Results 1 to 18 of 18
    Mar 2024
    Maine
    Default '24 RT - What's missing to get Music from Android phone to play on Spyder?
    Just took ownership of my first Spyder. 2024 Spyder RT Limited Platinum. First question. Connect phone via bluetooth. Unit sees the phone, contacts, recent calls... but will not show up on media app. Phone is a Samsung S22. If I'm playing music on phone, then start the bike, once it finds the phone the audio stops on phone as its connected to bike via bluetooth. What am I missing to get music to play? Thanks
    Last edited by Peter Aawen; 03-23-2024 at 04:30 PM. Reason: Expanded title to briefly ask the question... ;-)
    Sep 2020
    Middletown, NJ
    Short answer: save your sanity and just BT the phone and forget the BRP app. There are hours of comment on this forum. Enjoy the read!
    2020 RT base , Chalk White
    Mar 2024
    Maine
    I did but no music. Phone works but.... it all works fine in my Tundra
    Danbury Connecticut
    Quote Originally Posted by Sxvipere View Post
    Just took ownership of my first Spyder. 2024 Spyder RT Limited Platinum. First question. Connect phone via bluetooth. Unit sees the phone, contacts, recent calls... but will not show up on media app. Phone is a Samsung S22. If im playing music on phone then start the bike once it finds the phone the audio stops on phone as its connected to bike via bluetooth. What am i missing to get music to play. Thanks
    Have you connected the phone function only? You might try pairing the phone under "Bluetooth Audio" as well.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Active Member Maplehawk's Avatar
    Dec 2023
    Saint Cloud, FL
    Quote Originally Posted by RayBJ View Post
    If its a 2024 then he can't use BRP App yet because its part of AppleCarplay which isn't available yet
    2024 RT Limited, Petrol Metalic Sold, replaced with Goldwing
    Baja Ron Sway Bar
    TricLED Front Fender Reflectors with Sequential LED Turn Signals & Running Lights
    Show Chrome LED Trunk Lights with Run, Brake & Sequential Turn Signals
    Mo-Door Garage Door Opener
    Fobo Electronic Tire Pressure Monitoring System
    Show Chrome Heavy-Duty Replacement Rear Trunk Lid Lift Support Strut / Shock
    Show Chrome Trunk Mounted Luggage Rack
    SpyderExtras Billet Aluminum Handlebar Riser Kit
    Mar 2024
    Maine
    No apple car play here, Samsung S22
    Oct 2020
    Arizona
    Put a bluetooth helmet kit in your helmet(s). I have a Cardo Spirit HD system and listen to music all the time from either smartphone or my Garmin Zumo XT with a micro SD card having the music. As long as the paired helmet listens to their own separate music/smartphone, the intercom still works, and mutes the music when you talk.
    Mar 2024
    Maine
    Found the answer. As I suspected it's a firmware issue. Guy with same issue got his resolved this week.
    I have the answer to the fix. Just picket up my Spyder yesterday from the dealer. There is a canam software bug that causes the probem. The dealer got permission from canam to wipe out the initial software "flash" the place in all new Spyders. Canam gave the dealer a one time access to their proprietary software and able to, in no techincial terms. to "reflash" the software into the spyder system. It is now working perfectly. However, canam stated it was a bandaid fix and will be coming out with an update for Spyders by Marchf 25th, which of course is tomorrow so I don't have a lot of confidence on that. However, at least they know what the problem is while most dealers do NOT. Hope this helps
    Feb 2024
    Tennesse
    I hope the March 25th update will fix the issue.
    racoon
    Middle Tennessee
    2024 CAN-AM Spyder RT Sea-to-Sky - Vegas White Satin
    2023 Honda Ridgeline Sport - Sonic Grey Pearl (aka Baby Blue)
    2024 RT Sea-to-Sky , Vegas White Satin
    Active Member Johndeeredoo's Avatar
    Aug 2018
    South haven michigan
    Quote Originally Posted by racoon View Post
    Well, I have read in other areas that it's now the first or second week in April, what happened to the first or second week in February?
    As for Apple CarPlay, I wonder how BRP is going to compensate us (the buyers of BRP products that have Apple CarPlay integrated products) for selling us a defective product (Apple CarPlay does not work) and that they knew was going to be defective (Apple CarPlay does not work) when they shipped out their product and never told the dealers and/or the customers in any way?
    indpls in
    chill defective means not working junk toast needs replaced just because there may me a software or licensing issue does not mean its defective
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    @fatboy... well, true, but either way we don't have access to ACP (or Android Auto for that matter). The BRP hang tag on my new 2024 S2S clearly states ACP and details how to connect including a one liner to enjoy your favourite apps (Google Maps, Spotify, and more). And in tiny, tiny, tiny print on the bottom of the tag, it also says Android Auto coming soon.
    I can scan that in and post it here if you really need it......... but here is the BRP part number 704909988_EN for you to dig out...
    This is in addition to the severe issue with the screen going blank, the heated grips failing or not installed, various other codes including ABS and hydraulic clutch issues, and the final straw, a cheap Chinese brand battery with a 6-month warranty that many 2023 and 2024 owners say lasts just that long before dying.
    I dunno about you, but if you had to replace a new battery on your new brand new 2024 Spyder in just 6 months, what would you do? Replacement by dealer is the exact same crap, so warranty isn't gonna help much.....
    Wait! .... That's if you ever get your bike back and its actually working, with no codes, blank screen, and other stuff you paid for to be working, etc.
    2024 RT Sea to Sky (back at dealer again due to blank screen issues, loss of BT and WIFI :-( :-( AND the new cluster BRP sent is not linking to the bike properly = BRP fail again)
    indpls in
    I just picked up my new '24 RTL Friday, everything works! As a matter of fact, I think it has more pep than my '21 RTL did! I dunno, maybe just me picking up the wife's '24 S2S Wednesday - only issue so far, the '24 F3 handlebars are not available. Also, Lamonster's top cuff does not fit the new bars, so when CarPlay is operating it will be a bonus.
    By the way, love not having the antenna sticking up anymore!
    Feb 2024
    Tennesse
    As for the cheap battery issue, now that I've heard about it here, something the dealer tried to sell me makes sense.
    They tried to add on a two year replacement warranty on the battery, which I declined, because I had no idea that any battery would die that quickly.
    racoon
    Middle Tennessee
    Mar 2024
    Maine
    Dont understand the bluetooth issue. The tech has been around 20+ years!
    Nov 2022
    Georgia USA
    Yeah me too, gives a clean look to the bike. So just for info where the heck is the antenna located? Please , please not in the cluster.....
    indpls in
    not sure but i believe it is where the antenna use to be but internal on both the side cases
    Active Member helton61's Avatar
    Jan 2023
    Virginia
    This is what i did he has a good channel.https://www.youtube.com/watch?v=2bwMUJZXAt0&t=613s
    2016 RT Limited Orbital Blue. Ultimate seat
    Bajaron swaybar,PV3 with BLR custom Tune
    Farrod front car tires p165/65/15
    Led headlights and fog lights
    Showchrome windshield.
    Two Brothers Muffler and cat delete pipe.
