Results 1 to 14 of 14
    Member kjog's Avatar
    Sep 2018
    Northeast Texas
    Default 2022 F3 Transmission won't downshift - Any ideas?
    Bought a 2022 F3 Limited Special Series that was garaged and basically not ridden in over a year. Had 24 miles on it. The transmission shifts up fine but doesn’t downshift automatically or manually when slowing down. Most of the time when you stop, it downshifts. The display showing gear selection disappears in 5th gear and shifter-paddle quits working. Any ideas on a solution. Just changed the oil but nothing changed.
    Last edited by Peter Aawen; 02-01-2024 at 11:18 PM. Reason: Expanded title to briefly ask the question... ;-)
    Bossier LoUiSiAna
    Well on my 998 I have had a stripped shift arm.
    You can vaguely see the missing splines. The arm is soft metal & unfortunately can strip easily. Don’t know if it's sacrificial & saving the transmission. Especially don’t know if it's the same on 2022 F3's.
    Durham,Maine
    I would take it to the shop! Number one, there may be some warranty left on that bike. Number two, I think there's a communication problem between the paddle shifter and ecu and you may need BUDS to track it. There have been a few people having troubles with the shifting paddle, but yours sounds different. Good luck with your gremlin!
    2012 RTL , Pearl
    Sep 2018
    Northeast Texas
    thank you. shop visit is set
    There were some '22/'23-ish Spyders getting gremlins like this in their Left Hand Control Module, and IIRC, most were covered under warranty. So as Mikey suggested, it might be well worth your while to get it checked out by a dealer. You might need/want to do some searching here first tho, to get all the necessary details for a warranty claim; I'm pretty sure it's here if you look!
    Sep 2018
    Northeast Texas
    Thanks. A shop visit is pending
    Sep 2018
    Northeast Texas
    Bought a 2022 F3 Limited Special Series that was garaged and basically not ridden in over a year. Had 24 miles on it. The transmission shifts up fine but doesn’t downshift automatically or manually when slowing down. Most of the time when you stop, it downshifts. The display showing gear selection disappears in 5th gear and shifter-paddle quits working. Just changed the oil but nothing changed. It does have a warranty. Any ideas on a solution or what suggestions to ask the shop to look for when it is taken in?
    Last edited by Peter Aawen; 02-02-2024 at 02:10 PM. Reason: Merged duplicated thread.... :-/
    There were some '22/'23-ish Spyders getting gremlins like this in their Left Hand Control Module, and IIRC, most were covered under warranty. So as Mikey suggested, it might be well worth your while to get it checked out by a dealer. You might need/want to do some searching here first tho, to get all the necessary details for a warranty claim; I'm pretty sure ut's here if you look!
    ........ Mike
    Sep 2018
    Northeast Texas
    We've got an appointment for it tomorrow. Hoping it's a lighthearted gremlin.
    Sep 2018
    Northeast Texas
    UPDATE: The mechanic "relearned gear position sensor, tightened battery terminals and test drove for 30 minutes". It is shifting fine now. All covered under warranty.
    Sep 2012
    Stetson, Maine
    Thanks for informing us of the cure. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Sep 2018
    Northeast Texas
    Very Welcome.
    Apr 2021
    Wisconsin
    Did the mechanic say how (The mechanic "relearned gear position sensor,) might be good information if this happens on the road on a long trip.
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by TRMary View Post
    It can be done using BUDS interface…….one of many service options available.
    2019 F3L , Covid Blue
Tags for this Thread
