Results 1 to 20 of 20
    Active Member Y-me's Avatar
    Feb 2011
    NY
    Default There seems to be an abundance of 2019 RT's selling - what gives?
    Hi all,
    There seem to be a lot of low mileage 2019 RTs on the market.
    Are people giving them up because of the newer models, or was there some issue with this model year?
    I've looked around here and elsewhere, and I don't see a lot of issues outside "the red dust of death", and possibly the casting issues with the blocks that some have said are behind oil leaks.
    So what gives?
    Y
    Last edited by Peter Aawen; 03-23-2024 at 05:51 PM. Reason: Expanded title to briefly ask the question... ;-)
    Oct 2020
    Arizona
    BRP just did the sprocket recall on my used 2018 I had just bought. The 2018 and 2019 both have the full digital dash, which I like, as I have two 2018's. The 2019 RTL Chrome have one of best looking OEM front wheels of all years and models of Spyders.
    Feb 2011
    NY
    What's different about the new sprocket?
    I'm considering a new Spyder and looking at a used 2019 RT Limited with ~13000 miles for $16k and a new 2024 plain old RT for ~$24k.
    Very Active Member MRH's Avatar
    Apr 2012
    Los Angeles and Santa Ynez, CA
    The 2014-2019's were a very good run. Personally, I like the styling on the 2020-2024 much better, and it has a slightly more aggressive ride, but they aren't all that different. 13K miles is't a big deal at all, although you can easily spend a few dollars getting new tires in the not too distant future. At 2/3 the cost for a Limited, the 2019 sounds to me like the better choice if you plan to ride at or under 10K per year, but if you plan on heavy riding and long trips, then I'm generally a fan of new.
    It may help to see a service record, and to find out what you can about why it's for sale. If you can, have it checked out.
    2020 RT Limited in the ultra cool Deep Marsala Dark edition.
    Baja Ron Anti-Sway Bar, LED reflectors, Lamonster USB Charger (and phone mount), Can-Am Low Windshield, X-Creen Tour Variable Windscreen Spoiler Blade, Power Commander, Dilithium powered Flux Capacitor (not yet fully functional).
    Maintained by Lou at Pirate Powersports.
    Oct 2020
    Arizona
    Quote Originally Posted by Y-me View Post
    Not suppose to wear like the OEM one. That's a fair price for the 2019, especially if it is the chrome verses the dark model.
    Dec 2020
    Down South
    2019 isn't bad, but being that we're in 2024, I'd personally go for the newer model if it's in my budget. 13K miles really is low. That's averaging less than 5K miles per year.
    I do believe there are major differences in storage if you go with the RT Limited. The top case is better(in my opinion) on the newer RTs. The seat is also a little better(to me) from just sitting on a 2019 vs 20+. The 20+ feels a little roomier for 2 riders.
    If warranty is a concern, newer is likely to have some warranty left or the extended B.E.S.T. warrant as an available add on.
    As for appearance, I like the 20+ especially with the LED headlights, signature lights, etc. It looks more modern with a front that resembles a small sports car.
    The 2019s look like they could've been a character in that Disney movie Cars .
    Also, I think the 2019s have a rider adjustable "air suspension". I might be mistaken on the year for that. The 20+(Limited) are auto inflating and the base RT can be adjusted using a pump.
    I believe the things that make them go and stop are practically the same.
    I got a really good deal on mine in 2020 though. So, I decided against a 2019.
    I'm not a wrench turner, but I believe I've read a few posts that mentions working on the pre 20+ models are simpler(less plastic to move and such).
    Overall, I think you'd enjoy riding either generation.
    '20 RT Chalk Metallic
    Oct 2020
    Arizona
    Quote Originally Posted by JohnRuckus View Post
    The top case on the 2019- spyders is part of the trike and does not look like an add on stuck there. The 2018 and 2019 RTL has the auto leveling rear suspension. Not sure which year that started however.
    Brake pedal is in a better location on the 2019- models. I took my trike class on a 2020 and had been riding the 2018 a bit before. So yes I have ridened both.
