Page 1 of 2 12 LastLast
Results 1 to 25 of 34
    Doru the Destroyer-Spyder Photo Investigator docdoru's Avatar
    May 2008
    Clearwater, FL
    Default Counter shaft pulley...again
    Déjà vu grounding noises, this time with a broken retainer bolt. First time the bike was 50K (http://www.spyderlovers.com/forums/showthread.php?t=14189) now she is 7,890 miles.
    Joe at West Coast Power sports in Clearwater manages to extract the remaining bolt from the shaft and replace the pulley and bolt. Thanks to Lamonster and BJT for help.
    Here are some pics:
    2013 "Silver Dream" GG Taurus
    2008 "Silver Dream" Spyder RS
    Einstein's theory of drag racing: Time and Speed are Relative.
    Shut up and Race!
    Nov 2008
    las vegas, nv
    my spyder just developed a grinding noise/clunking, especially when i let off the throttle and feels like they are coming from between my feet. is that how yours was acting? if my pulley has the same problem, could it just fall off? i am out of town and i got 300 miles to home.
    6 states down 42 states to go
    Very Handy Member dltang's Avatar
    Sep 2007
    Grand Blanc, MI
    Quote Originally Posted by aka1004 View Post
    aka, that is the noise that I remember. Get it to the dealer as soon as you can.
    With Christ all things are possible, so live life with no fears and no worries.
    Happy Ex Owner, Hopefully future Spyder owner again.
    Pastor Deb Tangen, Missions Director and short term missionary.
    May 2008
    Clearwater, FL
    IMO you can drive home just avoid the "engine brake" (down shifting at high RPM). The symptoms are the same. Than, to the dealer ASAP.
    Shut up and Race!
    Nov 2008
    las vegas, nv
    alright. thank you both of ya.
    Very Helpful Member bjt's Avatar
    Oct 2007
    Grand Blanc, MI
    Quote Originally Posted by docdoru View Post
    Same symptoms as mine had. I rode back from Mosheim, TN. to Michigan with mine making the noise. That was after they fixed my broken bolt and worn pulley, just like in Doc's picture. The second time is when they determined that the shaft was bad too.
    Former Happy Spyder Owner
    Just decided it was time to move onto other things.
    Jul 2009
    Surry, Maine
    What is the torque on this bolt supposed to be?
    Happy 2009 Roadster Red SM5 Owner
    Two Brothers Dual Exhaust w/P1X Tips | Two Brothers Juice Box | KewlMetal Intake | Amber Fender Tip Lights | Fog Lights | SilverStar Headlights | Trunk Liner | 12v Acc. Plug | BRP Comfort Seat
    May 2008
    Clearwater, FL
    Quote Originally Posted by j45p3r View Post
    There is a new BRP bulletin regarding this.
    Shut up and Race!
    Mar 2008
    Allegan, MI
    I would sure be interested in the detail on this.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    Got a link or any specs so maybe some of us can avoid this nasty situation?
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    Registered Users tweeder's Avatar
    Jun 2008
    Kitimat, B.C.
    I see your problem.... It's made in the usa, the pic says it all
    2008 SM5, F1 EvoIII slide, Hindle, Race Air Flow System, O2 Delete, Fuel Pressure Modfier, Powerbus System, BRP 6 Spoke, 12V power supply x2, 1" Handel Bar Riser, CompuStar Alarm System w/pager, Mono Seat Cover, Brake Caliper Trim, Trunk Liner, Outdoor Cover, Carbon Fiber SM5 Handelbar Inserts, Carbon Fiber Tank Knee Pads, TBR Juice Box.
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by tweeder View Post
    Thats it ~44/40~ Or fight.
    Registered Users Latemarch's Avatar
    Aug 2008
    Cape Girardeau Missouri
    Rusty bolt.
    You can even see the point of entry and then the propagation of the rust to the interior of the bolt shaft.
    You're supposed to lubricate a bolt before you put it in.
    A member of the rabble in good standing.
    A happy owner of a yellow SE-5.
    NMN Risers, Mudflap Lights, Fender Tips, Center Brake Light w/ Triple Play, Throttlemeister, Madstad Robo-brackets, Madstad windshield, CHAD windshield, Canisterectomy, Exhaust wrap.
