Page 1 of 2 12 LastLast
Results 1 to 25 of 31
    Nov 2008
    las vegas, nv
    Default running rough, missing, popping, bad mpg
    could leaky y-gasket cause all this?
    when dynojet pull the pipes apart, they could not get the pipe all the way up due to thickness of the honda gasket. i had very hard time with that also.
    6 states down 42 states to go
    Active Member Eddie's Avatar
    Apr 2010
    Sthn. IL
    Quote Originally Posted by aka1004 View Post
    Why are they / You using a Honda gasket on a Can-Am??
    2009 RS with Hindle exhaust , handlebar risers , Green air filter , Juice box, Spyder Customs floor boards & Rifle windshield
    Mod Maniac ataDude's Avatar
    May 2008
    North Texas
    Yes they COULD cause this. The two smaller gaskets (where you are using the Hondas) are upstream of the O2 sensor.
    When I changed my gaskets (also Hondas), I found the best way was to remove the muffler and L-pipe. The remaining pipes were light enough to easily wiggle/maneuver over the new gaskets.
    I also had to use a large socket and mallet to widen the female part of the pipes' joints.
    ata = allergic to asphalt
    My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
    There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
    My Spyder:
    Apr 2010
    Sthn. IL
    Quote Originally Posted by ataDude View Post
    I also had to use a large socket and mallet to widen the female part of the pipes joints.
    Again I ask" WHY IN THE WORLD ARE YOU USING HONDA PARTS ON A ROTAX ENGINE" ?
    Jun 2009
    Zanesfield, Ohio
    I put the honda y gaskets on mine last weekend. The can am ones lasted on mine about 9,000 miles. Others have gotten even less mileage, even as little as 1,500 miles. The goldwing gaskets are the same size and seem to last longer.
    http://www.spyderlovers.com/forums/s...ad.php?t=19691
    09 SM5 Phantom
    Apr 2010
    Sthn. IL
    Quote Originally Posted by Batmobile View Post
    OH OK NOW I SEE.Think I will stick with Napa parts.Takes a little work to find the right one.But' when you do 1/2 price of Honda and just as good if not better. I have done dealt with Honda gaskets on my VTX1800. Not so great in my books
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by Eddie View Post
    There the Gold wing gaskets not VTX. Apples and Oranges.
    Alignment Specialist bone crusher's Avatar
    Aug 2008
    MD
    Half the price of $5.00...just as good or better....I think not! Is it really necessary to try to go that cheap when the Honda gaskets are vastly superior to stock, many people here have switched to them and have had success with them so far, and they are cheap?
    Bone Crusher
    If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    The BRB gaskets are junk. If you have 6,000 or so miles on your bike--- your righthand gasket is probably toast.
    The Honda gaskets are much cheaper than the BRP--- and MUCH better made---- probably will last for 50,000 miles!
    I was lucky that they fit great and was able to slide the lower pipes on no problem--- but some have had to spread the female pipe a bit to make the install go better.
    Great mod--- takes care of many of the problems mentioned...
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    Nov 2008
    las vegas, nv
    Alright, let's get back to the problem in hand
    Could a leak in the exhaust could cause all the issues I am having?
    Invalid Emails
    May 2008
    East Haven, CT
    Yes it could. I would also look at your spark plug wires & plug condition. We have had a few were the spark plug boots would leak and arch to the head. This would cause a weak spark in the engine. The easiest way to check it is remove your panels and start the bike in a dark area, see if you notice any arching to the head.
    Aug 2008
    MD
    Yes...and follow wackydan's instructions for replacing the gaskets...his thread is complete and very easy to follow...continued kudos to him!!!!
    You will need to get the Honda gasket (and yes, get the Honda one...it is made superiorly!)...part number 18392-mam-000
    Bone Crusher
    Aug 2009
    Manhattan KS
    I changed mine to the honda gasket at 6000 miles but I will tell you that teh BRP gasket was still in pretty good shape. That being said the Honda one was clearly a better made product.