    Dec 2020
    Down South
    Oh yeah, the floorboards are different as well.
    Nov 2013
    Central Texas
    As my signature line shows, we have a 2017 RT-S, a leftover bought new in the crate in July 2018. It has been a stellar performer with minimal problems, parking brake motor replaced under warranty early on, and a camshaft positioning sensor last year. Oh, and water in the gas recently, although certainly not the Spyder's fault. I consiously did not want the new for 2018 dash, if for no other reason that I don't typically don't buy anything with first year tecnology. And given the problems BRP had with it, and the ongoing issues even now, it was a good choice for me. So this will be last the bike for us, and I'm happy with that.
    Apr 2012
    Quote Originally Posted by Snoking1127 View Post
    I find the design of the 2020+ much more elegant than the earlier models and the much larger top case looks just right to my eyes (and it can be changed out for other options). The 2020+ feels more like a motorcycle, and less like a snowmobile in design, again, to my eyes. The auto leveling suspension goes back to at least 2014.
    Jun 2021
    I had a 2019 that I bought used. It was a nice bike but the 2023 that we now have is in my opinion a better machine. It rides better with less vibration at 80 mph. The oil changes are much easier since it has a smaller removable side pod to access the oil filter. It also seems more comfortable to ride and less stressful on my upper back.
    2023 RT Limited , Red/ black
    Apr 2012
    Greenville, SC
    Quote Originally Posted by MRH View Post
    My 2017 had an adjustment for how soft or firm you wanted the air suspension to be. It auto maintained it at that level. Seems like the 2024s are self-leveling but see no way to adjust how soft or firm it is anymore.
    Oct 2020
    Arizona
    Quote Originally Posted by jfischer View Post
    Starting in 2018 they are completely automagically leveled.
    Last edited by Peter Aawen; 03-25-2024 at 06:17 PM. Reason: Fixed quote display ;-)
    Mar 2015
    Indianapolis, IN
    My wife rides a 2019 Spyder RT Limited Dark Edition. I work on all Spyders and Rykers as a hobby gig. Nothing wrong with the 2nd Gen RTs. I still like that style better than the 3rd Gen RTs (2020+). I like the ergonomics better in the 3rd Gen but the looks better in the 2nd. We've got 28k trouble free miles on the 2019 and are quite happy with it.
    That said, many like the looks of the 3rd Gen -and the ergonomics are much better - so I think several are selling 2nd Gen and moving to 3rd because of it. The larger boards and slightly lower seat height is nice - addressing the comfort issues I personally have with the older RT.
    Personally - I'm an F3 (Sport) guy through and through - but for the RT folks - you can't go wrong with the 2nd or 3rd gens.
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    2016 F3S , Triple Black
    May 2013
    Apex, N.C.
    I don't think auto leveling began until 2018. I do know that in 2014 you could set it for harder or softer. I wish that was the case for my 2021. It would be nice to firm it up a little when wanting to ride more agressively when going solo. I have had a 2014 RT and currently have a 2021 RTL. To me, I think the quality was better on the 2014, but the looks and ability to remove the trunk from the 2020+ was a decision maker for me. I hated the attached trunk on the 2019 and earlier models. That is the main reason I went with a 2016 F3T when they came out.
    Feb 2011
    NY
    My 2013 plain ole RT had harder or softer options for the rear using a Schrader valve and your very own compressor. Though they offered an onboard compressor option so that you could change it up from the seat.
    Feb 2011
    NY
    I dun did it and went with the 2019.
    Maybe some of you will see the Great Pumpkin if you frequent SpyderQuest or Rockland or Orange counties in NY.
    Active Member Jesster72's Avatar
    Oct 2021
    IL
    "Automagically"
    2022 Sea to Sky
    Dec 2020
    Down South
    Congrats!
    Sep 2012
    Stetson, Maine
    All RTS and Limited models from 2010 to current had self leveling systems. In 2018 BRP removed button to stiffen or soften the ride. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
Tags for this Thread
