SpyderLovers Founder
Video- Lockable Center Storage Area
There's some misinformation about the RT center storage area and if it's lockable or not. I'm here to tell/show you it is lockable. You crank the wheels one way or the other just as you would to lock the steering and when you lock the steering it will also lock the center storage area.
[ame]http://www.youtube.com/watch?v=AMsb3ohd7kw[/ame]
Registered User
That is awesome!
Do you know if the RS for 2010 will have this option?
thank you.
Motorbike Professor
Thanks, Lamont. I had tried this feature on the demo at the dealership. Works just fine. Your video tells more than my words could ever had said.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
RT-S PE#0174
Thanks for that info!
"Happy Spyder Owner"
2010 RTS PE 0174
Custom Plates & paint,
ESI Triple play,mud flap lights,Fender tips/amber,Green Filter,Dayrunner/turn signals,Shortee Antenna,Scuff Guards,LED Brake Lights & 2 in 1 Harness,Brightsides & rear, Glo-ryders/amber, Kewlmetal inside trunk lightz, Garmin 660,Garmin Hood,Volt Meter & Oil Pressure Gauge, Utopia Backrest, IPS Key, ISCI Brake Pedal,Dual side/tall flag poles, SPYDERPOPS Heat Guard
http://www.farriscustoms.com
This site is excellent. Thanks Lamont. My dealer wasn't even aware that there was a center storage compartment, when we first statred looking at the RT. When I showed them, they said...hmm...too bad it doesn't lock..Well!! What can I say but thanks. Len
RT-S PE#0803
Originally Posted by lawrenc454
Lamonster - you seen to have been under the body work more than anyone else.
I want to add two switches and a Powerlet outlet for my vest and was thinking about putting them by the other switches but I know the air box is below that and didn't know if there is an 1" or more for the bottom of the switch and the wiring/connectors.
Thanks in advance and happy holidays dude.
Looks like there is room, just want to look before you drill because there are some ribs in the way.
Center storage all of a sudden does not lock
Hi Lamont
Hope you can guide me in the direction I should look.
I have a 2015 RTS- that I bought new-
I noticed two days ago that the center storage compartment in front of the seat no longer is locking when I turn the wheels all the way and the bike.
Can you please shed some knowledge on this situation.
Thanks very much.
Don
Bedford Virginia
Originally Posted by Don K
Hi Lamont
Thanks very much.
Don
Bedford Virginia
Don,
It's not just turning the wheels, you also have to lock the steering, by turning the key to lock position. This locks both the steering and the glove box.
2017 RT-S
Bump Skid - Spyderpops
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
3 PC Mesh Zippered Lid Net Set - TricLED
A arm LED's - Safety LED's - TricLED
Mirror Sequential turn signals
Glo-riders
LED rear turn signals and reverse lights
Front Grills
Third Brake light
Larson Scanner
Light Up - Sue Hopper
Originally Posted by bcer960
Don,
Thanks a lot for responding.
Yes I knew that you also needed to lock the steering.
I have not had any problems locking the compartments until two days ago when just this one compartment stopped locking .
Don,
I don’t think that my reply back went through.
Thanks very much for your response about the center storage not working.
I knew that you had to turn the front wheels and lock with the key.
Like I mentioned in my first post I purchased the Spyder new.
The compartment had always been working properly until two days ago.
It lid still latches close - it just won’t lock.
No problem Don,
Just making sure that you were locking the steering as well....
Good luck in finding an answer
2017 RT-S
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
Glo-riders
Front Grills
Third Brake light
Larson Scanner
No problem Don,
I do very much appreciate your response about the storage compartment.
I noticed that you have added a Baja Ron sway bar.
What was your reason for changing the swaybar?
Have you really noticed big differences after the change.
I’m wondering if this is what I need.
My 2015 RTS feels like it wants to roll/tilt in turns with any speed.
Thanks again Don
The sway bar fixed two things for me
First: If, when you are going around corners, mostly long sweeping corners, and suddenly the spyder looses it's line on the road. I had this happen a few times to me, especially when riding two up. But it happened top me when riding single as well.
Second: When a large vehicle, such as a transport truck passes you going in the opposite direction and the air pushes the spyder away.
hope this helps....
2017 RT-S
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
Glo-riders
Front Grills
Third Brake light
Larson Scanner
hope this helps....
Very helpful information.
Thanks
