when replacing y-gasket easier to?
take the muffler down first then the pipe or take them down as one unit?
do i have to change both gaskets at the same time? i was afraid when i pull the pipes down, left one may get damaged even if that one is still in good shape. i gotta take this spyder to dynojet asap but honda dealer only had one available...
thank you in advance.
6 states down 42 states to go
Y gaskets
If you have the stock muffler just loosen the one bolt holding it , loosen the clamps on the Y pipes [remove springs] The Y pipes will drop down.
The muffler does NOT have to come off! Also do both gaskets, Do your self a favor use the Honda gaskets.
Mod Maniac
My $0.02 worth.
Remove the muffler... it's a lot easier to reinstall the y-pipe with the new gaskets without the 25 pounds hanging on the end of it... particularly when you're on your back on the garage floor.
Replace both upper gaskets at the same time... not that much more work and you'll save yourself another tear down in the near future.
And, I agree... the Honda GL1800 gaskets are far superior to the stock ones.
No change required.
ata = allergic to asphalt
My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
My Spyder:
Agree, remove the can first. I have a hindle so it was not too much effort to slip it right off and then you have the rest of the stuff to work with. You will notice when you try to put both sids one, having the can off makes life a little eaiser, not much..tight fit I must say.
Very Happy Owner
thanks guys
honda dealer only had one so i swung by cam am dealer and picked up a spyder gasket. i will use the honda gasket on right side.
Originally Posted by ataDude
My $0.02 worth.
No change required.
I've also been told it's easier to place the new gasket on the male pipe and then insert into the female pipe. I'm still waiting for mine to come in--- should be later this week. Going to 'slot' the Hindle while it's off too.
Senile Member
Damn. I just RTVed my Hindle onto the Y-pipe good and tight. Oh well, maybe I'll ride the season out with the blown gaskets and do the dirty over winter.
Silver SM5 PE# 1274, Hindle Exhaust, Touring Windshield, Caliper Trim, B.E.S.T. 3 Year Ext, Nuvi 255 GPS, Fog Lights, Sport Rack, Back Rest, 12V Outlet, Talon 3300p Alarm, NMN Mud Flap and TipZ LEDs, SpyderLovers Emblems, Kuryakyn Widow Pegs and Axel Trim, Luimoto seat skin, Evo Air Filter and O2 Mod, Cranker Tank Bag, Blue Sea fuse block, MAD/AMS/MBG, Oddyssey battery, IPS.
Service Bulletin Applied: Gen II parking brake, 2nd SW patch, evap can/hose update, Gen II DPS
I don't understand, is the Hindle mounted differently than the stock can?
I just changed my gaskets all i did was loosen the one bolt holding the can
loosened the Y pipes then every thing just hinged down. I never took the can off!
Mod Maniac
My Spyder:
