my spyder just developed a grinding noise/clunking, especially when i let off the throttle and feels like they are coming from between my feet. is that how yours was acting? if my pulley has the same problem, could it just fall off? i am out of town and i got 300 miles to home.
6 states down 42 states to go
Very Handy Member
aka, that is the noise that I remember. Get it to the dealer as soon as you can.
With Christ all things are possible, so live life with no fears and no worries.
Happy Ex Owner, Hopefully future Spyder owner again.
Pastor Deb Tangen, Missions Director and short term missionary.
alright. thank you both of ya.
Very Helpful Member
Former Happy Spyder Owner
Just decided it was time to move onto other things.
What is the torque on this bolt supposed to be?
Happy 2009 Roadster Red SM5 Owner
Two Brothers Dual Exhaust w/P1X Tips | Two Brothers Juice Box | KewlMetal Intake | Amber Fender Tip Lights | Fog Lights | SilverStar Headlights | Trunk Liner | 12v Acc. Plug | BRP Comfort Seat
There is a new BRP bulletin regarding this.
2013 "Silver Dream" GG Taurus
2008 "Silver Dream" Spyder RS
Einstein's theory of drag racing: Time and Speed are Relative.
Shut up and Race!
Motorbike Professor
I would sure be interested in the detail on this.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Got a link or any specs so maybe some of us can avoid this nasty situation?
I see your problem.... It's made in the usa, the pic says it all
2008 SM5, F1 EvoIII slide, Hindle, Race Air Flow System, O2 Delete, Fuel Pressure Modfier, Powerbus System, BRP 6 Spoke, 12V power supply x2, 1" Handel Bar Riser, CompuStar Alarm System w/pager, Mono Seat Cover, Brake Caliper Trim, Trunk Liner, Outdoor Cover, Carbon Fiber SM5 Handelbar Inserts, Carbon Fiber Tank Knee Pads, TBR Juice Box.
Rusty bolt.
You can even see the point of entry and then the propagation of the rust to the interior of the bolt shaft.
You're supposed to lubricate a bolt before you put it in.
A member of the rabble in good standing.
A happy owner of a yellow SE-5.
NMN Risers, Mudflap Lights, Fender Tips, Center Brake Light w/ Triple Play, Throttlemeister, Madstad Robo-brackets, Madstad windshield, CHAD windshield, Canisterectomy, Exhaust wrap.
I am a bit concerned as I guess we all are. I have had mine replaced once at about 38,000.
A few questions to Doc since you are a 'lead the fleet' type of rider;
Do you do a lot of engine braking?
Do you think that replacing the bolts with a better grade would help prevent this? I am asking for an opinion here.
Should we be looking for an aftermarket supplier for this part?
Yes, I'm using a lot of engine braking with double-clutching (like in all sport bikes I had).
IMO the bolt is not the cause but the effect of the problem: too much stress for the splines on the shaft vs/pulley at the pitch line.
A crowned spline can be analyzed for torque capacity except that the tooth contact is more of a point load condition rather than the conformal contact of a straight spline.
Shut up and Race!
Motorbike Professor
Chicken or Egg?
The big question to me is which happens first? There are some that say the bolt cracks and loosens first, allowing the splines to wear, while others feel the spline wear allows play, which eventually damages the bolt. If the splines wear first, due to improper design, improper alloys, or improper heat treating...a stronger bolt, or Loctite, would be of little value. If the bolts are going away, there is still a question as to why the splines wear so badly, and why all the damaged pulleys I have seen were worn to the same point...none had slipped out farther on the shaft and left the outside ends of the splines (except the very outer edge) intact. I intend to Loctite the bolts, and even replace them with a higher grade, but I suspect the problem lies elsewhere.
-Scotty
How do you double clutch a motorcycle? There isn't a neutral between each gear.
Downshifting and blipping the throttle so the RPM matched the road speed.
Shut up and Race!
Originally Posted by NancysToy
The big question to me is which happens first? There are some that say the bolt cracks and loosens first, allowing the splines to wear, while others feel the spline wear allows play, which eventually damages the bolt. If the splines wear first, due to improper design, improper alloys, or improper heat treating...a stronger bolt, or Loctite, would be of little value. If the bolts are going away, there is still a question as to why the splines wear so badly, and why all the damaged pulleys I have seen were worn to the same point...none had slipped out father on the shaft and left the outside ends of the splines (except the very outer edge) intact. I intend to Loctite the bolts, and even replace them with a higher grade, but I suspect the problem lies elsewhere.
A very good question for the Can-Am R&D...
Shut up and Race!
Ah, OK, that's how I do it, didn't know bikers referred to it as double clutching.
Or double dutching
Shut up and Race!
Assuming you're NOT using the clutch during this process then?
I think it's the splines and then the bolt goes when it's trying to 'pick up the slack'.
RT-S PE#0027
Very astute Scotty , thus the vibration Dampner on the RT...nuff said.
Back amongst the living May 2021
2022 RT Limited Hyper Silver
Out to Pasture:
2013 ST Limited , Black Currant
2022 F3L , Dark Edition
2021 RTL , Chalk Chrome
2013 RT Limited , Circuit Yellow Metallic
2008 GS SM5 , Millenium Yellow
2020 RT Limited Petrol Dark
2014 RT Limited Champagne Black
2012 RT Limited White
2010 Timeless Black RTS SM5
2010 Orbital Blue RTS SM5
2008 GS SM5 PE 1941
2008 GS SM5 PE2011
