Results 1 to 12 of 12
    Active Member Claire's Avatar
    Jul 2019
    Georgia
    Default Need to replace Coolant & Flush on 2009 GS & have some questions?
    Hey All
    I've been reading through older threads and can't find an answer so I'm posting here.
    Couple of Questions.
    1. How to flush a radiator? And yes I'm draining via the hose. I have not and will not try to drain by the bolt on radiator.
    It was suggested to use distilled water & run the bike till the fan starts.
    A. Will distilled water clean all the hoses and the radiator? or
    B. is there a flush cleaner I should use
    2. What coolant is suggested for the 2009 GS? Hot weather. I'm in FL
    Originally green was added by a dealer. I drained that green today and had XPS orange - BUT this is why I'm here. I did not flush it and realized that green was probably still in the hoses when I poured the new orange in there today. I only started it twice for about 3 mins each time - fan never went on so I'm guessing it really did not get hot enough. Only went to 2 bars, then decided not to drive it when I realized it probably needed to be cleaned out. It hasn't been drained in about 3 yrs - it's my daily ride with low miles.
    Any advice is appreciated. Thank you!
    Edit to add: Can I use Water Wetter in this model?
    Last edited by Peter Aawen; 02-11-2024 at 06:27 PM. Reason: Expanded title to briefly state the reason for this thread! ;-)
    2009 GS SE5: Stage 2 Elka front shocks, BajaRon sway bar, K&N air filter, kuryakyn foot pegs, TricLED rear and front lights.
    Bossier LoUiSiAna
    Please just flush the mixed colors out quickly- regular tap water flush(collect & dispose properly) & once clean can go back with one color & some distilled if needed to top off
    - I really don't know about the specific coolants that you've used and their compatibility, Claire, but I DO KNOW that mixing coolants, even without running the engine/circulating the coolant at all, might result in a chemical reaction between dissimilar products that can form what is effectively CEMENT inside your cooling system &/or raditaor, or if it doesn't do that, it could create a highly corrosive mix that you really don't want to leave in anything for very long at all! (Do you really hafta ask how I know this little fact?? ) It is largely for this reason that you/everyone/anyone REALLY shouldn't change coolants without a thorough cooling system flush!
    So unless you KNOW that the green dealer supplied coolant and your replacement Orange coolant truly ARE compatible, then I'd suggest that you drain everything out of your cooling system RIGHT NOW or sooner, and immediately thoroughly flush the radiator and block with a LOT of fresh, running water! Your garden hose should be fine to do that, and it might even be an idea to run the engine for a minute with the hose supplying water to the block! It'll safely run gently for a minute or so without any coolant, and you really want to try and get any mixed coolant out of the system completely, so make sure you flush both the block and the radiator with copious amounts of water!!
    And sadly, if those two coolants aren't UNDENIABLY COMPATIBLE, you really have no choice but to discard whatever you drain out of the system now, even tho it might be brand new; and dispose of it (properly tho, not just down the drain/stormwater! ) because by adding the new Orange to any unflushed green that was left in the system, you've effectively mixed them inside the block/radiator anyway, and ANY incompatible mix left in there for too long could be damaging or even destroying things in there in a very expensive way!! Of course, none of this is an issue IF you can confirm that they are compatible.... You might be able to guess that they are, but do you really know what the dealer put in there last time??
    Just Sayin' Good Luck!
    Jul 2019
    Georgia
    Thank you for the feedback. Its 730pm here and I can't do it now. I will get out there and get rid of it tmwr.
    Can I leave it sit with no coolant till I get some? in a few days
    How do I flush the block?
    I can put the hose in the radiator I know that.
    Should I close up the radiator drain hose & run the engine for a minute?
    Distilled water vs hose water?
    Jul 2019
    Georgia
    Thank you!
    Quote Originally Posted by Claire View Post
    If you don't know that it's compatible and no-one else here can shed any light on that likelihood, you really should at least drain it out NOW, even if it's midnight &/or close to freezing!!
    Admittedly, it's a 'Worst Case' scenario, but how lucky do you feel?? If the mix that's in there now really is a combination of incompatible coolants, leaving it in there overnight could mean that you end up needing a new radiator AND a new engine!!
    This is because if you let incompatible coolants mix in the radiator core &/or the small cooling channels and galleries in the block where they can harden into something very much like concrete, there's effectively no 'non-destructive' way of getting it out of all the nooks and crannies and small cooling channels and your engine basically becomes a throw away job!! And even if the mix only turns into a highly corrosive substance, leaving it in there for even as little as just a few minutes to let it chew away at all the dissimilar metals and gaskets etc REALLY isn't all that good for your engine, radiator, cooling system, or any of those critical gaskets etc!!
