Results 1 to 25 of 25
    Dec 2013
    Default Can't reach your Rear Tire Valve Stem?? DO NOT DO THIS!!
    OK, I know you all might be sick of me carrying on about tires and tire pressures, but when this rear tire rolled up my drive a little while ago, I decided that now, I REALLY HAVE seen it all when it comes to dodgy tire jobs!!
    The background (short-ish version ) to it all goes like this - a newbie with tire problems was sent to me to see if I could help - turns out, this newbie has a 2023 RT that he purchased new less than 12 months ago. The issue he was concerned about was the AWFUL vibration issues he'd had with his Spyder ever since it had its first service done; vibrations that the tech/s who'd done the job claimed they couldn't replicate, find, &/or fix. (Yeah, right!! ) So this relative newbie to Spyders asked me to look at his Spyder & its tires to see if I could sort the vibration....
    He's not a young guy (like so many of us.. ) and he found it very difficult to check the air pressure in his rear tire, which he mentioned when he took his Spyder back for its first service.... He also mentioned that he'd read on this Forum (he reads the threads, but he's not a member - yet! ) that some members here had drilled a hole into the opposite side of the rim to the OEM valve & installed another valve stem that was easier to get at, so he asked if maybe they'd do that for him while they had his bike - and the pic below shows what they did (taken some time after I'd removed the tire & cut it up to check out some other damage it had & what caused the bulge in the upper left where the tread joins the sidewall... ) Anyhow, I reckon that this has gotta mean that I now truly have seen it all when it comes to dodgy tire jobs!!
    I've seen all sorts of dodgy things: like tires held together & onto the rim with fencing wire; punctured tires stuffed with sand &/or grass to 'inflate' them enough to ride out to safety on; I've seen tec-screws drilled into the tread to act as 'studs' when riding in snow, on ice, or in mud; and now I've seen a bloody valve put directly into the sidewall of a tire!! . Surely this is the be all & end all of dodgy tire jobs... SURELY??
    Check it out... Only please, DO NOT DO THIS to your tires!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Mar 2018
    pennsylvania
    Wink
    unbelievable
    Sep 2017
    Durham,Maine
    For once a tire thread I enjoy!!! This thing was holding air?
    2012 RTL , Pearl
    Very Active Member CloverHillCrawler's Avatar
    Mar 2021
    Maryland
    What makes this even more of a facepalm is that a tech in a dealership did this and no one else at the dealership noticed this as it was being done or returned to the customer. You think it would raise some eyebrows even with the request to drill it before it was performed.
    2020 F3 SE6
    Safety and Lighting: LED Headlight upgrade, IPS LED Fog lights, Show Chrome LED Fender Signals, LED Signature Light, Tric LED Afterburnerz, MotoHorn 2.0
    Suspension: Wilbers Front and Rear Shocks, BajaRon Sway Bar, Vredestein Quatrac Front and Rear Tires
    Comfort: Blue Ridge Windshield, Corbin Dual Touring Saddle, Ultimate Floorboards, OEM Passenger Backrest with Rear Shelf, OEM Passenger Floorboards Modified with High Risers from Pierre
    Tackform Center Mount Phone Holder w/ rapid charging USB-C.
    2020 F3 , Black
    Mar 2013
    WOW
    Now there's a tech that thinks outside the box, and that's where he should be - outside in a box somewhere away from anything with tools!
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Very Active Member Tango's Avatar
    Apr 2012
    Florida
    This pic, and a letter should be sent to BRP!!!!
    Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
    2020 Petrol Blue Metallic RTL
    Feb 2020
    CT and ME
    Wow. Just wow...
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
    Jul 2023
    Chesterfield SC
    To start with the "dealer" should buy and install a new tire for this poor man. This is beyond sad. I can't believe that this tire actually held air.
