Results 1 to 14 of 14
    Active Member seaweed's Avatar
    Oct 2015
    Fort Lupton, Colorado
    Default Looking for a quick release strap for a modular helmet - any ideas?
    I have tried a quick release from https://www.amazon.com/Helmet-Releas...7762600&sr=8-1 for a full modular helmet but it is a bit too loose for my satisfaction. Does anyone know of a quick release that would work better for a modular helmet?
    Dean Secord AKA seaweed
    Veteran: U.S. Air Force
    2015 RT-S SE6
    My Mods:
    Sep 2020
    Middletown, NJ
    There are a couple other styles but they all add at least 1 inch to the loop under your neck.
    I ended up buying my carbon lid with quick release from Europe because the same USA model was D-ring.
    2020 RT base , Chalk White
    When I was Vending I bought a bunch on E-bay for about $ 2.00 ea. .... they arn't as big as that one ..... it did require you cutting off the " D " rings and sewing it on .... but sewing isn't rocket science .... ..... JMHO .... Mike
    Oct 2015
    Lynden, WA
    I have 2 helmets. a Full Face and a Modular. I use this release on both helmets.
    No cutting of the D Rings is needed.
    https://www.amazon.com/dp/B01KGGP7SW...lig_dp_it&th=1
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Active Member Woodswoman's Avatar
    Nov 2020
    Upstate NY
    This is the model of add-on quick release buckle I have used.
    https://www.motorcyclegear.com/parts...se_buckle.html
    Very sturdy -- in fact, it's pretty stiff until you use it awhile. But it works fine, with no cutting required.
    2016 Spyder F3-S
    Feb 2022
    New Zealand
    Just wondering which "full modular helmet' dosnt come with a quick release strap these days?
    I previously had a Nolan then went to Evoline with the fully folded back chin bit if ya wanted to,
    latest helmet is a LS2 Valiant, which I find great by the way.
    All had the quick release catch as SOP.
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by Haze View Post
    I've used several of these over the year. Given enough use the male end might eventually break and need replacement. Have them on two helmets I currently use most.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Sep 2020
    Middletown, NJ
    Quote Originally Posted by Isopedella View Post
    For one, the HJC C90 modular. The USA version in Carbon Fiber comes with D rings but the Europe version has quick-release.
    AND the US lid is over $100 more.
    Mar 2015
    forrest above Reno, Nv
    I've used one that's all metal in the actual attachments with just a little plastic cover. I've had all plastic clip's in the past and they have broken..............
    Lew L
    2014 RTS , Circuit Yellow
    Oct 2015
    Quote Originally Posted by RayBJ View Post
    But where can the poor suckers in the States buy a Europe version? What would the shipping cost be?
    2015 RT-S SE6
    My Mods:
    Oct 2015
    Not all the Europe versions are quick-release. Look at https://hjchelmets.eu/products/rpha-12-carbon. That one is DOUBLE-D RING
    2015 RT-S SE6
    My Mods:
    Florida Swamp
    Once upon a time, I bought a quick release buckle for a full face helmet because it was so hard trying to thread the D rings up under the edge of the helmet. It worked, but where it had to be attached to the D rings put the buckle in a place that bit into the edge of my jawbone.
    Take whatever moral you want to from this fable.
    2019 F3-S , Black & Silver
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by seaweed View Post
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2020
    Middletown, NJ
    I already had the US model of the HJC C90 with D-rings that fits my noggin and my other lids all have quick release (QR). I wanted the lighter C90 Carbon model but only the EU model uses the QR. I ordered the lid from Netherlands and got the QR and saved over $100 in the process.
