Results 1 to 9 of 9
    Active Member MonPaul's Avatar
    Feb 2019
    Central WI
    Default Where does this Battery Bracket fit on 2018 RTL?
    I had a hard time getting my fat hands into the small space to get the battery out. After I pulled out the battery the top bracket fell and I'm not sure how it goes back; if you look at the second 2nd pic, I think I have it where is should be to put back in the bike, but I can't figure out where the top piece goes (arrows)?? It looks like it should fit inside a slot or around a rod, but I can't see anything. Any help would be appreciated - a pic or video would be appreciated even more.
    Last edited by Peter Aawen; 04-09-2024 at 06:58 PM. Reason: Expanded title to briefly ask the question... ;-)
    indpls in
    Yes, that is correct orientation of the bracket. After you put the battery back in, it's kinda a feel thing to raise the front of the bracket, slide it in, let the front down, & it should not pull out when you put the strap on.
    Faribault, MN
    +1 There are slots cut in the frame above the battery box that those tabs tuck up into once the battery is in place. Then the rubber strap connects below the bottom of the battery box to the flat hook on the front of that bracket.
    Moabman has a nice youtube video on Battery removal and replacement. The install starts about 2 min 50 seconds into the video.
    https://youtu.be/j-N1bmXjiaQ?si=6JuRJ_VzIXT8Q2an&t=173
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Mar 2017
    Salisbury,NC
    practice just with hold down bracket first, to put in frame slots. Try a good light and a mirror to see the slots. If you had a helper, you might be able to install bracket, then have them hold it up, while you slip battery in area
    Feb 2019
    Central WI
    Perfect, just what I needed! It is a lot easier to see on the F3, but at least I know where to look.
    Last edited by Peter Aawen; 04-09-2024 at 10:23 PM. Reason: Fixed quote display ;-)
    Feb 2017
    The thing that confused me the most was that the link led me to a video that's 4 minutes 18 seconds long. Just couldn't figure out how to get to the 5 minute 30 second point. Have I overlooked something?
    2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
    Quote Originally Posted by Arion View Post
    I've now fixed the time stamp in the original post showing the link, and fixed the quotes; but clicking on the original link took me to exactly the right spot anyway, just where all the pertinent info started showing.
    Feb 2019
    Central WI
    Quote Originally Posted by Woodaddict View Post
    Perfect advice! It took a mirror and light just to see the slots. All they had to do was put a little more of a hook on the tab that fits in. The bracket should be able to just hang there - I ended up fitting it in and just duct taped it up so it wouldn't fall. Thanks again for the help.
    Faribault, MN
    Sorry, dislexic typing old geezer here Thanks to Peter for fixing my typo and link.
    Safe Rides,
    IBA 70020