    2011 Can AM RT-S SE5 Red
    Jul 2021
    IL
    I don't plan on doing this to my rear tire, but I share the frustration with getting to the stem on the rear tire. I installed a TPMS system so that I don't have to check the tire pressure manually, but I still have to get to it at least once a year to add air and to replace the battery in the TPMS valve. I'm 80 and have damaged shoulders. I have to lie down on the ground and reach the stem with great difficulty. This is one of the few things about my Spyder that I am unhappy about, but I guess I can live with it.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
    with Peter ...... let me add that I started putting an 87 / 90 degree metal motorcycle valve stem on the DISK brake side of the rear wheel over a decade ago ( done three so far ) to avoid this issue .... all have worked out fine ...... I wouldn't bother doing it until a normal rear tire change .... I bought mine from KurveyKurl on-line .....Mike
    All I can say on this is my, my, my.
    Jun 2011
    Alamogordo, NM
    81 here, this has made airing and checking all 3 tires an absolute piece of cake. Bought it from Amazon
    JACO FlowPro 2.0 Digital Tire Inflator with Pressure Gauge - 200 PSI
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Oct 2021
    Wichita, KS
    That is some really, really bad (sad) stuff there!
    Peter Pan has struck again!
    Dec 2020
    Hartwell, Ga
    The scary part is that the "Shop Manager" let the tire leave like that. IMHO the whole dealership should be avoided.
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    Quote Originally Posted by old Timer View Post
    I got that same unit from Amazon a year ago, and its made all my tire checking super easy!! I use it on all my vehicles including my E-bicycle!
    2014 RTL bought in 3/20 with only 6,000 mi.
    Came with Garmin 660
    Car tires in 5/20; Elka stage 2 front shocks in 10/21
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by vito1943 View Post
    Vito, you might be able to get away with not getting down on the ground. I, too, have difficulty doing that.
    I find that if you release the handbrake, you can roll the Spyder until the rear valve is at around 3 o’clock. If you sit on a mechanics stool beside the rear wheel, you can get both left and right hand onto the FOBO and unscrew it, then pop your preset battery operated pump onto the valve for correct pressure, then use both hands to screw FOBO back on. Works for me, but as we are all different it may not work for you.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2016
    I assume this was a South Australian dealer, Peter?
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2018
    Australia
    Pffttt..........didn't even loctite the core in by the looks of it.Sack him.
    2017 F3S Daytona , Circuit Yellow Metalic
    Dec 2013
    Pete
    I can't say Pete - I've been asked by the owner not to say anything about the dealer, so I'm not sayin' nuffin'!
    Mind you, apparently it's been posted online in one of those 'Customer States - mechanical nightmare' or 'mechanical fails' or similar u-tube short videos, but I can't find it and haven't been sent a link...
    Active Member Gldwnger's Avatar
    Apr 2015
    Kitts Hill, Ohio
    Is it April 1st down under?
    Dec 2013
    Quote Originally Posted by Gldwnger View Post
    When I first saw it, I did wonder, but No...
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by Tango View Post
    this picture and a letter should be sent to the GM/Owner and a copy to the service manager of the Dealership that did this.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Dec 2013
    See post #19 - I understand that more than that ^^ has already happened.... Just waiting to hear if anything much comes of it all.
    Active Member Latrappe's Avatar
    Nov 2022
    Flaxton Queensland Australia
    Hello Pete, I am assuming the tech had his lights on, but nobody was home. Yeah, I have seen dodgy things that the situation demands while in the services but never anything like that.
    2019 Can Am Spyder F3S
    ICSI Ride Hand Brake Kit as my right leg and foot does not work that well due to MS
    The Ultimate F3 Floorboard
    Baja Ron Sway Bar
    Shad Saddle Bags
    Lamonster F3 PACKRACK
    SHAD 58X in Carbon finish - Expandable TOP Case
    Pedal Box
    IPS Belt Tensioner and Handlebar Riser from Lamonster
    K&N air filter
    INNOVV K5
    Wilbers Nite Line Shocks
    RLS Cat Delete
    Floating Rotors with EBC Brakes for the front
    I am now broke
    I Should mention the Boss has a 900 Ryker Ralli next to my bike
    2018 F3S , Monolith Black
    Dec 2013
    I'm told I can't say anything more about this, at least for now - except for "Please don't do this to a tire, any tire!"