    To flush the block, just put the running garden hose into the other side of the radiator hose you took off - one way clearly goes into the radiator, the other goes into the engine/block, so after you've flushed the radiator, just stick the running hose into the other side... And it doesn't hurt to gently run the engine for a minute or so while the hose is running water in there; that helps pump any remaining coolant out of the water pump & thermostat, cooling galleries etc, so it's a better flush than just pumping water in there, and if you only do it for a minute or so, you won't be over-heating or damaging anything.
    As for using distilled water or just tap water, if you are simply flushing everything before re-filling with proper coolant, sure, you can do that, but why waste any extra time/effort/money on distilled water when all you really want/need is a relatively benign liquid to flush out any remaining coolant. So unless you live in an area where your tap water is extremely 'hard' or full of high levels of dissolved metals, chemicals, calcium, etc, there's absolutely no benefit in using anything else....
    Jul 2019
    Georgia
    A quick update: all good! I dropped the new coolant. Flushed with hose water - ran for 2 mins. no more than that. Added distilled water and ran for 2 mins. going to add coolant.
    Peter, you're signature says worry less mate! I'm curious if you experienced coolant turning to gel in an engine?
    Yes, I've been able to help a few owners who've had their vehicle's 'incompatible coolant mix' turn to gel - fixing that is sometimes possible, but it's always a pain; AND I couldn't really help a couple where that mix had already turned into unmovable concrete!!
    And Yes, I do try to practice & tell others to Ride More, Worry Less - after all, that's a lot of what riding is all about for many of us! But I really DON'T encourage people to play Russian Roulette at all - and mixing potentially incompatible coolant types is pretty much doing just that... Especially if you leave it in there for too long! You might ask, "How long is too long?" but that's even harder to answer than "How long is a piece of string?"
    ... Just let me add ..... you can get an anti-freeze / coolant tester , however BRP makes it very difficult to get a sample .... also note just because it won't freeze / over-heat doesn't tell you how effect it is to prevent corrosion .... Mike
    I could be wrong .... But I believe you need to use HOT water to flush - WHY .... Cold water will not allow the thermostat ( which controls coolant flow ) through the engine ..... Bert - Peter is this correct .... Mike ..... Correction : Although this will work - you need to have a LARGE source of Boiling water ......
    AFAIK, using Hot water to flush your cooling system won't hurt, but if you use the 'garden hose in the radiator first & then swap it to run into the engine' method, or some similar 'copious quantities of running water' method, it's not strictly necessary that the thermostat opens, but if you can flow that much hot water for long enough, then it certainly won't hurt!
    But as mentioned, it's not strictly necessary to open the thermostat; firstly, because the thermostat won't completely block off all flow of coolant &/or flushing water around the system anyway - most cooling systems &/or the thermostats themselves even have a small bypass built in to allow for some flow around the system even with a fully closed thermostat (most engine coolant pumps prefer if not actually need to move some coolant while they're running, and some few can even be damaged if they can't!); and secondly, by running the water into the system thru the radiator, and then by running it 'the other way' or vice versa, you're effectively stirring up any old coolant that remains in the system and either completely flushing it out thru the quantity and flow rate of the flush, or the remaining coolant is being so diluted by the sheer volume/quantity of flushing water that it's no longer an issue...
    Dec 2022
    NY
    I wouldn’t worry too much about it. I did my 2010 RS. Tore off the right-side Tupperware. The bolt at the bottom of the radiator is fine to use. It’s very different than the stupid “petcocks” that we see on cars. This is an actual metal bolt in a metal radiator. I removed the reservoir cap, removed the drain bolt, waited for the drainage to slow to a drip, started the Spyder with a garden hose in the reservoir and the drain plug out. Let it run for 3-5 minutes until the water draining out ran clear. Shut off the bike, wait for the water to quit draining, put the plug back in, filled the reservoir with Prestone 50/50 pre mix, start the bike with reservoir cap off, add coolant as necessary until level remains constant over a period of 10 - 15 minutes, shut bike off, top coolant off to max line, put on the reservoir cap and replace the Tupperware, and enjoy your ride. My coolant level tends to want to drop off to about 1/4 of the reservoir, but then never gets any lower. Don’t worry about that. The reservoir is only there to accommodate expansion, so as long as there is some coolant in it when it’s cold, you’ll be fine. Take note of the level that your Spyder likes to be at. As I said, mine likes to be about 1/4 tank. And it stays there, which is good enough for the girls I go with.
    ~~2010 RS SE5 My first Spidey, but not my first ride~~
    The trigger’s been pulled. We have to
    get there before the hammer falls.