    2009 phantom 424 of 500! Another Happy Spyder owner
    Apr 2010
    Sthn. IL
    Quote Originally Posted by boborgera View Post
    LOL Boy aint dat da truth
    Aug 2008
    MD
    Quote Originally Posted by jabba11 View Post
    I just changed mine...at around 3000 miles, and the right one was pretty chewed up...if I remember, I'll try to get a pic of it...
    Bone Crusher
    Senior Member
    Apr 2008
    Naples, Florida
    Quote Originally Posted by garganos View Post
    I have had this twice.
    Registered Users krb1945's Avatar
    Apr 2009
    God's Country, Keystone Heights, FL "Happy Owner"
    Eddie... what is the napa part number for their exhaust gaskets? And... were you able to locate a substitute for the large lower gasket. If so please post the part numbers for all of us. I've been searching for 10 months trying to find a sub for that big gasket.
    I've been using the Honda GL1800 exhaust gaskets for a year now. They are nice and tight. I've had them off a couple of times and the only time you will have any trouble installing them is if there is a tiny wire sticking out. Inspect them closely and if you see a meat hook just snip it off and install.
    Thanks for the info. Ken krb1945
    Ken krb1945 "Happy Owner"
    USN DAV 100% 'er
    Proud grandfather of a former United States Marine
    1 2008 SM5 PE 548
    1 2008 SM5, 1 2009 SE5
    2008 GL1800
    Apr 2010
    Sthn. IL
    Quote Originally Posted by krb1945 View Post
    I really haven't had a reason to look yet. Mine have been doing good so far. As far as the Napa part # I won't have that until I need to change mine. If you have got your Honda's installed and they are working good.Then I would just go with that. As far as the Honda's go when I had my VTX1800 a LOT of folks was having problems with the stock gaskets and a few just jumped over to Napa. My self being an Auto Tech. Will first take my old ones to Napa and try to match them Most of the time its not to hard if you have the old gaskets. But' as others have said" If the Honda is working and working good, Then stay with that as long as all you have to do is run up to the dealer and pick them up as a stock Item? " If Not then most of the time Napa can have them on the noon run or the next morning. Its really no big deal as long as you get a good gasket that works. Sounds like the Honda is the one that works. Think thats the one I would stick with
    Very Active Member Freddy's Avatar
    Dec 2009
    West Oz
    <snip>
    Does anyone have the inner and outer dimensions of this larger lower gasket?
    The best substitute for brains & knowledge is....................silence.
    Invalid Emails
    Mar 2009
    Georgia
    Quote Originally Posted by HDXBONES View Post
    Because many have found the Honda parts to be superior to BRP's
    Which is why I bought a Honda...
    Nov 2008
    las vegas, nv
    will leaky exhaust cause lean-ness? than pre-ignition?
    Doru the Destroyer-Spyder Photo Investigator docdoru's Avatar
    May 2008
    Clearwater, FL
    Yes on the first question.
    2013 "Silver Dream" GG Taurus
    2008 "Silver Dream" Spyder RS
    Einstein's theory of drag racing: Time and Speed are Relative.
    Shut up and Race!
    Nov 2008
    las vegas, nv
    i replaced the damaged clamp on the left and viola! problems went away.
    thank you for your posts.
    Very Active Member ntxYguy2009's Avatar
    Jul 2009
    McKinney, TX
    My Spyder has 15K on her and I suspect that my gaskets are destroyed also, so I just ordered the Honda gaskets at $4.93 ea from Honda Direct Line (directlineparts.com). I ordered two extra just in case any being damaged in shipment or I damage one!
    David
    David
    McKinney, TX
    Feb 2009
    Ceresco, Michigan
    Quote Originally Posted by ntxYguy2009 View Post
    David
    If you have 15K on the original OEM Y gaskets---- you can almost guarantee the righthand one is toast.
    The Honda ones are FAR better.
