sway bar, Street Magic/Day Runner Pucks, Glo Riders Amsoil, 10w40, Rons performance wires
    Jun 2010
    augusta, Ga
    Default coming out of 1st gear
    I had the same problem, took my bike to the dealer only to find out that there was a recall on the electronic gear shifter
