Results 1 to 20 of 20
    Jan 2024
    Rochester NY
    Default Are Tire 'Flat Stoppers' necessary for winter storage??
    I've got a 2012 RT that's "new" to me so I'm clueless on most things Spyder. With so many opinions on the internet/YT, I thought I'd check the forum here. Didn't catch anything on my 1st search of the topic so I hope I'm not annoying you all with a "same old question" asked and answered a million times.
    If storing in my garage (now on a battery tender) for winter months - I'm guessing 3 more months at this point, should the wheels be on flat stoppers? I've got a local friend who owns a Spyder who swears by them and said she never stores w/o them. Haven't seen much written on it, so I'm curious what you all find. I Certainly don't want to cause flat spots in the tires from 4mo of winter storage.
    Thanks!!
    Mike
    Last edited by Peter Aawen; 01-22-2024 at 05:55 PM. Reason: Expanded title to briefly ask the question... ;-)
    Nov 2018
    Waynesboro, PA
    Hello Mike2012RT, I have never used them (flat stoppers) and have never had a problem. I just put the battery tender on and put fuel stabilizer in the gas if the Spyder is going to sit for some time.
    My Spyder
    2012 RTL , Brown
    I have never used them. We stored our bikes in Alaska from November through March most years. A little air and about 10 miles will take any "kinks" out.
    I don't think I'd bother with them. The weight of a Spyder vs tire on the ground is not high. Radial tires do not get the same flat spot issue that the old biased ply tires did. I've never had a problem. Stored a Spyder for over 4 years without creating a flat spot, though I did keep the tires aired up.
    Sep 2016
    Chillicothe, Oh.
    Nope. Battery tender, full gas tank with some stabilizer, and don't start it unless you're going to ride and get it up to full operating temperature.
    2015 RT , Black
    Jun 2011
    Alamogordo, NM
    Absolutely correct thing to do.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Jan 2024
    Rochester NY
    Thanks all for chiming in. Since the verdict seems to be don't bother that's what i'm going with!!
    Quote Originally Posted by Mike2012RT View Post
    Thanks!!
    Mike
    My Spyder is in my warm basement for the winter so this doesn't apply to me ..... HOWEVER - I do have other cars that are out all winter ( in Vermont ) and I inflate those tires to slightly above the max psi on those tires .... they don't flat spot over the winter ..... If you do the same to your Spyder , they won't flat-spot either ....Mike
    Bossier LoUiSiAna
    Plenty threads on hibernation & prevention
    https://www.spyderlovers.com/forums/...rge-maintainer
    May 2014
    Benson, NY
    I leave my spyder on these HF furniture movers so I can move it out of the way for the off season. Have never had an issue.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Wow! A subject that everyone agrees on! This is AMAZING!
    Sep 2016
    Chillicothe, Oh.
    2015 RT , Black
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Bensonoid View Post
    Yup.. Same here. Also add a few extra PSI to the tires for storage.
    2022 RT Sea To Sky
    Feb 2022
    New Zealand
    Cheers for reminding me about those Ben.
    I will see whats available down here.
    Not that we have to store bikes for months on end but it could free up some floor-space room and park them closer.
    Easy to move to access stuff in the shed. Like cupboards with occasional required stuff.
    Hell push the boat out and make up some "outrigger style" ( tyres and side-stand) sets for the 2 wheelers. Stack em closer. Can only ride 1 at a time after all. Even more room and maneuverability. Himmm.
    Your photos show they will be simple to knock up a set.
    12 rollers, some 1"x3" timber to cut up and 36 bolts to tie them together. Have to price up I guess.
    2017 F3 Ltd
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Isopedella View Post
    I bought my three thru Harbor Freight on a Black Friday sale for $9.80/each. Heck, they're only $13/each normally. I don't what you have available in NZ though ..
    2022 RT Sea To Sky
    Active Member 3Tyme's Avatar
    Feb 2019
    SE Ohio
    Maybe Hell did freeze over, It felt like it here a couple of mornings
    2015 F3-S , Silver
    Quote Originally Posted by 3Tyme View Post
    That must be it! Not sure why I didn't think of it. Both are on the same plane of improbability. My wife says I should have kept quiet. 'Now', she tells me, 'someone will disagree and ruin the vibe!' So, I'm going to enjoy it while it lasts!
    Sep 2016
    Chillicothe, Oh.
    Hasn't it though? Now we get to tread water for a week.
    2015 RT , Black
    Active Member mecsw500's Avatar
    Sep 2021
    UT
    Never worried about flat spots, Can Am or motorcycles. Used Sta-Bil most years, unless I forget. Always on a battery tender anyway. Give it a wipe down to get the dust off. I've never had a problem from November to March storage. Pretty cold in my garage over the winter, and hot over the summer so I find batteries don't last as long as they should, so I check the voltage when the bike is running and charging. Modern machines seem very sensitive to having a good battery so every other year at least one of my machines seems to need one.
    Set tires to 20/28 in the spring. Go for a long enough ride to get everything all warmed up, fresh tank of gas (premium, I don't worry about Ethanol free) and it's all set. Book it in for an oil and filter and I'm ready to go for the year.
    Can Am Syder RT Limited (2021)
    Triumph Bonneville T120 (2018)
    2021 RT Limited , Silver
Tags for this Thread
