Page 2 of 2 FirstFirst 12
Results 26 to 48 of 48
  1. #26
    Jan 2021
    Descanso, CA
    Thumbs down
    Those bolts will not fit down into the hole. The spark plug holes are less than 8mm and the bolts are much larger than that.
    Baja Ron offers (https://www.spyderlovers.com/forums/...rs-amp-Helmets) and most people use the NGK CR7EIX Iridium which has a thread diameter of 10mm https://www.sparkplug-crossreference...eter%3A%2010mm
  2. #27
    C'mon guys, play nice! Last 'warning'!
  3. #28
    This has been an interesting subject to say the least. The moderators are wanting to keep this site friendly to all. There is no reason to trade barbs back and forth. There are a couple other sites out there where the "wise guys" rule. Rather than being user friendly, they are not helpful to Spyder owners in general. You can even find a few people who have been banned from this site for just such behavior.
    Let's keep it informative and save the "wise guy" barbs for other sites. Thanking you all in advance.
    Quote Originally Posted by Scottncol View Post
    Great idea. I would assume that they could use the current ECM, since the engines are the same. Thoughts?
    Regardless of where you get an engine, you REALLY NEED to keep your existing Engine Control, Transmission Control, and Dash/Console Modules unless you also change pretty much the rest of the bike!! Your Control Modules are tailored to the Spyder you have - it's not too hard to use BUDS to re-programme them to accept a different engine, probably not even necessary at all if you only change the short motor and stay with the same SE6 gearbox type; but it'll be a SERIOUS PAIN if not completely impossible to make work if you happen to get & install an ECM, a TCM, or a dash/console that comes off a Spyder with a different rear sprocket - and given the year & model of your existing Spyder, that's a pretty high risk!!
    So sure, get a new/replacement engine/trans assembly if that's the way you want to go, but I'd suggest that you DO NOT use any other ECM, TCM, or Dash/Console module without making sure that EVERYTHING else between your bike & the donor bike is identical!
    Ps: And unless you want to open up yet another absolutely steaming can of worms, it'll be a whole lot easier to do an engine swap if you get another SE6 - unless it's absolutely unavoidable, you really don't want to try to graft in all the semi-auto clutch & shifter arrangements!
    Last edited by Peter Aawen; 02-01-2024 at 07:16 PM. Reason: Added Dash/Console per BR's advice. ;-)
  5. #30
    Jan 2024
    PA
    If I am looking directly at the gear box on a Spyder, is there a way to tell the difference between the manual and semi-automatic?
    i am looking for engines on ebay and they are all 1330's but the gear box looks different and there nothing in the description of the engine that tells me if its manual or semi.
  6. #31
    Active Member Latrappe's Avatar
    Nov 2022
    Flaxton Queensland Australia
    Hello Scott, I have found this so interesting. As I have mentioned earlier, I believe that you got a steal if the price was right for the to start with, even if you have to go through a bit of pain now. So when you get it sorted out and running you will have a good machine; the only thing that makes me cringe is the tow bar on your F3S that I have seen in the picture, as I don't believe they are suited to tow, unlike the F3T or RT's which have that ability, but as I mentioned that's just my opinion.
    2019 Can Am Spyder F3S
    ICSI Ride Hand Brake Kit as my right leg and foot does not work that well due to MS
    The Ultimate F3 Floorboard
    Baja Ron Sway Bar
    Shad Saddle Bags
    Lamonster F3 PACKRACK
    SHAD 58X in Carbon finish - Expandable TOP Case
    Pedal Box
    IPS Belt Tensioner and Handlebar Riser from Lamonster
    K&N air filter
    INNOVV K5
    Wilbers Nite Line Shocks
    RLS Cat Delete
    Floating Rotors with EBC Brakes for the front
    I am now broke
    I Should mention the Boss has a 900 Ryker Ralli next to my bike
    2018 F3S , Monolith Black
  7. #32
    Jan 2024
    PA
    Quote Originally Posted by Latrappe View Post
    You have my word, as soon as I get this running, that is the first thing to go!
    Last edited by Peter Aawen; 02-02-2024 at 12:55 AM. Reason: Fixed quote display ;-)
  8. #33
    Nov 2022
    Baja Ron Sway Bar
    Shad Saddle Bags
    Pedal Box
    K&N air filter
    INNOVV K5
    RLS Cat Delete
    I am now broke
  9. #34
    Check out Bert Remington's recommendation back in post #9 - He's put in the effort, gone out of his way to help you in researching this, and found that engine. It is out of a 2016 F3 with an 89T rear sprocket like yours, so as far as we can see, it should be a direct replacement for your current engine without any ECM, TCM, or Dash/Console mis-match issues...
    Just sayin'
  10. #35
    Jan 2024
    PA
    Just sayin'
    I agree. Great engine.
  11. #36
    Jun 2011
    Alamogordo, NM
    I agree with Peter above.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
  12. #37
    Jan 2024
    PA
    Picked up a used engine.
    1096 miles.
    Thanks.
  13. #38
    Clinton, MS
    1096 miles.
    Thanks.
    That ain't even broke in yet.
    2019 RTL Phoenix Orange
  14. #39
    Jan 2024
    PA
    The front of the bike was rather smashed up but the engine was in great shape.
  15. #40
    Sep 2012
    Stetson, Maine
    Congrats on the new motor...
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
  16. #41
    Nov 2022
    Hello Scott, that is awesome mate that is good news for you, keep us posted on how it all works for you mate.
    Baja Ron Sway Bar
    Shad Saddle Bags
    Pedal Box
    K&N air filter
    INNOVV K5
    RLS Cat Delete
    I am now broke
  17. #42
    Durham,Maine
    Good job, get her in and running!!!
    2012 RTL , Pearl
  18. #43
    Nov 2022
    Hi Scott, I hope this all works out for you mate just keep us posted as I mentioned earlier, I am super interested in the outcome, for you mate as it seems to be working out for you hopefully not to long and you will be riding your very own
    Baja Ron Sway Bar
    Shad Saddle Bags
    Pedal Box
    K&N air filter
    INNOVV K5
    RLS Cat Delete
    I am now broke
  19. #44
    Jan 2024
    PA
    It has been removed and is up for sale.. great advice, thanks!
  20. #45
    Feb 2012
    Spring City,Utah
    Actually all Spyders can tow with no problem, they were designed from the beginning to be able to tow unlike all other motorcycles and trikes. Although many of them do and very successfully. If you don't want to tow that is fine but it will do it.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  21. #46
    Jan 2024
    PA
    Great info, thanks!
    I would never need to tow, so off it comes.
  22. #47
    Active Member AndysF3S's Avatar
    Jul 2023
    Alberta
    1096 miles.
    Thanks.
    Looks like a good engine let us know how it runs after the transplant.
  23. #48
    Jan 2024
    PA
    Quote Originally Posted by AndysF3S View Post
    Will do. Can't wait but it may be a week or two.
    Edit: Here's a link to the engine transplant thread:
    https://www.spyderlovers.com/forums/...eing-installed
