Results 1 to 11 of 11
    Active Member 66Roseracing66's Avatar
    Dec 2021
    Florida
    Default Double Vision on the Dash! - Am I crazy, or new glasses wonky?? Anyone else?
    Jumped on the 2021 F3s this morning to run to the store. Looked down at the gauges and saw double vision. They looked like a double exposure of a photo. When I came out of the store and restarted the Spyder everything was good. Either I am crazy, or my new glasses are acting up. Just wondering if anyone else has ever had that problem.
    No, I was not drinking yet! LOL
    Thanks
    Last edited by Peter Aawen; 03-30-2024 at 03:47 PM. Reason: Removed Prefix - not 1330 engine specific & expanded title to briefly ask the question... ;-)
    2021 F3S , Grey/orange
    sun baked control panels can lead to such happenings.
    Dec 2021
    Florida
    I am not thinking "sun baked control panels" is the problem. The Spyder only has 7000 miles on it and is garage kept. However, anything is possible. I appreciate your opinion.
    Apr 2019
    Clinton, MS
    I remember reading about it happening. Seems to be extremely sporadic without a cause being found. You may never see it again.
    2019 RTL Phoenix Orange
    Quote Originally Posted by 66Roseracing66 View Post
    By "sunbaked" I am referring to the dash controls getting overheated on a hot sunny day--like they have sometimes in Florida.
    Dec 2021
    Florida
    Thanks for the input. If it happens again I will try to photograph it and show everyone I am not nuts ! Haaa Thanks
    Jan 2022
    North Dakota
    It did it to my 2021RTL. Cycled key and all was well. Hasn't reoccurred in two years. I did take pictures in case it happened again.
    2021 RTL , Asphalt Gray
    Vermont
    Thanks
    HI, 66 Roseracing66,
    I had it happen on my 2023 F3 LTD Special Series last year, I had the double vision on all of the gauges, I was shifting gears and using the controls too fast. It did't last too long. At the time I was going up a hill. After I shifted more slower, the display was normal again. Since then I have had it happen.
    Sorry no pictures.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Dec 2021
    Florida
    Thanks for everyone's input. Guess I won't worry about it until the next time. Never a bad answer with this electronics stuff. Cheers
    Very Active Member CloverHillCrawler's Avatar
    Mar 2021
    Maryland
    Next time you have it at the dealer have them check to make sure the firmware is a current version or have them reflash it.
    2020 F3 SE6
    Safety and Lighting: LED Headlight upgrade, IPS LED Fog lights, Show Chrome LED Fender Signals, LED Signature Light, Tric LED Afterburnerz, MotoHorn 2.0
    Suspension: Wilbers Front and Rear Shocks, BajaRon Sway Bar, Vredestein Quatrac Front and Rear Tires
    Comfort: Blue Ridge Windshield, Corbin Dual Touring Saddle, Ultimate Floorboards, OEM Passenger Backrest with Rear Shelf, OEM Passenger Floorboards Modified with High Risers from Pierre
    Tackform Center Mount Phone Holder w/ rapid charging USB-C.
    2020 F3 , Black
    Aug 2018
    Piperton, TN
    Happened to me once on my 2021 RTL. I turned it off, took out the key, and restarted and it was normal again. Sounds like a software glitch that just needed rebooting.
