Results 1 to 6 of 6
    Jul 2023
    Florida
    Question Lamonster Top Cuff w/Cup Holder Hitting Dash Cover on 2023 Sea-to-Sky?
    Recently installed a Lamonster Top Cuff with Drink Holder on my new, 2023 Can Am Spyder RT Sea-to-Sky. Absolutely love this add-on, but just noticed that on STEEP turns, the cup holder (Even without a cup in it!) can hit the dash/display cover.
    Does anyone else have this issue and how did you work around it? I assume putting a RAM ball in the back with a short arm to get the actual holder out of the way is the only option?
    Thanks, in advance, for any insight/tips!
    2016 Can Am Spyder RT Limited
    Crawfordville, Florida
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Why don't you call Lamonster? It's his design so maybe he has some guidance.
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by RonH2K View Post
    I have the 2020RTL and Lamonster's cuff with drink holder. I also have the Lamonster handlebar riser kit which gets the handlebars up and back away from the dash approx 2 inches, giving more room between dash & handlebars. No problem with hitting the drink holder.
    2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
    Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
    BaJa Ron Ultra 3 pcs sway bar kit
    7jurock 25" tinted windscreen w/flip
    Frogman Dave's "Signal Button"
    If in Doubt, Don't Do It!
    " Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
    Jul 2023
    Florida
    Great tip! Thanks! I'm seeing a riser set from Show Chrome, but not a Lamonster-specific one. Would have the same impact, I'm sure.
    Thanks, again!
    Active Member Abbot Spyder's Avatar
    Jul 2008
    Abbot Maine
    I have a 2023 sea to sky I put the cup holder inside the handle bar. I had the same issue, so I instal the cup holder inside the handle bar. Problem solve.
    IBA # 61125
    Saddle Sore 1000
    Bun Burner 1500
    1st one to do 48/10 on a Spyder
    4 Corner Finisher
    SCMA Member
    Oct 2021
    Wichita, KS
    Quote Originally Posted by Knizar View Post
    Same here. I hadn't thought that not having the riser might be a problem, but I guess it is.
    Peter Pan has struck again!