    Active Member Recluze's Avatar
    Jan 2009
    St george, UT
    I am a bit concerned as I guess we all are. I have had mine replaced once at about 38,000.
    A few questions to Doc since you are a 'lead the fleet' type of rider;
    Do you do a lot of engine braking?
    Do you think that replacing the bolts with a better grade would help prevent this? I am asking for an opinion here.
    Should we be looking for an aftermarket supplier for this part?
    http://bobspyder.wordpress.com/
    #610 2007-2009
    #104 2012....
    May 2008
    Clearwater, FL
    Quote Originally Posted by Recluze View Post
    Yes, I'm using a lot of engine braking with double-clutching (like in all sport bikes I had).
    IMO the bolt is not the cause but the effect of the problem: too much stress for the splines on the shaft vs/pulley at the pitch line.
    A crowned spline can be analyzed for torque capacity except that the tooth contact is more of a point load condition rather than the conformal contact of a straight spline.
    Shut up and Race!
    Jul 2009
    Surry, Maine
    How do you double clutch a motorcycle? There isn't a neutral between each gear.
    Mar 2008
    Allegan, MI
    Default Chicken or Egg?
    The big question to me is which happens first? There are some that say the bolt cracks and loosens first, allowing the splines to wear, while others feel the spline wear allows play, which eventually damages the bolt. If the splines wear first, due to improper design, improper alloys, or improper heat treating...a stronger bolt, or Loctite, would be of little value. If the bolts are going away, there is still a question as to why the splines wear so badly, and why all the damaged pulleys I have seen were worn to the same point...none had slipped out farther on the shaft and left the outside ends of the splines (except the very outer edge) intact. I intend to Loctite the bolts, and even replace them with a higher grade, but I suspect the problem lies elsewhere.
    -Scotty
    May 2008
    Clearwater, FL
    Downshifting and blipping the throttle so the RPM matched the road speed.
    Shut up and Race!
    May 2008
    Clearwater, FL
    Quote Originally Posted by NancysToy View Post
    The big question to me is which happens first? There are some that say the bolt cracks and loosens first, allowing the splines to wear, while others feel the spline wear allows play, which eventually damages the bolt. If the splines wear first, due to improper design, improper alloys, or improper heat treating...a stronger bolt, or Loctite, would be of little value. If the bolts are going away, there is still a question as to why the splines wear so badly, and why all the damaged pulleys I have seen were worn to the same point...none had slipped out father on the shaft and left the outside ends of the splines (except the very outer edge) intact. I intend to Loctite the bolts, and even replace them with a higher grade, but I suspect the problem lies elsewhere.
    A very good question for the Can-Am R&D...
    Shut up and Race!
    Jul 2009
    Surry, Maine
    Ah, OK, that's how I do it, didn't know bikers referred to it as double clutching.
    May 2008
    Clearwater, FL
    Or double dutching
    Shut up and Race!
    Registered Users SpyderWolf's Avatar
    Oct 2009
    Martin, SC
    Or double dutching
    I wanted to try that, but can't seem to get the front wheels of my SE5 off the ground enough to start the game.
    Very Happy Spyder Ryder!
    Click here to see My Spyder Mods
    Feb 2009
    Ceresco, Michigan
    Assuming you're NOT using the clutch during this process then?
    Feb 2009
    Ceresco, Michigan
    I think it's the splines and then the bolt goes when it's trying to 'pick up the slack'.
    RT-S PE#0027 widowmaker2011's Avatar
    Jan 2010
    Orchard Park NY
    Very astute Scotty , thus the vibration Dampner on the RT...nuff said.
    Back amongst the living May 2021
    2022 RT Limited Hyper Silver
    Out to Pasture:
    2013 ST Limited , Black Currant
    2022 F3L , Dark Edition
    2021 RTL , Chalk Chrome
    2013 RT Limited , Circuit Yellow Metallic
    2008 GS SM5 , Millenium Yellow
    2020 RT Limited Petrol Dark
    2014 RT Limited Champagne Black
    2012 RT Limited White
    2010 Timeless Black RTS SM5
    2010 Orbital Blue RTS SM5
    2008 GS SM5 PE 1941
    2008 GS SM5 PE2011
