Results 1 to 6 of 6
    Feb 2024
    Ohio
    Default Using FOBO TPMS? Did you install the T valves?
    I used the FOBO TPMS system on my Goldwing. Does anyone on here use this system on their Spyder? If so did you install the T Valve's in the rims?
    Last edited by Peter Aawen; 04-24-2024 at 11:47 AM. Reason: Expanded title to briefly ask the question/s... ;-)
    indpls in
    yes no
    Jan 2024
    Texas
    Quote Originally Posted by SamHuskyguy View Post
    Yes. No t-valves. Also, not enough room for the lock either, so they are just screwed on. Super simple.
    2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
    Feb 2024
    Ohio
    Quote Originally Posted by Allen42 View Post
    Thanks Allen42! I was curious if there was enough room for T-Valves.
    Active Member Maplehawk's Avatar
    Dec 2023
    Saint Cloud, FL
    also yes and No
    2024 RT Limited, Petrol Metalic Sold, replaced with Goldwing
    Baja Ron Sway Bar
    TricLED Front Fender Reflectors with Sequential LED Turn Signals & Running Lights
    Show Chrome LED Trunk Lights with Run, Brake & Sequential Turn Signals
    Mo-Door Garage Door Opener
    Fobo Electronic Tire Pressure Monitoring System
    Show Chrome Heavy-Duty Replacement Rear Trunk Lid Lift Support Strut / Shock
    Show Chrome Trunk Mounted Luggage Rack
    SpyderExtras Billet Aluminum Handlebar Riser Kit
    Mar 2024
    St Augistine area Florida
    I used the TPMS on my Victory and installed the T valves that go in the wheels. But there are T's that can go on the esiting valve stem and then t so you can service without removing sensor.
