Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
  1. #26
    Clinton, MS
    If you want to add something that really makes a difference, get something that doesn't change the exponential of the throttle, spend a few bucks more and get the dang thing flashed.
    2019 RTL Phoenix Orange
  2. #27
    Dick ...... but you are .....JMHO ....Mike
  3. #28
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    IMHO. It's more the time it takes a human to twist the throttle wide open vs an immediate electronic response to wide open throttle with a slight twist of the wrist. All I know is that my Spyder really came to life when I added the Peddle Commander, so much so, that I had to dial it back from the Sport+ mode 3 numbers down as it made the throttle a little too twitchy in city traffic. I will not be removing my Pedal Commander anytime soon. I feel I have awoken a sleeping giant.
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
  4. #29
    Active Member DickB's Avatar
    Jun 2021
    FL
    Quote Originally Posted by Valkrocket View Post
    As I pointed out, the time it took this human to fully twist the grip on a Ryker is 76 ms, or .076 seconds. Pedal Commander can accelerate partial twist signal by 35 ms, or .035 seconds. A blink of an eye is .1 seconds. So the "improvement" is a third of a blink of an eye. Keep in mind, this is an acceleration in the signal to the ECM, not an acceleration in actual butterfly opening. As I stated and measured, butterfly opening speed is limited by the throttle body slew rate. If the twist grip were replaced with a toggle switch, providing instant 100% signal to the ECM, the butterfly would not open instantly, but only as fast as the throttle body slew rate.
    Pedal Commander does not emulate a toggle switch to provide an "immediate electronic response to wide open throttle with a slight twist of the wrist", per their own chart. In both cases, with and without Pedal Commander, you must twist fully to get wide open butterfly. Pedal Commander does not improve wide open butterfly response at all.
    Making the twist grip "twitchy" is exactly what Pedal Commander does. If that makes you feel as if you have woken a sleeping giant, peace.
  5. #30
    Active Member nightfalcon's Avatar
    May 2023
    New Zealand
    Quote Originally Posted by DickB View Post
    so....Pedal Commander tells the butterfly to open a third of a blink of an eye earlier than would otherwise be the case. The butterfly has a fixed maximum speed at which it can open but PC allows the command to do its thing 0.035ms earlier?
    That is, while the throttle is being opened (as fast as the operator is able) PC is accelerating the response time from throttle input to butterfly actuation by 0.035ms (throughout throttle opening)?
    Thus, while the butterfly isn't moving faster it is activating quicker.... albeit marginally....providing earlier acceleration which appears to be interpreted by riders as faster acceleration. In actual fact it is earlier acceleration which you say is akin to a twitchy throttle.
    Have I got this right?
    My brain is hurting.......
  6. #31
    Jun 2021
    FL
    Quote Originally Posted by nightfalcon View Post
    No, it doesn't. My statement regarding .035 seconds was confusing, so just forget about it for now. Let's look instead at what is happening moment by moment.
    Normally (that is, not ECO mode, not traction control, etc.), the ECM is going to try to put the butterfly where the twist grip is telling it to. In other words, it is going to try to match the yellow signal (butterfly) to the blue signal (twist grip). The speed at which things are happening is evident by the slope of the signals - the faster things are happening, the steeper the slope of the signals.
    Let's look first at the case where the signals are dropping - that is, when I released the twist grip. The slope of the twist grip (light blue) is very steep - things are happening fast - because the spring in the twist grip snaps the grip back very quickly. But the slope of the butterfly (yellow) is not as steep - not moving as fast as the twist grip. Why? Because the throttle body cannot physically move as fast as the twist grip is snapping back. It is moving as fast as it can. That speed - the slope of the falling yellow line - is the slew rate.
    Now look at the case where the signals are rising - twisting open. Note that the slope of the yellow line is the same as when falling - in other words, moving at the maximum slew rate of the throttle body. Since the slope of the light blue line is the same, that tells us that I just happened to be twisting at the same rate as the maximum speed of the throttle body. If I would have tried and been able to twist even faster, the butterfly would not have opened any faster. The dark blue line represents what Pedal Commander would signal the ECM if I had one installed. So yes, while the slope is steeper, telling the ECM that I was twisting faster than I actually was, it would make no difference. Once the twist signal rate of change (slope) exceeds the throttle body slew rate, the butterfly can't move any faster.
