Results 1 to 16 of 16
    Mar 2024
    AR
    Default What is this plastic rod? Should it be attached somewhere?
    I was under the 2023 Spyder RT-L today and noticed this rod that appears to need to be attached with a nut and bolt to the hole below it.
    Can anyone tell be what this is and what purpose it serves? Could you recommend taking it in for service or just buying a bolt and nut to reattach?
    Thanks.
    Last edited by Peter Aawen; 04-13-2024 at 07:04 PM. Reason: Expanded title to briefly ask the question/s... ;-)
    Mike Branscum
    2023 Spyder RT Limited Carbon Black
    I'm pretty sure that's the connecting rod to the ACS system. You have a Ltd, so it has the Self-leveling system .... Have you noticed that it wasn't working????? .... Mike
    Look at a parts Fiche' to see what size it is and get one anywhere they sell nuts and bolts - Ps. it's probably METRIC.
    Mar 2024
    AR
    Thanks. I’ll check that out. Yes I have notice the ride was a little rough.
    Mike Branscum
    Oct 2020
    Arizona
    Quote Originally Posted by mbranscum View Post
    Thanks.
    Did you have a new rear tire installed recently? It is disconnected as part of doing a rear tire replacement.
    Mar 2024
    AR
    Quote Originally Posted by Snoking1127 View Post
    Did you have a new rear tire installed recently. It is disconnected as part of doing a rear tire replacement.
    This was a new purchase around three weeks ago. Is this common item they miss on new set ups or should I be worried?
    I reconnected and ride is much smoother now.
    Mike Branscum
    Well whoever assembled your Spyder .... didn't connect it .... You should let the salesperson you did business with know about this ..... Glad you got it fixed ....Mike
    Active Member Elwood58's Avatar
    Mar 2012
    PHOENIX Arizona
    That is one step that gets missed often during initial assembly. It was one of the first things I checked on my F3. My previous RT had it too.
    2012 Viper Red RT-S (Sold)
    2020 Ryker Rally
    2023 Plasma Red F3 Limited
    Clinton, MS
    When you get it hooked up correctly you are going to notice a tremendous improvement in ride quality. Based on the pic your air bag is completely collapsed.
    2019 RTL Phoenix Orange
    Durham,Maine
    And hopefully not pinched and leaking!!!
    2012 RTL , Pearl
    Active Member Spyderglide's Avatar
    May 2017
    Wildwood, Florida
    My right hand up! Yes! My air bag link was not hooked up by my dealer when I took delivery! (I heard the air pump running and then it stopped!) My luck the dealer was closed, so once I got home, I looked in my tin cans of nuts and bolts and found the right metric bolt to hook it up!
    2016 Spyder RT-S Special Series (black)
    Garmin Zumo 590 GPS with Mounting Kit & Locking Plate
    Battery Tender Jr
    Full & Half Covers
    Foam Grip Covers
    NBV Highway Brackets with Black Dually Trident ISO Pegs
    3- Piece Lid Net Set
    Baja Ron Sway Bar with Aluminum End Links
    Magic Mirror’s
    Doc’s Vibration Damper
    Air Ryde Rock Armour Cup
    Missing Belt Guard
    Dual USB Charger with Digital Voltmeter Rocker Switch
    IPS Axel Caps Front (inner) & Rear
    GoldPlugs MP-01 & MP-18
    Yuasa YTX24HL-BS Battery
    Battery Post Risers
    Tie Down Rings
    Show Chrome Rear Trunk Shock
    2- Beaded Seat Cushions
    Tinted Sport Windshield & Side Cargo Bag Set (stored in a box)
    Apr 2022
    Oklahoma
    It's a '23, let the dealer fix it. If you do have a damaged air bag, they could refuse to fix it because you worked on the system and now it's broke. Worst case for sure, but some dealers are always in the CYA mode.
    Oct 2021
    Wichita, KS
    Now you need to take it back to the dealer and have the ride height calibrated with BUDS. Your Spyder is not right until it is calibrated.
    Peter Pan has struck again!
    Active Member MonPaul's Avatar
    Feb 2019
    Central WI
    Agree, good thing you took the before you put it back together picture!
    Jan 2024
    Texas
    What years does this apply to? Should I take the tupperware off my 2019 RTL to verify mine is hooked up?
    2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
    Quote Originally Posted by Allen42 View Post
    It's not the YEARS that matter ..... only if you have a model that has the " ACS " system ..... The Rt's that have the ACS are the ones that have the Auto Leveling system PUMP .... all the LTD's have them ....Mike
    Oct 2021
    Wichita, KS
    No need to remove any body panels. You can look up under there to see it. You would be aware if it was not hooked up. You would be experiencing a very rough ride otherwise. Many threads on here about it.
