Results 1 to 5 of 5
    Dec 2014
    S.E. Michigan
    Cool How Do I Wire BOTH Fiamm High & Low Note Horns?
    So, I'd like to add a Fiamm High Note Horn to my Fiamm low note horn. Both are disc horns. I was thinking just attach one to the other. Then I thought about not exploding anything, so I thought I'd ask wiser minds.
    Thanks in advance!!!!!
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
    NorCal - Northbay
    Just run jumper wires from one to the other. You will need "piggyback" terminals to give you the secondary jumper connections to put on the first horn.... I have this currently set up on mine with two horns... Here is one option:
    https://www.amazon.com/Heschen-Piggy...2942348&sr=8-6
    I have had my horns installed like this since I got the byke in 2016 with NO issues... You just need to make sure the power draw is within the fuse rating.
    Chuck
    Dec 2014
    S.E. Michigan
    Thanks, Hypurone. I've got a jerry rigged solution set up, pending Amazon delivery.
    ~Sandee~
    Hopnel Pouch
    Magic Mirrors
    Iron Butt #35273
    Oct 2020
    Missouri
    I added dual horns on my Yamaha FJR and just made a positive and negative jumper wires that plugged into the factory harness. Never a problem but now the wife wants dual horns on her 2020 Spyder RTL so I will be laying on the ground doing the same wiring thing to her Can Am.
    As long as you're using the proper wire gauge to handle the load, should be no problem with jumping from one to the other.
