Results 1 to 6 of 6
    Jul 2010
    Las Vegas, NV
    Default I Highly recommend the Pedal box
    Put a pedal box from Lamonster’s Garage on a friend’s bike the other day. Fantastic! Works great, and makes quite a difference! I’m sold! I also agree with his video; connect it, and mount it under the body. My friend had a cuff, which is cool, but I think once you have it set to where you want it, you won’t mess with it. Highly recommend! Joe
    Joe Meyer
    Harrington, Australia
    Yes, mine did exactly what I wanted it to, Joe. I agree completely
    HeliBars Handlebars
    Kenda Kanine rear.
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Unfortunately, I bought the pedal box and after a month, kept getting fault codes. I was not successful in getting a refund. Their support was only interested in telling me over and over how to reset it, which would work for a few runs, but then would act up again. I ended up buying the pedal commander and actually like it better. But good luck with yours. They definitely make a difference in throttle response.
    2021 RT Base - Petrol Blue
    Sep 2020
    Middletown, NJ
    Some have said the Pedal Commander is not waterproof.
    I noticed with the PC, my MPG sank drastically compared to the lethargic non-PC operation when always on. So, for casual rides, I shut it off and when I'm feeling frisky I use it and burn thru gas with a big grin on my face. I mounted the box on the dash below the cowl and after 20k miles of all-weather touring, it's been bulletproof to the elements. Just saying.
    2020 RT base , Chalk White
    Mar 2021
    Arizona high country
    I also have the pedal commander. I mounted mine under the seat once I decided on my desired setting. Since I can control it with my phone there is no need to have it out in the open (waterproof or not)
    Sep 2020
    Middletown, NJ
    Quote Originally Posted by rjinaz86323 View Post
    Being an old-school techno weeny, not a fan of all-in-one / single failure-point devices. Maybe more clutter but easier to perform functions w/o diddling with phone apps.
    My point re: rain protection was not to fret with having it exposed unless you ride under water.
