Results 1 to 15 of 15
    Active Member USAF's Avatar
    Aug 2022
    NY
    Default Any experience using these Dolly Jack's for moving Spyder?
    Has anyone used one of these dolly jacks on your rear wheel to move your spyder around the garage out of the way ? And will it work with a 2022 Spyder RT ?
    2022 Spyder RTL
    Apr 2019
    Clinton, MS
    It will but it is very tight if you try to put it fully under the tire before you start to lift. Works great on the front.
    2019 RTL Phoenix Orange
    .... I think the Lifting lever is not going to be accessible for the rear wheel .... I bought small wood framed moving doolies from either Harbor Freight or Home Depot .... 12 X 14-16 .... the rear wheel fit inside very nice .... I know you have to jack up the Spyder to do this, but I seldom needed to do this ....Mike
    Active Member Jesster72's Avatar
    Oct 2021
    IL
    I got the Harbor Freight car dollies. I would have preferred the softer nylon rollers, but I use them twice a year - once to roll the Spyder to the back of the garage, and then to move it out to wake it up. I think I spent about $100 for the set of 4, and I already had a floor jack to get the bike up in the air, so it worked out for me.
    2022 Sea to Sky
    Northern Kalifornia
    Exactly as BK911 said. It's the least expensive, quickest, and safest way to move around and store your spyder for the season.
    Aug 2022
    NY
    I was also thinking of getting these without the jack like already mentioned. I think this is the route I may go with.
    2022 Spyder RTL
    Aug 2022
    NY
    You are saying a wood framed dolly will hold the weight of the spyder ? Do you have a picture of what you purchased ? That would be a much cheaper way to go.
    2022 Spyder RTL
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    Quote Originally Posted by Jesster72 View Post
    I brought the same thing to move two Spyders around in the garage, works great for storing during the winter. Can move the Spyders around without the need to start them.
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    Sep 2012
    Northern Virginia
    Quote Originally Posted by USAF View Post
    They work great, lift up the Spyder a couple of inches off the ground and slide them under wheels.
    [B]
    No pic - Sometimes I use all three, and sometimes just one under the rear wheel. .... ZERO issues with weight. ... Bought them over 14 years ago. ..... Mike .... Just looked on Harbor Freight. ... hardwood 1000 lb rated 12" X 18" - $ 12.95 ea.
    Northern Kalifornia
    I have one of those little HF wooden dollies under a small antique business safe made of steel and concrete that weighs close to 500 lbs. and it's as good and sturdy as the day I bought it. That's close to half of an RT.
    Sep 2017
    Durham,Maine
    I have used my sled dolly's that look a lot like these, work great!!!
    2012 RTL , Pearl
    Active Member BigPoppa's Avatar
    Jun 2023
    CA
    I bought similar ones off Amazon to complement my Big Blue lift. I haven’t used them yet though, they’re still in the box.
    Last edited by Peter Aawen; 04-17-2024 at 06:40 PM. Reason: Fixed quote display ;-)
    Very Active Member Bensonoid's Avatar
    May 2014
    Benson, NY
    They're on sale now at HF.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    May 2013
    Apex, N.C.
    Quote Originally Posted by Bensonoid View Post
    I also use those to attach my shop working stool to. The wheels on the stool always break off. So I just take them off and bolt the entire thing to the wooden dolly. Works great, and raises it up about an inch.