  7. #32
    May 2023
    New Zealand
    My comment....
    "so....Pedal Commander tells the butterfly to open a third of a blink of an eye earlier than would otherwise be the case."
    would've been better written... Pedal commander tells the butterfly to open wider than would otherwise be the case?
    Given your comment....
    "Because Pedal Commander does make the twist grip more sensitive, a small twist of the grip with it will open the butterfly more and thus deliver more power than the same small twist without it. This increase in sensitivity is perceived as improved throttle response."
    It follows that by installing PC the throttle control inputs are going to move the butterfly wider (therefore increase the expected acceleration) than would otherwise be the case for the same rotational throttle input without PC. What isn't in question is the wider the butterfly opens the more fuel is available and the faster the engine will rev/ accelerate.
    "Throttle response" in the context of this debate comes down to semantics. Clearly the throttle is more responsive....'twitchy as you put it. In fact PC is designed to make the throttle over respond to an input. It's clear this over responding is very noticeable by riders...your quarter turn is now a three quarter turn (for argument sake).
    While you appear (to me) to have a solid argument on how the throttle system works the fact PC makes the bike accelerate further along the slew graph with less rotational input of the throttle is essentially the same thing as the ryker owners with PC are saying...the throttle responds better.....it's a rose by another name.....surely?
  8. #33
    Active Member AndysF3S's Avatar
    Jul 2023
    Alberta
    A couple of years ago, the trail skidoo riders (Renegade, MXZ models) didn't like doo's electronic throttle because it was tooooo twitchy for a lot of them. Sooo in 2022, Doo changed the throttle from electronic to a cable that goes to a module (variable resistor?) that sends the signal to the ECM which then sends the signal to the throttle body. Baas ackwards IMO, but it is what it is. Reverse engineering at its best.
  9. #34
    Jun 2021
    FL
    My comment....
    No, it’s not a rose by another name. It is throttle response (time) versus input sensitivity (effort or distance) and they are entirely different things, not different names for the same thing. And often confused.
    First, addressing semantics, I have been careful and precise in my use of my terms. Others have not.
    Some use the term “throttle” to mean the twist grip, and some use “throttle” to mean the butterfly. I have used the terms “twist grip” and “butterfly” to avoid any confusion regarding the meaning of terms.
    Misusage of the term “throttle response” has happened in this thread and elsewhere. At the outset I defined throttle response to mean a measure of how quickly a vehicle's engine can increase its power output in response to a driver's request for acceleration. This is the generally accepted definition (https://en.wikipedia.org/wiki/Throttle_response), and in fact is the definition used by Pedal Commander on their website:
    “…throttle response is more appropriately referred to as the time speed of increase in levels of power…”
    Note that nowhere in the definition of “throttle response” is there any reference to the amount of effort or the distance required to move an input device to increase power. That is sensitivity.
    So when I refer to “throttle response” I'm referring to the time to increase power.
    Since the data shows that in stock condition the butterfly can be opened as fast as the throttle body slew rate allows, maximum throttle response (shortest time to increase in power) can be had in stock condition. Pedal Commander does not and can not improve throttle response; to do so would require the butterfly to move faster than it is physically able.
    Pedal Commander alters input device (twist grip or pedal) sensitivity. Again, from Pedal Commander’s website:
    “It lets you adjust how sensitive your gas pedal is.”
    So yes, if you twist the grip less than 100%, the more sensitive input device is going to cause the butterfly to open more. But this relationship is independent of time, and therefore is not throttle response, it is sensitivity. I have acknowledged that an increase in sensitivity is (wrongly) interpreted by many as improved throttle response.
    I have consistently and clearly stated that Power Commander alters sensitivity but does not alter throttle response. I have postulated and then proved with real word Ryker data that if you twist fast, you get the maximum possible throttle response out of a Ryker.
    There may be an issue with semantics, but I don’t have that issue.
